Thu, Feb 13, 1:58 AM CST
Subject: holy @#$% x_x how can a render take so long?
anxcon ( ) posted Wed, 08 February 2006 at 11:55 PM · edited Thu, 13 February 2025 at 1:57 AM
ok so i made a portrait, just 1024x768 shading 0.2, raytrace bounces 3, textures all 1024, 2 lights, no IBL takes 1 hour to do forehead, ok reasonable maybe i goto bed shortly after i saw it was doing the bucket that the right eye (all of it) was in 8 hours (about) later, i come back, the eye didn't show yet figure 8 hours should've been enough, thought poser froze so i sit down to consider cancelling, and my cursor is RIGHT ON the cancel button, when the eye shows up! almost 9 hours wasted :x eeep the corneas have nodes for reflection and spec iriss have the same (testing an idea with reflect) along with some nodes connected to ambient (another test) eyewhites also reflect, with a few nodes for noise so....WHY does it take 8 hours on the damn eye? not much different than a plain mirror really normally i don't care what the time cost, as long as the end result gets more realism, but damn x_x
operaguy ( ) posted Thu, 09 February 2006 at 12:29 AM
can you start by giving your hardware rig please? Also, pixel samples And please give the type of your two lights, with these three settings for shadow map: map size bias blur If raytraced shadows, please give settings for that. The time taken for forehead....that could well be hair-related. What hair model, and is it visible in raytrace? ::::: Opera :::::
anxcon ( ) posted Thu, 09 February 2006 at 12:39 AM
P4 3.2ghz, 1mb cache, 1gb ram (task manager says 250mb available) 5 pixel samples, lights both spotlights, 256 map, .05 bias, 8 blur raytraced shadows, dynamic hair, visible in raytracing usually i get 12 hours to render a pic (roughly) but this should take about 20 hours, yeesh x_x dont care if carrara has no "visible in raytrace" setting i think i'll be using it more than P6 soon! lol
operaguy ( ) posted Thu, 09 February 2006 at 12:45 AM
it's the dynamic hair visible in raytrace. That is MURDER on render time. Your other settings are reasonable. Why do you need the dynamic hair visible in raytrace? So it casts a shadow on the face? Just as an experiment, make the hair invisible to raytrace and try again. ::::: Opera :::::
operaguy ( ) posted Thu, 09 February 2006 at 12:53 AM
Rendertime: 552 seconds
size: 720x540 Two lights with DMShadows, but raytrace on for another effect, but dynamic hair (it's Kate Hair) invisible to raytrace.
Other settings similar to yours.
AMD 3500+
::::: Opera :::::
anxcon ( ) posted Thu, 09 February 2006 at 1:00 AM
i know it's murder, but all of the hair is done (and its shadows) took i figure 1 1/2 hours total for hair areas its just those eyes x_x doesnt seem like the hair would effect em though 2nd eye just finished btw, the reflections didnt come out like i wanted x_x goes the cheap way and rerenders 1 eye and composites do de do
operaguy ( ) posted Thu, 09 February 2006 at 1:02 AM
well...for the future then. I don't know what is making the eyes take so long. BTW: your strand hair goes bye bye if your take this scene into Carrara.
anxcon ( ) posted Thu, 09 February 2006 at 1:03 AM
shes cute :)
Robo2010 ( ) posted Thu, 09 February 2006 at 1:11 AM · edited Thu, 09 February 2006 at 1:19 AM
Umm...odd. P6 user here. I just stopped this render to call it a night (doing a test). And will continue on this tmrw. 5 hours to render this, but one more hour would have completed it. I think you need more ram. I dunno...when I started using Poser I was using 768mb SDram. Then P5, then upgraded system. I know Hair can hurt my render times.
Used a IBL AO on this.
WindowsXP(SP2)
3GB DDram (PC3200s, at 400mhz Dual Channel)
AMD Althon XP 3200+, 2.2Ghz
160MB HD (Pri), 80GB HD (Sec), (Both 7200RPM)
ATI Radeon 9600xt (128MB)
I have one time encountered those renders in the past (Using P6), that haven't moved. Wondering if something is running in the Background, a virus, spyware or other slowing things down. But this latest update for P6 is amazing (Well for me anyways). Sometimes a bad nod setup can do bad render times. For example I was using the gather nod, which I know now, I can never use at all does hurt rendering and possibly the system. I would check nod setups, specially on the eyes if that is where the render is holding.
Message edited on: 02/09/2006 01:19
anxcon ( ) posted Thu, 09 February 2006 at 1:33 AM
this was the last render, lower quality, about 3 minutes test has koz short hair, same basic look as the dynamic will be (hair swapped to dynamic at final renders, easier in creating pics) this was the last pic with flaws i thought i fixed before bed :P funny thing, the left eye has reflections i wanted, right eye doesnt the long render i had today, i thought i fixed, but the eyes had some problem, but it was the left not reflecting now -_- o well just showing what i was working towards :P
anxcon ( ) posted Thu, 09 February 2006 at 1:38 AM
and dont play critic :P its an old test render from before alot of those flaws got fixed :)
TrekkieGrrrl ( ) posted Thu, 09 February 2006 at 4:15 AM · edited Thu, 09 February 2006 at 4:16 AM
Was one of your lights a point light by any chance? In my expirience, point lights and reflection/refraction doesn't play well together. I have a pair of glasses where I HAVE to remember to alter the glass settings if I have a point light in the scene, or the renderer simply stops once it encounters them...
Message edited on: 02/09/2006 04:16
templargfx ( ) posted Thu, 09 February 2006 at 4:42 AM
3 reflections? theres your issue. ok, heres whats going on as far as I can tell. you have transperant reflecting surfaces in the eye materials, perhaps a refract node too (if you do, Im suprised you got as far as you did with the eyes in 8 hours!!) heres a tip -> if you want BOTH reflect AND refract, use the FRESNAL node (P6 only) instead, as it does both.
TemplarGFX
3D Hobbyist since 1996
I use poser native units
167 Car Materials for Poser
richardson ( ) posted Thu, 09 February 2006 at 7:55 AM
Along with post13, You really only have 2 reflective surfaces; eyewhite and cornea. If you have reflect on iris and pupil also, you'll get a "bounce" war infinitum between all the reflective surfaces. Iris>Cornea>iris>cornea...x5. Cornea>bg(something to reflect)>cornea>camera..x5 Pupil>Cornea,,,,,,just guessing with info but, I see something on the pupil.
gmadone ( ) posted Thu, 09 February 2006 at 8:38 AM
It sounds like the memory bug. When it finishes be sure to do a reboot.
operaguy ( ) posted Thu, 09 February 2006 at 9:50 AM
I agree about reboot, sadly. When I am in the middle of sucessive test renders, I sometimes get out-of-memory failure, even though I just rendered nearly the same thing 5 times. There IS some sort of memory release deterioration. And: IT IS NOT always enough to quit Poser and come back in; in extreme cases, you have to reboot the computer. ::::: Opera :::::
operaguy ( ) posted Thu, 09 February 2006 at 9:56 AM
Here is another image in my sequence, if only to show that a reflect node does NOT have to grind render to a halt. There is a reflect node in both eyes. Per advice of face_off, I do not use infinite or point lights in shadow map work like this, only spot lights. There are three spot lights on the face, two generating shadows. Render time: 552 seconds, less than 10 minutes at 720x540 ::::: Opera :::::
anxcon ( ) posted Thu, 09 February 2006 at 11:35 AM
about the reflect in iris, i knew there be a reflect war was testing an idea :P opera, pretty eyes, but i'm more of a green or blue person hehe :) one of the effects i was testing, take a spec node, set for slightly larger than the cornea, and allow it drives ambient value then ambient color is the texture map used on the iris the iris "glows" a bit where light hits it if i can get the sightings right, it is a quality that real eyes have some more than others, my ex gf had eyes that glowed :P
mikachan ( ) posted Thu, 09 February 2006 at 1:44 PM
anxcon, if you get that last bit figures out, please please please write a tutorial explaining how you did it!
ghelmer ( ) posted Thu, 09 February 2006 at 1:47 PM
WOW OG!! Your renders look AWESOME!!! I wish I had more patience to dig & figure things out like yourself, Paul & maxxx!!! Fantastic work Opera!! Have you made your mind up about Carrara yet? Gerard
The GR00VY GH0ULIE!
You are pure, you are snow
We are the useless sluts that they mould
Rock n roll is our epiphany
Culture, alienation, boredom and despair
operaguy ( ) posted Thu, 09 February 2006 at 3:40 PM
can't use Carrara for current projects becuase i need dynamic hair, it does not support it, and rendering close in with Carrara with fine hair and skin....no speed gain on render. Also, I found Carrara's animation slider to be WAY sluggish, so Carrara could only be used as a render platform, no animation, dynamic sym, etc. Stickin' with Poser for now. "one of the effects i was testing, take a spec node, set for slightly larger than the cornea, and allow it drives ambient value then ambient color is the texture map used on the iris the iris "glows" a bit where light hits it" Okay, that sounds like something interesting. Please post back if you get it going. I am very interested in making eyes glow under extreme low light. BTW, easy to turn her eyes blue with one click, but she is from Asia, that would not be Orientally Correct. ::::: Opera :::::
mathman ( ) posted Thu, 09 February 2006 at 3:52 PM
bookmark
anxcon ( ) posted Thu, 09 February 2006 at 4:55 PM
this is art though, correct isn't a limit =) and if you want eyes to glow in dim light, sounds more like a diffuse/ambient mix, mine is more of a spec/ambient mix i'll see what i can do about yours after this :)
artnik ( ) posted Thu, 09 February 2006 at 9:50 PM
bookmark
operaguy ( ) posted Thu, 09 February 2006 at 10:24 PM · edited Thu, 09 February 2006 at 10:24 PM
i can make eyes glow in the dark, yes, with ambient, but that is primitive. Really what I want is to see the glint of reflection in a character's eye, and some indication of liquid, as the head/eye moves in animation, while the character sits in deep shadow. Not pure dark, but quite dark.
::::: Opera :::::
Message edited on: 02/09/2006 22:24
anxcon ( ) posted Thu, 09 February 2006 at 11:54 PM
i got the eye glow that i wanted, kinda, not much time for poser >.< as for the darkness look, working on it now will try n post it before bed or in morning if i can find anything :) sleeping sucks....waste of time.... if a beautiful girl then ok i can see a value in it (sorry lol) but just plain sleep is a waste of time ;/ its a damn 1/3 of a life! i could take over the world in that time.....
anxcon ( ) posted Fri, 10 February 2006 at 12:12 AM
just a thought, since reflect on the iris makes a nice look and doing so, makes "reflect wars", could render iris/cornea alone, and layer in a paint program, i'm sure not insanely hard to make a plugin or something to do batches of frames thats assuming no movie editor to be found to do it :P it's similiar to something i've been considering to do between carrara and poser, which is render the scenes/people then a 2nd render for the hair only, whether carrara or poser just a wildly random thought i had lol
anxcon ( ) posted Fri, 10 February 2006 at 12:30 AM
the pic in post 26 had 1 spotlight at 100% (all white) this had the spotlight lowered to 30%, pretty dark the way i set my material made the iris change from diffuse to ambient gradually as light got dimmer, to add a slight overall glow to it, but the brighter area on the iris is from the reflect node added in (which fades out as light brightens, and changes more to my above glow) just the eye part i did, took 10 min to render about should drop more though if you dont zoom in :P
anxcon ( ) posted Fri, 10 February 2006 at 12:31 AM
sleepy time, let me know what ya think, and i shall return ^_^
operaguy ( ) posted Fri, 10 February 2006 at 12:35 AM
I will be fooling with this idea over the weekend anxcon, thanks for your effort, your thread here gives me direction. Will post results when I start experimenting. ::::: Opera :::::
Tucan-Tiki ( ) posted Fri, 10 February 2006 at 12:58 AM
8 hours wow should only take an hour at most I would think....try turning off ray tracing, you really dont need it unless your doing reflections.
anxcon ( ) posted Fri, 10 February 2006 at 2:04 AM
i resent that, i haven't turned off raytrace in 9 months and i never will! mwuhahaha, and yes there are reflections
operaguy ( ) posted Fri, 10 February 2006 at 2:24 AM
per my post 4 above.....is the hair invisible to raytrace?
anxcon ( ) posted Fri, 10 February 2006 at 11:52 AM
forgot to give you the mats if you want to play with em i'll still be playing with other ways to do it for a bit this is just the left iris/eyewhite/cornea, rename to .mc6 let me know if you find anything interesting :) i'm pretty much just screwing off, trying to get effects and seeing what i can get, before putting into my animation since what is shown in a story, depends what can be done :)
Latexluv ( ) posted Fri, 10 February 2006 at 12:29 PM
I was experimenting with the gather node. Duh, decided to do a reflective floor. BIG mistake. Great pic, but it took 12 hours in P6 to render. In P5 it would have taken a couple of hours maybe. Of course, no gather node in P5. I am not sure why P6 takes so much longer.
Weapons of choice:
operaguy ( ) posted Fri, 10 February 2006 at 12:59 PM
"I am not sure why P6 takes so much longer" You answered your own question. If the gather node were available and engaged in P5, do you have any objective, factual reason to believe it would have executed this render faster than P6 did? As to the 12 hours. First, do you have any light on in this scene? ::::: Opera :::::
Latexluv ( ) posted Fri, 10 February 2006 at 1:16 PM
Yes, I have lights and I just decided to check my shader. I was using as my base the mirror shader from the Magic Mirror package in the Market place (Shadowdale, I believe). Reflect on that is set to 1.00. When you just bring in a reflect at first, it is set at .2000. Which probably would have done better speed wise if I'd checked it before hitting the render button. I was just reading some materials on the gather node and thought, wouldn't it be nice to try that and have the floor reflective too. I haven't messed with P6 much, so I had a duh moment. I was just messing with my custom water material and took out my reflect and refract and added fresnel as suggested somewhere up there and tried a render. Live and learn.
Weapons of choice:
operaguy ( ) posted Fri, 10 February 2006 at 1:21 PM
my point is, with raytrace going like mad in your render, how do you know it is the reflect node, or even the gather node, that is the culprit in the 12 hours? Maybe it's the fact that raytrace on hair and skin is expensive. ::::: Opera :::::
Latexluv ( ) posted Fri, 10 February 2006 at 1:28 PM
Hmmm, maybe when it comes to the reflection of the woman in the floor. The upper part of the picture, the girl and the glow ball, rendered in fairly quickly. I started the render at 10:15AM. The render hit the floor region of the image at 10:39AM, and took until 10:42PM that night to complete the bottom of the image. It's a test image, so I can always try it again, adjusting the reflect value and see if I get a 'forever' render again. It could be the gather added to the reflect on the floor (I didn't expect to get any 'gathering' of light from the female at all that surprised me.) Or it could be I need a new laptop, this one is two years old, and it has a hard time with some of the things I want to try in P6 (like IBL with AO, that took 6 hours on a render).
Weapons of choice:
Latexluv ( ) posted Fri, 10 February 2006 at 2:07 PM
Hmmm, interestingly enough, this one only took 35 minutes. I adjusted my water mat from P5, using fresnel instead of separate reflect and refract. I added a gather to the alternate diffuse. I rendered with settings like the picture last night and it only took 35 minutes. Of course, there isn't a human figure in this as well.
Weapons of choice:
operaguy ( ) posted Fri, 10 February 2006 at 5:57 PM
anxcon,
many pressing needs have kept me for working with your glow-in-the-dark shader, i'll try to get to it this weekend. Meanwhile, this is my setup for eyes for the image in post 17 above.
Three white boxes with ambiant at 1.0 placed in front of model.
::::: Opera :::::
