16 threads found!
thartwick1 | 6 | 371 | ||
thartwick1 | 7 | 298 | ||
Advisories: nudity
thartwick1 | 10 | 224 | |
thartwick1 | 2 | 60 | ||
thartwick1 | 2 | 26 | ||
thartwick1 | 2 | 88 | ||
thartwick1 | 0 | 22 |
(none)
thartwick1 | 5 | 70 | ||
thartwick1 | 0 | 26 |
(none)
thartwick1 | 0 | 12 |
(none)
thartwick1 | 3 | 205 | ||
thartwick1 | 3 | 188 | ||
thartwick1 | 5 | 145 | ||
thartwick1 | 2 | 34 | ||
thartwick1 | 4 | 53 |
37 comments found!
Thread: Please Help - Lost document window in the Pose Room | Forum: Poser 12
Thanks for the tip.Glad it was a simple fix. Once you have everything back where you want, I recommend setting one of the UI dots to make it easier to fix if it happens again.
Setting to factory state on the interface fixed it. I forgot that launching to preferred and factory states is on two tabs. I had it set to factory state on the document page, but that obviously didn't fix that issue. Thanks very much. I was pulling what little hair I have let out.
Tom
Thread: zip code | Forum: MarketPlace Customers
Thread: Bringing in Figure or Object into specific place in scene | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
HartyBart posted at 11:28AM Mon, 27 July 2020 - #4395327
Yes, the "SnapTo" script uses Tkinter as part of the PoserPython script - which means Mac users can't run it. Tkinter is one of the many things not supported by Apple.
But you don't have to miss out on all Python scripts. Open the desired script with a text editor, and look for "Tkinter" near the top. If it's not there, then you can likely run the script. Unless, perhaps Apple has introduced further security-blocks that I've not yet heard about.
Thanks for this tip. I did try running it and it does use Tkinter.
bwldrd posted at 7:36PM Sun, 26 July 2020 - #4395306
Not really for when bringing it in, but once you have an item in you seen an easy way to move it would be Ochams 'snap to' script on his site @ Ocham's Bungalow
I'm on a Max so python scripts don't work. Thanks anyway!!!
structure posted at 7:35PM Sun, 26 July 2020 - #4395301
you can create a pose and save the body transformations - this way you can put back to the exact same place every time
see this thread for finding objects in a large scene.
Thanks!!
Thread: Poser 11.2.319 translate editing tool deforming figure | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
LeeMoon posted at 7:07PM Mon, 25 November 2019 - #4371273
Definitely a different behavior with the translate tool. From time to time, I use the translate tool to "nudge" a hand or foot around and the limb/torso/etc. will follow along depending on how far I move the body part. I can confirm that the stretching is happening in Poser Pro 11.2.319 on macOS Catslina. Stretching DOES NOT occur on my Mac running macOS Sierra and Poser Pro 11.2.319.
Additionally, the translate tool works normally on the first use of it, but begins stretching on the following usages.
I hope this gets sorted out quickly.
Lee
Thanks Lee and Nerd, confirming it isn't just me that is experiencing this. Hopefully the developers will look into this.
Tom
Thread: Problems conforming to V4 figure and non working morphs | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Thread: Order paid for - still showing unpaid | Forum: MarketPlace Customers
Thread: Adding Insult to Injury | Forum: MarketPlace Customers
Thread: Fantastic Friday coupon not working | Forum: Community Center
Interesting. The coupon code is on a number of products such as https://www.renderosity.com/mod/bcs/?ViewProduct=108288. I guess they were never updated to remove the following text. You can see that no year is given, only a month and day.
We'd like to welcome you to Fantastic Friday at Renderosity where we're celebrating the arrival of the upcoming weekend by highlighting 20 NEW MarketPlace releases such as this one!
As an added bonus - we're offering a special coupon code FanFri0123B10P10 that can be applied to each of these items. Coupon Code valid now through Monday, January 26th and provides savings of 10% on each of these items. Must spend at least $10 at checkout to qualify. HAPPY SHOPPING
Thread: Can the 'new' Vue still do Poser imports? | Forum: Vue
