Carrara F.A.Q (Last Updated: 2025 Feb 13 6:48 pm)
To clarify... this has been happening on V3 and Aiko 3 as well and it's not just a Miki thing... OT I quite like Miki! She's so fine, she's so fine she blows my mind, HEY MIKI! HEY MIKI!! LOL!! Sorry! I'm stuck in the 80's!!
G
Message edited on: 02/19/2006 11:21
The GR00VY GH0ULIE!
You are pure, you are snow
We are the useless sluts that they mould
Rock n roll is our epiphany
Culture, alienation, boredom and despair
The GR00VY GH0ULIE!
The manual helps, however, I doubt it is updated properly...this has been a small issue. It does have some poser tips in transposer.pdf and I think the other one. The change in 5.03 added this as part of the GI transparency issues that had been happening, then they corrected the overlighting in 5.04 When you don't use GI you obviously don't need the GI option (it will be greyed out).
No need to think outside the box....
Just make it
invisible.
Yes we added the "Light through Transparency" option for the GI in 5.0.3. The reason is that we had fix the alpha channel for the GI and that in some cases it can lead to extremely long rendering time without any real benefit. (Try rendering trees with Alpha masked leaves and global illumination, each rays for indirect lighting can go through thousands of leaves...) So I decided to turn it off by default to keep the fast rendering.
![file_327630.jpg](https://live.cdn.renderosity.com/forum/threads/2589358/file_327630.jpg)
Hello, this seems to have only started since I installed the 5.04 update... is there any wat to fix it without trying to rollback to 5.03??? I've tried numerous times messing with the settings on the scalp (or base depending on the hair model) and the eyelashes but no success! I'm rather new to Carrara but not 3D proggies so I'm not a complete noob but I cannot figure this one out... I've tried everything thing I could think of but perhaps it's a bug in 5.04 that kills Poser trans maps! I dunno!! Sorry for the big boobedness in the pic... trying Posermatics Miki morphs... :) Any ideas & input would be awesome!!!!! GerardThe GR00VY GH0ULIE!
