Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 24 11:54 pm)
does this mean that there won't be dynamic versions of the bra and stockings? or that there will be both? that is, is this a progression or addition? i know i'd be interested in the dynamic versions you have now, because i anticipate using the many morphs that should come out that haven't yet (muscularity, capsces', etc.).
cobaltdream: both versions.will be included. They'll share their geometry and UV mapping, so duplicate material collections /MAT poses won't be necessary.
My gallery   My freestuff
wow. this is going to be incredible. thanks so much!
oh, and my pic using the v3 clothes is in my gallery now: Escape from the Office. it's much more tame than that title sounds, i realize now.
i just read that clothify body part tutorial.. i had tried that myself without success...it was the coreographed groups! doh
yep svdl kills i've been using your dynamics for years. i bought many packages, yet yours always better. now i make some of my own. can't wait to see your mesh see how it's done now.
thanks for all you've done over the years
Bra is done, except for ERC-ing to Victoria 4.
Blouse is done
Pencil skirt and mini skirt are done
Garter needs reboning and remorphing, geometry and mapping are done.
UV mapping and templates are done.
Material collections and separate P5 materials are half way.
Poser 5 MAT poses are half way.
CopyMorphs script is done.
Stockings are being converted right now. Might have to tweak the geometry a little.
Since the stockings are VERY tight, some displacement adjustment to V4's legs are necessary. I'll write a P5 script and a P6 wacro to adjust the leg displacements (I'll try to leave existing displacement in place. Takes some figuring out).
To allow for the non-infinitely small thickness of the stockings, shoes also need a displacement adjustment. I'll write a P5 script /P6 wacro for shoe material adjustment too.
Everything will be included in the package.
ETA in freestuff: 1 to 2 weeks.
Anticipation is more than half the pleasure and eventual satisfaction. Sounds like a monster - shall we say master - work. Your 'ambition' should be rewarded by the sounds of things.
How do you model/conform/convert a stocking cloth mesh - close fitting to the wavefront .obj of the character? I use Modo but the principles should be the same as 3D Max (which I believe you have alluded to using). Are there some generic instructions or tuts on the subject? It would be painful to pull extend polys individually to'skin' close to he character mesh and not particularly consistent or accurate. Is there a specific toll/set that I'm missing?
The project sounds and looks magnificent and I'm sure that its reception will satisfy your 'ambition'.
Thanks again.
Reboning and remorphing of the garter is done.
I still have to make a conforming version of the stockings, and write a couple of scripts. A few days, and everything should be done.
Scripts ? We half to write scripts for dynamic cloths ?
Â
Is there anything I can not import from Poser to Vue ?
Â
RorrKonn
http://www.atomic-3d.com
============================================================Â
The
Artist that will fight for decades to conquer their media.
One of the scripts is done - it creates a morph in V4 that make the stockings fit better. It displaces all vertices 1 mm inwards from mid thigh down on both legs.
I'm still wrestling with a script that will add a little outward displacement to shoe materials - needed to prevent the stockings from poking through the shoes.
And I'm working on a script that'll set up the P6/P7 clothing simulations with the right parameters.Â
Only the first script does something that is as good as impossible to do by hand.Â
The other two scripts will provide a handy shortcut to things that also can be done by hand in the material room and the cloth room. Those scripts will only work in P6 and P7, the first script works in P5 too.
Attached Link: V4 Office Set
It is finished.This is what you'll find in the package
The ZIP file is quite large, 12.6 MB, and the upstream capacity of my server is limited. So if you can't get it to download, please be patient and try again later.
I hope you all have as much fun using this set as I had creating it.
Many thanks for this!Â
____________________________________________________________________________________________________________________________
Asus N50-600 - Intel Core i5-8400 CPU @ 2.80GHz · Windows 10 Home/11 upgrade 64-bit · 16GB DDR4 RAM · 1TB SSD and 1TB HDD; Graphics: NVIDIA Geforce GTX 1060 - 6GB GDDR5 VRAM; Software: Poser Pro 11x
Oops.
There's more in the package. I forgot to mention the pencil skirt and the mini skirt. The pencil skirt comes in 5 versions, from zipper fully closed to zipper fully open, the mini skirt has 3 zipper versions.
The skirts are also provided with several material collections/MAT poses.
The
svdl,
A week earlier than you predicted - magnificent contribution and effort on your part. I'm floating around next three weeks without access to Poser so ironically I can't test fly this until I get back. Great pity I don't have a laptop load of Poser during travels.
I am sure from the previews and the readmes that you have produced a superlative product.Â
Can't wait to test drive it.
Thanks again.
CobaltDreams you've done enough vacationing cause you have us seeing double ;)
Â
RorrKonn
The
I am working with the garter from svdl's office pack (magnificent) and am totally stumped by the read-me command "Magnetize the garter to Victoria 4 and run the CopyMorphs script to fit the top edge around Victoria 4's waist."
How does one "magnetize" - I have searched all the manuals and faintly remember some reference to this but can find nothing.
I have run the copy morph script and set the clips and run the simulation which works almost correctly but not quite.
So I presume not Magnetizing the garter is the problem. How do I do this please?
Victoria 4 comes with a set of poses in the category "Magnetize Clothing". That's what I meant with "magnetize to V4", you have to apply one of these "magnetize clothing" poses to the garter. Which one, that depends on the figure numbering of Victoria 4.
The pose folder is called Magnetize Clothing.
The pose files are called !Magnetize To V4, !Magnetize To V4 1, !Magnetize to V4 2 ... !Magnetize to V4 9.
I don't remember where the pose files originally extracted to, I immediately reorganized my libraries after installing the complete V4 bundle.
All I can say is, Wow! Can't wait! Thanks so much!!
