Fri, Nov 22, 12:41 AM CST
Subject: for picnic-the gold lam
maclean ( ) posted Sun, 27 August 2000 at 5:58 PM ยท edited Tue, 12 November 2024 at 11:38 PM
OK diane, I used your suggestion. Pic 1 is with the 'Dal' refl map at 550x550 and my own transmap on the formal dress top with hip and thighs out, and the mini below. No textures at all. As you can see it's much too metallic. Pic 2 is the same deal, with a fine square-net map as a bump, stretched to 500x750 on the mini and 1000x1500 on the formal. The squared look is what I want, but it's still too big on the formal (and the bump's already 6meg), so I have to find a finer net to use. Also I need to experiment, to try and get somewhere in between the two. Still working on it, but the direction's there. Will post it whenever I can (still have to transmap the back). It'll be my first post, so be kind. Thanks for all the help, and any suggestions and crits are always welcome. Alla da best from Italy. maclean
picnic ( ) posted Sun, 27 August 2000 at 6:29 PM
Hey, coming along great S. New trial--I went to Photopaint and opened Eyecandy and did the 'weave' in b/w, resampled it to quite small, then used it for 'fill' in a 1000 x 1000. Used that as bump, used the noise on gold for tex--tried with and without reflection map. You are probably going to have to make a small grid--VERY small--then make it a seamless tile and large enough to cover the template (otherwise you will get 'stretch' marks). I found with some of these dresses--if you aren't going to be looking at the back and the side seams are more important to be 'smooth'-- that cylindrical mapping works better. Then, of course, you have to deal with the seam down the back unless you are very meticulous about getting the seams to match. Hmmm--just thinking out loud and looking at your post again--probably the different sized map affected the sizing--you will most likely have to actually make a tex map with the size you want 'where' you want it. What's someone called maclean doing in Italy?? S Sounds like a wonderful life though. Diane B/picnic
maclean ( ) posted Sun, 27 August 2000 at 6:55 PM
Hey, diane. Still at it, I see. You're tenacious! I don't have Eyecandy, but I'm sure there's something in Photoshop I can use. Yeah, I need a really small grid: Just have to multiply a map and re-sample it down to size, I guess. The formal's a much bigger map to cover. I want to get it right because if I post it, someone will look at the sides anyway. Might manage it in the next day or two. PS Someone called maclean is in the Italian Alps at 6,000ft because he couldn't take Milan any longer! Came here from Scotland years ago and like it too much to leave. Did fashion and music photography, and am now doing web design (that way I don't have to get off my ss!) Hey, if you like fashion, check out my site (free plug!) http://www.infinito.it/utenti/maclean You might like it. Anyway, someone called maclean is going to bed now! It's 2am here! Goodnight...and thanks maclean (jimmi)
picnic ( ) posted Sun, 27 August 2000 at 9:56 PM
Oh, I do. Favorites--the violinist and the nudes, altho' all are really terrific. diane
maclean ( ) posted Mon, 28 August 2000 at 12:05 PM
gkad you like the pics, diane. Some things on the site are a bit sucky, but it was my first, and I can't be bothered re-doing it. Too much other work. Made a new refl. map and new bumps, and the lamdress looks more like what I want. Am currently trying out tex. maps to put creases in it. It should all be done in a day. Then I need to firure out how to post. Ciao maclean
