Truth has no value without backing by unfounded belief.
Renderosity
Gallery
arcady, what version of Poser are you using? If it's 5, I've noticed that some textures don't import correctly into Bryce if you have special nodes from P5's material room connected. You may be missing a second texture (the blue skin) from the material room. If this is the case, you would need to import it via Leo in Bryce. Just a thought but the above ideas should work as well.
I dare you, while there is still time, to have a magnificent obsession. --William Danforth
Renderosity
Gallery
Yeah, the first time I put a 'B' and 'A' in thee together I kept wondering why she went back to flesh tones by the time it reached her feet. It took me almost three hours to make a DTE 'B' channel that was just a solid color too... It kept putting lines and squiggles in there... :p
Renderosity
Gallery
It took me almost three hours to make a DTE..<< I feel for ya. The DTE has a zillion different settings. I tested my ABC set up on a poser figure and it worked fine. I noticed that Bryce has an "export" button for it's textures, so I should be able to export the C channel texture. You're welcome to it if you want.
Ok, I'm importing the figure seen here into Bryce (victoria 3). In Poser she's got a texture map in normal skin tones, and then a blue color over it. I've gotten her texture set up in Bryce (image at right) with transparency, but I can figure out how to put in the blue... :)Truth has no value without backing by unfounded belief.
Renderosity Gallery
