DAZ|Studio F.A.Q (Last Updated: 2025 Feb 12 6:12 pm)
DAZ Studio have different animations method than anothers . I suggest you to learn pupeteer
in http://forum.daz3d.com/viewtopic.php?t=68689&highlight=pupeteer
I dont know about Blender, but if Blender supported by collada plugins , you should with easy load any items from DAZ Studio to Blender . Im using Max and this plugins sucsessful imported figures , skeleton weightmap and morph too , even animation
Try this link colladablender.illusoft.com/cms/ or check in http://www.feelingsoftware.com/ ( you should register first) , maybe they have blender versions ( i`ve got free Max version from this site )
I hope this reply help u
If you import the model into Blender using .obj format they will lose all rigging (posing ability). Furthermore they won't have any of their morphs. The collada format is an attempt at creating a universal import/export function that can maintain rigging, morphing, et al between 3D apps. But Poser rigging is so different from any other used that it doesn't convert well. DAZ sells Carrara (spelling?) that is supposed to be able use Poser content, but from what other have said in several forums, it doesn't seem to work at the moment. Your best options are either learn Puppeteer as already been suggested, or consider getting Poser.
Quote - DAZ Studio have different animations method than anothers . I suggest you to learn pupeteer
in http://forum.daz3d.com/viewtopic.php?t=68689&highlight=pupeteerI dont know about Blender, but if Blender supported by collada plugins , you should with easy load any items from DAZ Studio to Blender . Im using Max and this plugins sucsessful imported figures , skeleton weightmap and morph too , even animation
Hi i dloaded colladafree,cg beta toolkit but i couldnt import dazmodel into max9. Can you give more details about your success? thnx
I had simmiliar issue before , but it solved after ive download Collada Max free 3.05 . Not cg beta toolkit . Sorry ...but i dont have Max 9 ,so i can figure it out . but this route work well in 7th or 2008 version . Since 2008 similiar with 9th .. i thinks it should work too , but tell me if doesn
t work , ok?
Thanks
Try this link downloads.sourceforge.net/colladamaya/ColladaMax_FREE_3.05B.exe
Sorry i dont have armaseda hair so i cant figure it out what make hair doesn
t show up .
No need to put bones on figures ( except you want different rig system ) because colada format had already bring it . If you`ve animate in Poser or DAZ it should loaded too .
BTW in 3dsmax you can fix or add animate with rotate or move those bones and maybe some modifier ..
maybe it looks very limited for you , but i think this easy ( and free ..? ) way to bring poser figures to 3ds max with entirely bone system and weightmap
If you want different rigging sytem or you not satisfied with poser type rig you can manually adjust . But remember its not simple and easy way .
Using biped had same issues too . I dont recommended change any bones thing unless you had good or excellent knowledge about rig system , skinning , IK or envelopes in 3dmax
Look at this attachment , had you already check it ?
I dont know about Max 9 issues , but ive read in somewhere ( sorry i
m forget where ) . Max 9 have different animation method from Max 7. Maybe it cause you couldn`t import animation from DAZ . You can visit and ask 3dsMax forum for sure or maybe ask people at DAZ
Thanks
hi,newbie here. can someone direct me to a tutorial on how to animate my figures in DAZ,also can i use my figures from DAZ in blender? or what other compatable program does DAZ play well with? thanks much,sorry if this has been asked, but i searched the forum and came up with zilch,so i decided to ask.
