Tue, Jan 7, 8:57 AM CST
Subject: Requiring expert Bryce assistance
bandolin ( ) posted Fri, 14 January 2005 at 1:33 PM · edited Tue, 07 January 2025 at 8:56 AM
I've model this little space craft in BAM (Bryce adjunct modeller) otherwise known as W3D. Its a large luxury yatch made from a single cube. Except for the sphere on top of the conning tower. My 1st problem is texturing.
<strong>bandolin</strong><br />
[Former 3DS Max forum coordinator]<br />
<br />
<a href="http://www.renderosity.com/homepage.php">Homepage</a> ||
<a href="http://www.renderosity.com/mod/sitemail/">SiteMail</a> ||
<a href="http://excalibur.renderosity.com/mod/gallery/browse.php?user_id=70375">
Gallery</a> || <a href="http://www.renderosity.com/mod/freestuff/index.php?username=bandolin">
Freestuff</a>
<p><em>Caution: just a hobbyist</em></p>
bandolin ( ) posted Fri, 14 January 2005 at 1:35 PM
I've tried UV mapper with some help from Quest, and I've haven't been able to get anywhere. First off the many of the lines are missing, and I'm not quite sure how to apply a texture in PS using this a template. Its very confusing with all these lines in the way.
<br />
Freestuff</a>
bandolin ( ) posted Fri, 14 January 2005 at 1:37 PM
Here's the model in its native environment, just to give an idea of what it looks like.
<br />
Freestuff</a>
bandolin ( ) posted Fri, 14 January 2005 at 1:41 PM
My 2nd problem is lighting. I'd like to introduce porthole lights out of glowing cubes to give the effect that there a numerous decks and whatnot. How do you make a cube primitive glow. My final problem is achieving an exhaust glow from the engines. Any you folks have ideas about that. I've tried with miserable results which I'm embarassed to show.
<br />
Freestuff</a>
bandolin ( ) posted Fri, 14 January 2005 at 1:42 PM
Please don't be offended if I don't respond until towmorrow, I gotta run right now.
<br />
Freestuff</a>
bandolin ( ) posted Fri, 14 January 2005 at 1:43 PM
Oh, and if all works out, I'll be posting this a freebie. Once I figure out how to do that.
<br />
Freestuff</a>
draculaz ( ) posted Fri, 14 January 2005 at 3:26 PM
really cool work bandolin!! although uvmapper wise, unless you're really good with postwork techniques, the texture's gonna end up being somewhat crappy. i'd suggest using world cubic texture co-ordinates. that way you won't have to uvmap it. as well, if you want windows, you gotta define some extra materials in Wings. click on a face, give it a new material (color) and that face will be separate when you ungroup the model in Bryce. I like the fact that you de-smoothed it, it looks better that way. and what else... windows are easy, just find a texture with a lot of white, world cubic it, and add it as ambience levels :)
pakled ( ) posted Fri, 14 January 2005 at 4:05 PM
oh..that too. What I do is select face areas, and use Material (New, the right-click), and make up colors. Repeat for other areas you'd like to texture, until you've got everything covered. I cheat, since I use multiple primitives to make things, so I just go body mode|select|Face mode|Material, like that.
I've tried making portholes (dangit) by smoothing some faces, insetting slightly, and extruding inwards just a hair. Then set a material color just for them. I've had a little luck with a material called 'plasma' (don't know where I got it), which has some variations, so that it doesn't look too bad.
Another thing that (sorta) works is to make the portholes as indicated, then find a tiny face (wherever), and delete it. Then intrude, and don't set the thickness. Then go inside the model, and texture the same color (if needed).
Once in Bryce, you can drop a coupla radials in, and they shine outwards. May want to back off the intensity, unless there's little outside lighting.
Hope this has given you several ways 'not to' do it..;)
draculaz ( ) posted Fri, 14 January 2005 at 4:24 PM
you can make portholes with simple textures, there's no need to burden the model with more smoothing. then again, this is someone talking that won't make a model under 10mb... but yeah, ambience levels. randomize soem of those techno textures you have in the defaults.
ysvry ( ) posted Fri, 14 January 2005 at 6:45 PM
use an volumetric spotlamp for exhaust glow put it in the enigine facing out and put a normal lamp in its trail of the same color to put the glow back on the ship.
for some free stuff i made
and for almost daily fotos
Zhann ( ) posted Fri, 14 January 2005 at 7:31 PM
Got just the texture for it, coooool...=)
Bryce Forum Coordinator....
Dann-O ( ) posted Fri, 14 January 2005 at 8:30 PM
I always use photoshop and painter with UV mapper to texture I really don't like procedurals on my models. Usuing cubic mapping tends to give you too much unused space on yoru map. Try using a map from the Y axis don't split it. Then cut off the pieces that want to map from the Z axis. Set them aside. Remap the part you are mapping from the Y axis so it is split. Now you have a more workable map. I use layers in Photoshop and make lights with just a 4 pixel brush putting on dots or drwaing lines and deleting parts. Keep it in a different layer. Make the reast of yoru texture. Now after you have you texture ready open up your texture file in photoshop and hide all layers but the window layer. Set the color to black. You can use it as an ambience channel or as a transparency map and put soem lights inside.
The wit of a misplaced ex-patriot.
I cheated on my metaphysics exam by looking into the soul of the person next to me.
CrazyDawg ( ) posted Fri, 14 January 2005 at 10:17 PM
what i do is leave the modelling problems to others, texture wise i mess around with them until i get the look i want :) Nice model by the way, i'm still trying to get my 8 sided cube to look like something. Not bad at all for my first attempt it started out as a sphere
I have opinions of my own -- strong opinions -- but I don't always agree with them.
Quest ( ) posted Fri, 14 January 2005 at 10:31 PM
Ooooo, nice ship! Just bring the texture template into Photoshop and paint in your texture on a separate layerside views, top view, bottom view, front and back. Dont worry about the inside lines they just designate where your polygons are. Just use the outside shape lines as guides for your brush. Try a quickie in PS and youll see what I mean. Use different colors for all your sides then save it and import your model into Bryce then bring in the map in the 2D pic editor.
pauljs75 ( ) posted Fri, 14 January 2005 at 10:49 PM · edited Fri, 14 January 2005 at 10:50 PM
Unless you have UVmapper Pro, you're actually better off using the Wings-native UV mapping tools. Since v98.0.25 (or something) the ability to create UV cordinates is actually better than Classic's. Of course you're stuck with the square format for workspace, but the features and flexibility make up for that. You can also see where stretching is by comparing the model window to the grid, etc. Overlap can be pulled apart by selecting the right edges or vertices and moving them on the template as needed before finalizing it (telling it to "create texture").
Give it a shot sometime. Also like I've said before - once mapped the UVs are retained in Wings (unless you do some colors to material thing or whatever), so you can go and apply new materials to areas you mapped already. This way you can have the option of selecting different areas for using painted textures, procedurals, or any combinations of the like. :D
Message edited on: 01/14/2005 22:50
Barbequed Pixels?
Quest ( ) posted Sat, 15 January 2005 at 12:55 AM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=2051378
Youve already done all the work to derive the map, you just need to fill in your texture. Maybe take Zhanns texture offer to fill in your map in Photoshop. The uploaded image shows what I mean by filling in your colors/textures and what the mapped model would look like (more or less). Youve done the hard part. Forget about the lines inside the shapes. In fact, even if you dont stay inside the shape lines, the colors/texture will still appear right on your rendered model as long as you dont go overboard to overlap into the adjacent shapes.
Check out the thread above to see how I textured my Battlecraft. You can also download it from FreeStuff and take it apart to see how it's done.
pogmahone ( ) posted Sat, 15 January 2005 at 3:04 AM · edited Sat, 15 January 2005 at 3:06 AM
I find UnWrap3d easiest to use for UVmapping, but mostly I just set different materials on different areas/faces in Wings, then apply materials to the different areas in Bryce.
Following on from what Pakled suggested, you can either set a glass material for the windows/portholes in Wings, or you can get rid of the material in those areas altogether using the technique above, to let light shine through. (when intruding, leave a tiny clearance between the inside and outside of the object, or you might get light shining through at some seams). PS - Oops! the workflow might have been a bit clearer if I'd selected a face from the front of the object to Bridge, instead of going to the back :^(
Message edited on: 01/15/2005 03:06
Quest ( ) posted Sat, 15 January 2005 at 3:12 AM
Unfortunately Unwrap3D demo does not offer a way to save your map. Although Unwrap3D offers basically the same features as UVMaper, I would much proffer, after trying both, UVMapper
lordstormdragon ( ) posted Sat, 15 January 2005 at 4:39 AM
Ahh, I miss the days of Painter 3D... and Detailer... Wonder what I did with those two?
Quest ( ) posted Sat, 15 January 2005 at 6:47 AM
LSD, I have them both.
bandolin ( ) posted Sat, 15 January 2005 at 12:50 PM
You've guys have all given me alot of techniques, and I'm going to try them all, just for practice and results. I'd have given up on UV mapper but Quest makes it looks so easy. So I'll give it a shot aswell. Zhann, where's this texture you like? Don't keep it a secret. I actually thought about modelling the portholes and shining light out of them, but that would have taken alot of work and was hoping for an easier method. I'll try Drac's idea. Although I think I already did without success. I'm not quite sure I understand ysvry's technique. But I'll give it a shot. Thanks pog for the tut. I'll try that out first. Hey, an item from your part of the world made into my morning paper. Something about a Macgillycuddy of the Reeks from Co. Kerry just passed away? I guess its because Montreal has a large Irish population. You guys are awesome. Thanks to all. Although I have to admit, I didn't understand some of the stuff that was offered. My dimwittedness.
<br />
Freestuff</a>
pogmahone ( ) posted Sat, 15 January 2005 at 1:34 PM
Attached Link: http://www.homeatfirst.com/carraunt.htm
bandolin - spent every childhood holiday very close the the MacGillicuddy Reeks. My sister used to regularly get out of the car to walk certain parts of the road rather than trust my father's driving! Came on this quite interesting read when I googled to find out about the Macgillycuddy's death.
