Fri, Jan 10, 9:39 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
Subject: What 3D progs. allow you to create morph targets for Poser that work?
  • 1
  • 2
Kingfisher ( ) posted Fri, 11 March 2005 at 6:59 AM · edited Thu, 09 January 2025 at 12:28 AM
What 3D progs. allow you to create a morph target from an exported poser .obj file. Alter the mesh & then save the file as .obj & import it into Poser as a morph target. Without altering the number of vertices. If this happens you cannot use it as a morph target. Ive tried Amapi 6 & its ok. Tried Amapi Designer 7 & it alters the number of vertices on export. Carra 4 Pro does likewise. What`s your experiences?
xantor ( ) posted Fri, 11 March 2005 at 7:12 AM
Lightwave works.
linkdink ( ) posted Fri, 11 March 2005 at 7:15 AM
Excellent question, Kingfisher. Does Shade work for this purpose? I briefly looked into Raydream 3d, but got confused by the scale differences.
Gallery
PhilC ( ) posted Fri, 11 March 2005 at 7:35 AM
I have successfully created morphs with Truespace and Max.
DCArt ( ) posted Fri, 11 March 2005 at 7:45 AM
ZBrush. Unbeatable for morphs.
samcclung65 ( ) posted Fri, 11 March 2005 at 7:53 AM
I second ZBrush. Quick and easy morphs.
stonemason ( ) posted Fri, 11 March 2005 at 7:54 AM
yeah..Z-brush! ...perfect for morphing :)
Cg Society Portfolio
EnglishBob ( ) posted Fri, 11 March 2005 at 8:20 AM
On the free side, Anim8or works for me, and I believe Wings does too. A recent question in the technical forum suggests that Blender re-orders the vertices.
SWAMP ( ) posted Fri, 11 March 2005 at 8:43 AM
ZBrush!!!
-Timberwolf- ( ) posted Fri, 11 March 2005 at 9:06 AM
Is ZBrush also advisable for creating or altering whole Characters?
DCArt ( ) posted Fri, 11 March 2005 at 9:12 AM · edited Fri, 11 March 2005 at 9:14 AM
You can, if you do the workflow correctly.
You can export multiple body parts, import them into ZBrush, and export them out again for morphing. When you bring the OBJ file back into Poser, you use the grouping tool to break the objects back into their individual body parts, and then export the individual parts out again to use as morph targets.
That is yet another tutorial that I have to write. (Adds it to the outline). Hang on a sec, and I'll do a quick runthrough to make sure I get it right. 8-)
Message edited on: 03/11/2005 09:14
Teyon ( ) posted Fri, 11 March 2005 at 9:43 AM
WINGS3D
DCArt ( ) posted Fri, 11 March 2005 at 9:51 AM · edited Fri, 11 March 2005 at 9:56 AM
QUICK TUTORIAL: Morphing Multiple Body Parts with ZBrush
IN POSER
(1) Load a figure. Turn off inverse kinematics. Zero the pose and body/hip trans settings.
(2) File > Export > OBJ. Select the parts you want to morph. If you want to do a full body morph, go for it! 8-)
(3) When the dialog pops up, select only two options: INCLUDE EXISTING GROUPS IN POLYGON GROUPS and AS MORPH TARGET, NO WORLD TRANSFORMATIONS.
(4) Save the OBJ file in a place you remember! LOL
IN ZBRUSH 2.0
(1) From the Tool panel, choose Import. Locate the object you exported from Poser.
(2) Draw the object on the screen. It will initially come in upside down and backwards. You can rotate the model by keeping the mouse pressed down and moving the mouse until you position it the right way.
(3) In the Transform panel, turn on the Edit and Move icons. Also, turn XSymmetry on, so that the morphs automatically mirror to the other side (NICE, NICE, NICE!)
(4) In the Draw panel, set the draw size (the overall area affected), and the focus size (the area where the morph is strongest, it falls off to the outer setting).
(5) Morph away ... its great fun! You can change the brush size in the Draw panel as you complete your morph. You can also use the Edit panel to undo multiple steps if needed (it holds 64 levels).
(6) After youre done, go back to the Tool panel, and choose Export. Save the morphed file under a new name.
BACK IN POSER
(1) Choose File > Import > OBJ. Locate the morphed OBJ file. Uncheck ALL import options.
(2) Open the Group editor. Click the Spawn Props button. Now you should have the original multi-part object (which you can delete), and all individual body parts.
(3) File > Export > OBJ. Select one body part, and export it As Morph Target No World Transformations. Do this until all affected body parts are exported.
Now ... load in your original character. Select a body part that you made a morph for, and choose Object > Load Morph Target. Choose your custom morph target, give it a name, and then test it by dialing it in. Voila, you made a morph.
After you load ALL of the morphs in and have them set to 1, create your full body morph. Then turn all of the dials back to zero. When you dial the full body morph back to 1, you should see your full body morph, just as you created it in ZBrush!
Message edited on: 03/11/2005 09:56
operaguy ( ) posted Fri, 11 March 2005 at 10:03 AM
bookmarking and I second the notion of trueSpace. ::::: Opera :::::
Little_Dragon ( ) posted Fri, 11 March 2005 at 10:31 AM
MilkShape's .obj import/export works surprisingly well, as long as the mesh isn't too high-resolution. I typically do the bulk of my morphing with Poser's magnets and grouping tool, then load the results into MilkShape to tweak individual vertices. Ultimate Unwrap3D maintains the vertex count/order, also.
pakled ( ) posted Fri, 11 March 2005 at 10:47 AM
Attached Link: http://www.wings3d.com
Dr. Geep has a tutorial on making morphs in Wings 3d..here's the program, if you need it Wings local 509..;)
xen ( ) posted Fri, 11 March 2005 at 10:56 AM
Attached Link: http://nevercenter.com/index.php/Home/491
Silo works. Fab program.
Gareee ( ) posted Fri, 11 March 2005 at 11:08 AM
Simple answer, Kingfisher.. anything that will allow you to pretty much import a obj format file, modify it, and then save it again. There are a HUGE number of programs (as others have listed) that can do this.) Some are better for some things, some are better for others. Mojo is a new modeler recently released with some outstanding modeling features.
konan ( ) posted Fri, 11 March 2005 at 11:16 AM
Attached Link: http://www.blacksmith3d.com
Blacksmith3D-Morph allows you to import and export Poser CR2 files. You can simply import a CR2 file, morph any part of the body that you wish and export a new CR2 file. Full body morphs will be automatically setup if your morphs span over multiple body parts. Check out the free demo, Konan (Creator of Blacksmith3D) [![Blacksmith3D_Signature.jpg](http://www.blacksmith3d.com/images/Blacksmith3D_Signature.jpg)](http://www.blacksmith3d.com) Blacksmith3D - Morph - Paint - Suite Reshape Objects Easily. Paint textures in true 3D. Import/Export Poser CR2 or OBJ files. New version available (December 3, 2004)
-Timberwolf- ( ) posted Fri, 11 March 2005 at 11:40 AM
Sorry,Gareee I have to disagree.Cinema 4 D can Im/Export Obj-Files but importing back to Poser(without using external Plug-ins)You only get exploding Morphs.
EnglishBob ( ) posted Fri, 11 March 2005 at 11:43 AM
Gareee ( ) posted Fri, 11 March 2005 at 11:49 AM
As I said, pretty much.. I didn't say every single thing out there. There are exceptions to every rule, and if programs mess with point order, then of course they won't work.
DCArt ( ) posted Fri, 11 March 2005 at 11:53 AM
Well, maybe that is a good part of this reply as well. What programs mess with point order and what programs don't? For the record, Deep UV does, which is why I use UV Mapper Pro as a go-between.
konan ( ) posted Fri, 11 March 2005 at 11:59 AM
Blacksmith3D-Morph does not alter the point order, scale, or anything like that. It was originally designed for morphing Poser charcters. You can morph the original CR2 or OBJ file, morph any part of the body and export the CR2 file again. The morphs for the individual bodyparts are automatically separated and setup. Easy :o) Konan (Creator of Blacksmith3D) Blacksmith3D_Signature.jpg Blacksmith3D - Morph - Paint - Suite Reshape Objects Easily. Paint textures in true 3D. Import/Export Poser CR2 or OBJ files. New version available (December 3, 2004) http://www.blacksmith3d.com
Gareee ( ) posted Fri, 11 March 2005 at 12:03 PM
There are so many out there, the lit would take us forever to compile. I know lightwave is safe, but DeepUV is a uv editing program, used by many poser content artists. All it does is change uv mapping, if memory serves, and that means it does not mess with point order, but also, it cannot create morphs either. UVmapper pro is another UV editor, and again is NOT used for creating morphs. (although it can be used to fix some export issues) Plus another consideration, is price. Not many people are going to invest $1500-$4000 for a 3d modeling application just to create some morphs. Rather then a blanket "what all programs can" question, would be "what program do you use", or I'm considering x,y,z.. which would work? questions. It's kinda like asking which is the best grpahic editor for making textures... there are SO many to choose from.
Kingfisher ( ) posted Fri, 11 March 2005 at 12:04 PM
Thanks for the response. Ill have to check a few out. Demo first of course. You cant keep on sending out on different applications. Im just wondering though. Which version works o.k. & is the .obj a plug in or standard. As my experiences with Amapi shows it makes a difference. I havent found it very successful in going in & out of other progs like UV Mapper in sorting out the vertices numbers changing. Dont understand why they should change.
Netherworks ( ) posted Fri, 11 March 2005 at 12:05 PM
Deecey, my advice would be to use the figure's obj initially instead, and use the grouping tool to break it into props and delete the original .obj from the Poser scene. That way you're sure to get a completely zero'd, unmorphed or modified base to work with. Cinema 4D can do morphs too without reordering vertices if you use Spanki's free Riptide import/export plugin. Often you can use UVMapper Pro to fix re-ordered vertices.
DCArt ( ) posted Fri, 11 March 2005 at 12:08 PM
Good point, Netherworks!
Kingfisher ( ) posted Fri, 11 March 2005 at 12:13 PM
What about Shade? Has anyone used it successfully for morphs? After all it is sold by CL & is being shipped with Poser 6.
ScottA ( ) posted Fri, 11 March 2005 at 12:24 PM
1.)set the figure to a zero pose with the Joint Editor 2.)export the body part from Poser in .3ds format 3.)open the .3ds file in Cinema4D and make your changes 4.)Save that new file as .obj format 5.)load that .obj file as a morph target in Poser No exploding. Pretty simple stuff. -ScottA
stahlratte ( ) posted Fri, 11 March 2005 at 12:55 PM
Im using the Poser Magnets and Wings3D:
stahlratte
nomuse ( ) posted Fri, 11 March 2005 at 1:35 PM
Carrara DOES work, but most of the fun tools are out. Pretty much the only thing you can do is pull verts around by hand. (A fact I found to my dismay also applies to making morph targets for Carrara within Carrara). I've also used Amorphium, which is amusing, but you need to use a couple extra steps to keep it from changing the size of the morph-mesh.
capsces ( ) posted Fri, 11 March 2005 at 1:40 PM
Are you sure Carrara will not do the trick? I haven't really used it since version 1, but I thought it would do Poser morphs. Have you asked on the Carrara Yahoo Group? If you just want to do morphs, like make longer noses, wider hips, stuff that does not require a great deal of intricate mesh moving, I would suggest Poser magnets. They work great for body morphs, as you can save your magnets and use them on the clothing too.
capsces ( ) posted Fri, 11 March 2005 at 1:43 PM
I see nomuse confirmed that Cararra works before I hit the post button. ;)
odeathoflife ( ) posted Fri, 11 March 2005 at 2:03 PM
TrueSpace is awsome for morph targets cause you can work on the whole of the figure cause it keeps the hieracrchy and then you can break them into individual comonents to bring into poser for morphs
♠Ω Poser eZine Ω♠
♠Ω Poser Free Stuff Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
x2000 ( ) posted Fri, 11 March 2005 at 2:13 PM · edited Fri, 11 March 2005 at 2:14 PM
Most modelers will do morphs, but sometimes you need to know the exact procedure to get it to work.
POSER MORPHS FROM CINEMA 4D
http://www.designertoday.com/tabindex-17/tabId-72/itemid-1716/DesktopDefault.aspx
CREATING MORPH TARGETS IN CARRARA FOR USE IN POSER
http://www.geocities.com/porsche_carrara/index3
Message edited on: 03/11/2005 14:14
pokeydots ( ) posted Fri, 11 March 2005 at 2:19 PM
I'd like to learn more about Blacksmith but there isn't much info on the forum here :( I downloaded the demo, but where are there any tutorials?
Poser 9 SR3  and 8 sr3
Processor Type:  AMD Phenom II 830 Quad-Core
Hard Drive Size:  1TB
Processor - Clock Speed:  2.8 GHz
Operating System:  Windows 7 Home Premium 64-bit
Graphics Type:  ATI Radeon HD 4200
System Ram:  8GB
DCArt ( ) posted Fri, 11 March 2005 at 2:24 PM · edited Fri, 11 March 2005 at 2:25 PM
xantor, you mentioned LightWave. On some occasions, when I have imported figures, they split apart during morphing where the groups join. If I remember correctly, this happened with Judy. Have you ever encountered that, and if so, what is the workaround without changing vertex order?
Message edited on: 03/11/2005 14:25
konan ( ) posted Fri, 11 March 2005 at 2:25 PM
Attached Link: http://www.blacksmith3d.com/blacksmith3d_help.htm
The tutorials can be found at the attached link. We will be making some video demonstration tutorials in the very near future. These ones should help get you started. Konan (Creator of Blacksmith3D) [![Blacksmith3D_Signature.jpg](http://www.blacksmith3d.com/images/Blacksmith3D_Signature.jpg)](http://www.blacksmith3d.com) Blacksmith3D - Morph - Paint - Suite Reshape Objects Easily. Paint textures in true 3D. Import/Export Poser CR2 or OBJ files. New version available (December 3, 2004)
xantor ( ) posted Fri, 11 March 2005 at 3:10 PM
Deecey I have only made single morphs using lightwave.
DCArt ( ) posted Fri, 11 March 2005 at 3:15 PM
Ah ... ok, that explains that. 8-) The only way I could think of was to try to use UV mapper to weld the vertices, but of course, that gets rid of some of them and definitely DOES change the vertex order. ZBrush, on the other hand, sees the body as all one entity. Go figure.
x2000 ( ) posted Fri, 11 March 2005 at 4:46 PM
BTW, you can make morphs right in Poser using magnets, you know. They're actually quite useful once you get the hang of them.:)
jcbwms ( ) posted Fri, 11 March 2005 at 5:18 PM
There is a new product out from Greenbriar available at that bastion of effective equipment called DAZ that allows you to do exactly this. The ToolBox set -- and the Poser version is effective enough -- allows you to essentially rig & morph a figure (make one, even, apparently) completely, then export it as a Poser file directly (no importing into Poser), including joint parameters and other fashionable joys. It even includes a set up that create inj and rem settings automatically, including the file formats, that are either set up for their own channels or that use one of the preexisting ones. Basically, it is exactly what has long been asked for in regards to morphing.
Xena ( ) posted Fri, 11 March 2005 at 8:03 PM
Gotta second X2's comment. Poser magnets are a great way to make morphs for Poser. You just have to be patient and learn how to use them (like you would a modelling program to make morphs in it!) I make all my morphs with magnets. Find it less of a hassle than using a modelling program as I don't have to go back and forth between programs. Plus you have the added bonus of being able to save your magnet sets to the prop library so you can use them over and over again. I have FBM mag sets for all major characters saved this way.
ScottA ( ) posted Fri, 11 March 2005 at 8:34 PM
There are certain times when the Poser magnets won't do the job. I recently took on the daunting task of creating eyelid morphs for one of my figures. And even though I'm pretty good with Poser magnets. It's not doable with them. They don't handle small, detailed, overlapping geometry well at all. The only way to morph those types is to export the geometry into a 3D program that can select the surrounding vertices and faces and hide them so you can get at, and move, the proper vertices one by one.
DCArt ( ) posted Fri, 11 March 2005 at 10:08 PM
Yup, eyelid morphs are something even ZBrush couldn't handle that well.
pokeydots ( ) posted Fri, 11 March 2005 at 10:22 PM
Thanks Konan
System Ram:  8GB
Kingfisher ( ) posted Sat, 12 March 2005 at 11:16 AM
Carrara 4 Pro is ok with import/export & keeping the same number of vertices. I had the tick in the wrong box. It needed the tick to import as a single mesh.
Kingfisher ( ) posted Sat, 12 March 2005 at 12:01 PM
Also solved the problem with Amapi Designer 7. When poser exports the .obj it also exports the materials. When Amapi imports it creates meshes for each material. So I found that by removing the materials Amapi imports the .obj as one mesh with the same number of verices. Its just that Amapi has some excellent tools for selecting points & malipulating the mesh. And having got the hang of a fair proportion of the program Im reluctant to go elsewhere.
gtrdon ( ) posted Sat, 12 March 2005 at 11:28 PM
Kingfisher "So I found that by removing the materials Amapi imports the .obj as one mesh with the same number of verices. " How do you remove the materials in Amapi 7 or Poser? I have it but I am struggling to figure it out..
diviner ( ) posted Sat, 12 March 2005 at 11:37 PM · edited Sat, 12 March 2005 at 11:39 PM
Attached Link: http://www.renderosity.com/tut.ez?Form.ViewPages=865
I use anim8or when I want fine technical control and zbrush when I wasnt to go wild and get organic. I did a tutorial called 'Creating full body morphs in Zbrush2.0' It is in the tutorial section here under zbrush and also under 'poser secrets'. With Anim8or I can get hold of single points and nudge them nicely, but nothing beats Zbrush for organic stuff (in my humble opinion). Just edited this to say that the url above is a link to the tutorial I did.
Message edited on: 03/12/2005 23:39
  • 1
  • 2
