Wed, Feb 12, 9:06 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Feb 12 7:20 pm)
Carrara Free Stuff here.
Subject: Cararra Pro 5.04 P6 scenes and transparancy issues! HELP?!?!?!!
ghelmer ( ) posted Sun, 19 February 2006 at 11:18 AM · edited Wed, 12 February 2025 at 8:48 PM
Hello, this seems to have only started since I installed the 5.04 update... is there any wat to fix it without trying to rollback to 5.03??? I've tried numerous times messing with the settings on the scalp (or base depending on the hair model) and the eyelashes but no success! I'm rather new to Carrara but not 3D proggies so I'm not a complete noob but I cannot figure this one out... I've tried everything thing I could think of but perhaps it's a bug in 5.04 that kills Poser trans maps! I dunno!! Sorry for the big boobedness in the pic... trying Posermatics Miki morphs... :) Any ideas & input would be awesome!!!!! Gerard
The GR00VY GH0ULIE!
You are pure, you are snow
We are the useless sluts that they mould
Rock n roll is our epiphany
Culture, alienation, boredom and despair
ghelmer ( ) posted Sun, 19 February 2006 at 11:21 AM · edited Sun, 19 February 2006 at 11:21 AM
To clarify... this has been happening on V3 and Aiko 3 as well and it's not just a Miki thing... OT I quite like Miki! She's so fine, she's so fine she blows my mind, HEY MIKI! HEY MIKI!! LOL!! Sorry! I'm stuck in the 80's!!
G
Message edited on: 02/19/2006 11:21
The GR00VY GH0ULIE!
jt411 ( ) posted Sun, 19 February 2006 at 11:56 AM
Did you have the "Light through transparency" button checked in your render options? (Why did you make her boobs so small?)
ren_mem ( ) posted Sun, 19 February 2006 at 2:25 PM
LoL, omg. 2 things, Must have alpha maps in the channels, then must have both options for light thru trans turned on, if you are using GI.(Both are in render room, one at the top and 1 under GI area below.)
No need to think outside the box....
    Just make it invisible.
brycetech ( ) posted Sun, 19 February 2006 at 7:54 PM
unless you draw arrows (like in the pict)..no one would look at her head anyhow... lol
ghelmer ( ) posted Mon, 20 February 2006 at 8:55 AM
>>>>>>>>ren_mem: "must have both options for light thru trans turned on" That's all it was!! Just ticked the second one and it was fine! Thanks all for helping! Guess I need to read the manual!! G
The GR00VY GH0ULIE!
ren_mem ( ) posted Mon, 20 February 2006 at 12:22 PM
The manual helps, however, I doubt it is updated properly...this has been a small issue. It does have some poser tips in transposer.pdf and I think the other one. The change in 5.03 added this as part of the GI transparency issues that had been happening, then they corrected the overlighting in 5.04 When you don't use GI you obviously don't need the GI option (it will be greyed out).
charlesb ( ) posted Fri, 24 February 2006 at 12:29 PM
Yes we added the "Light through Transparency" option for the GI in 5.0.3. The reason is that we had fix the alpha channel for the GI and that in some cases it can lead to extremely long rendering time without any real benefit. (Try rendering trees with Alpha masked leaves and global illumination, each rays for indirect lighting can go through thousands of leaves...) So I decided to turn it off by default to keep the fast rendering.
bluetone ( ) posted Mon, 27 February 2006 at 6:04 PM
Thanx Charles! :D Now... can you fix the problem with the second pic? Seems to fade out right below the clavical for some reason.... ;)
charlesb ( ) posted Mon, 27 February 2006 at 6:19 PM
I don't think that's a bug, it is probably just a lighting issue...
