Sat, Feb 8, 11:24 PM CST
Subject: Slightly OT: Running Poser On a Laptop
mathman ( ) posted Wed, 13 January 2010 at 2:49 PM · edited Sat, 08 February 2025 at 11:22 PM
Hi,
Was wondering if people out there use a laptop to run Poser (...and other 3D apps for that matter) ?
The reason I am asking is because I am considering purchasing a laptop and wondered if Poser slows down performance-wise on a laptop ? ... Laptops have integrated graphics, correct ? .. I have heard that this is a performance drawback.
I welcome your feedback.
Thanks and regards,
Andrew
mathman ( ) posted Wed, 13 January 2010 at 2:51 PM · edited Wed, 13 January 2010 at 2:51 PM
....Oh, and its a widescreen that I am considering.
bagginsbill ( ) posted Wed, 13 January 2010 at 3:14 PM
Works fine on my Dell D830 which is old.
SamTherapy ( ) posted Wed, 13 January 2010 at 3:40 PM
Considering most modern laptops wazz all over my Poser desktop machine, I can't see a problem.
Nance ( ) posted Wed, 13 January 2010 at 3:45 PM
Haven't looked into it myself, but now you've got my curiosity up.  What's the max screen resolution that is available on typical widescreen laptops nowdays?
(clinging tightly to a dual 19" monitor setup)
bagginsbill ( ) posted Wed, 13 January 2010 at 4:19 PM
If you only shop at Best Buy, you won't find any more than 1440x900 (considered Premium). For example, there is an Alienware Premium 17" with that resolution (and a crazy price - $2299.99).
However, if you shop elsewhere, particularly for laptops that are basically software development workstations, you'll find 1920x1200. That's what I have. Look for WUXGA - that's 1920x1200.
mathman ( ) posted Wed, 13 January 2010 at 4:36 PM
Quote - Considering most modern laptops wazz all over my Poser desktop machine, I can't see a problem.
What is this translated into English ?
SamTherapy ( ) posted Wed, 13 January 2010 at 4:49 PM
Quote - > Quote - Considering most modern laptops wazz all over my Poser desktop machine, I can't see a problem.
That is English.  :P  :biggrin:
Nance ( ) posted Wed, 13 January 2010 at 5:36 PM
Thanks for the display info BBill.
markschum ( ) posted Wed, 13 January 2010 at 5:48 PM
My Laptop was a $500 special from walmart, a Toshiba. dual core processor, 3gb memory , 250 gb hard drive , dvd . It works great with poser, better than my old laptop.
rjjack ( ) posted Wed, 13 January 2010 at 5:48 PM
i have run Poser 5, 6, 7, Pro and 8 on various laptops since 2005 in fact i don't  know if Poser run on a desktop ;-)
like BB said try to get a 17 inch 1900x1200 screen, my advice is to don't get anything less than a 15 inch 1680x1050, tried once Poser 8 on a 1440x900 but i have to undock many elements to get some room to work
i don't know how poser work  with the integrated graphics, i buy only laptops with a dedicaced graphics card and video memory, Modo and C4D feel better with a good gfx card
drewradley ( ) posted Wed, 13 January 2010 at 5:59 PM · edited Wed, 13 January 2010 at 6:04 PM
Quote - > Quote - > Quote - Considering most modern laptops wazz all over my Poser desktop machine, I can't see a problem.
Except for the verb which more or less makes your entire sentence nonsensical. I have a laptop and I have never seen it wazz my desktop. Of course, I have no idea what that means, so maybe I missed it. It sounds dirty.
I can, however, run Poser 7 with no real problems. It's a Dell Inspirion I1520 (or something). It has an integrated graphics card. I think it's about 2 years old (probably a bit less). OpenGL preview doesn't always work and SreeD has strange things happen, such as characters' (in the distance) clothing appears shredded. It has no effect other than in the preview mode. I also get a lot more of the "infinite poly" (when a mesh has a poly that appears to go off into inifinty but doesn't really, if you've seen it, you know what I mean). Other than that, I take my laptop with me everywhere and set up some pretty serious scenes.  I never use it for rendering more than three figures though as I will get the "not enough memory to load texture or babd texture" error.
Now Playing
My Insomnia Presents
Blue Defender
Acadia ( ) posted Wed, 13 January 2010 at 6:07 PM
I used to run Poser on a laptop.  The only problem that I really had was lack of storage space. My hard drive was only 40 gigs.  Also, I found that I couldn't render large scenes and often had to reduce the texture sizes in my graphic program so that the longest side was no more than 1024 pixels on the longest side.  I also found that I had to hide things and render in bits and pieces and piece it all together in my graphic program.
Maybe a newer, more powerful computer would work better.
replicand ( ) posted Wed, 13 January 2010 at 6:46 PM
 No problems running Poser, Maya or Vue on a Macbook Pro. I second the advice to stay away from integrated graphics. It will cause more headaches that the $200 you save will be worth.
mathman ( ) posted Wed, 13 January 2010 at 7:30 PM · edited Wed, 13 January 2010 at 7:34 PM
'Wazz' is not English. I have no idea what you are talking about ?
mathman ( ) posted Wed, 13 January 2010 at 7:35 PM · edited Wed, 13 January 2010 at 7:35 PM
Quote - I can, however, run Poser 7 with no real problems. It's a Dell Inspirion I1520 (or something). It has an integrated graphics card. I think it's about 2 years old (probably a bit less). OpenGL preview doesn't always work and SreeD has strange things happen, such as characters' (in the distance) clothing appears shredded. It has no effect other than in the preview mode. I also get a lot more of the "infinite poly" (when a mesh has a poly that appears to go off into inifinty but doesn't really, if you've seen it, you know what I mean). Other than that, I take my laptop with me everywhere and set up some pretty serious scenes.  I never use it for rendering more than three figures though as I will get the "not enough memory to load texture or babd texture" error.
drewradley, what are the specs of your Dell Inspiron ?
wheatpenny ( ) posted Wed, 13 January 2010 at 7:59 PM
Site Admin
I run P7 on a compaq Presario CQ60 laptop, 2 GB ram with no problems.
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
LaurieA ( ) posted Wed, 13 January 2010 at 9:12 PM
Grow a sense of humor folks. He was just saying it beats his desktop...
Khai-J-Bach ( ) posted Wed, 13 January 2010 at 9:13 PM
to Wazz. :
to take a leak. to water the daisies. to syphon the python. to pee. English slang term.
ergo : "Considering most modern laptops wazz all over my Poser desktop machine, I can't see a problem. " is "Considering most modern laptops pee all over my Poser desktop machine, I can't see a problem. "
you guys don't have slang terms where you are?
bagginsbill ( ) posted Wed, 13 January 2010 at 10:25 PM · edited Wed, 13 January 2010 at 10:26 PM
And also do these guys not have Google? Took me all of ten seconds to find it.
UK Slang - W
http://www.peevish.co.uk/slang/w.htm
Open that page and you'll find wazz. Apparently it has a couple other meanings. So I could say:
Wazz over to Google and when you find what wazz means, wazz the link over to me. I'd do it myself but I have to wazz real bad.
drewradley ( ) posted Wed, 13 January 2010 at 11:18 PM
Dell Inspiron I1520, Intel core 2 duo, T8300 @ 2.40GHz, 3.5 gigs ram.
Mobile Intel 965 Express Chipset video.
If I had to do all over again, I would have saved another couple months and bought one with a dedicated video card.
Now Playing
Blue Defender
seachnasaigh ( ) posted Thu, 14 January 2010 at 12:31 AM · edited Thu, 14 January 2010 at 12:38 AM
     Laptops are limited in capacity, but as long as you get/have something reasonably well equipped, it'll do fine.  Dual core would be nice;  RAM would be most important to me;  budget permitting, get the max the chassis/OS will take, usually 4Gb for 32bit OS, or 8Gb for 64bit.
    You certainly can get a dedicated video card in a laptop;  I'd get a OpenGL compliant video card, rather than rely on "on-board" video.
I like those 1920x1200 pixel screens because they have lots of workspace for control panels. :D
aeilkema ( ) posted Thu, 14 January 2010 at 3:06 AM
No problem running Poser or other 3D apps on a laptop. My setup is a Intel Core2Duo 2.4Ghz, 4Gb Ram (3.5Gb usable in Windows), ATI HD4330 256Mb, 300Gb Hard Drive. Came with Vista 32bit, but I replaced that with WinXP, runs much smoother. I've got a 15,6" widescreen, I used to have a regular 17", but I do not miss the size difference at all. The widescreen is wider, but less high, but I do not miss the height at all. I do find that the extra width is much more pleasant and usefull then extra height.
It handles everything well, Poser runs great, everything is fast and responsive. Rendering goes pretty fast. I also use Vue, Bryce and TrueSpace (to model), no problems there.
Just make sure you get one with a dedicated video card, it's a must, the integrated gfx are not that good. I also would recommend considering a quadcore, in the long run it will be worth spending the extra money for that.
Food for thought.....
EnglishBob ( ) posted Thu, 14 January 2010 at 8:40 AM
 I'm now happily using an HP ProBook 4710s (2.1GHz core duo, 2GB RAM, XP Pro) which is a great improvement over my last machine - but then it would be. I'm too embarrassed to post the specs of its predecessor. :)
The only thing I would change if I could is the display - at 1600 x 900, it has plenty of pixels, but a 4:3 screen or even a portrait monitor would be better for much of what I do. Widescreen is good for music and audio editing, which tends to work horizontally, and for watching videos (which I hardly ever do anyway); but for documents and for Poser work with standing figures, it's limiting.
ratscloset ( ) posted Thu, 14 January 2010 at 10:06 AM
The only issue some users may encounter with Laptops has to do with support of OpenGL with some of the Video Chipsets used... nVidia are ususally good, Intel Drivers seem to only come from the Laptop Manufacturer... if it is a new Chipset you are normally okay, but if it is an older one, you may find the Driver has no updates. I am not real familiar personally with ATI, but I also do not see to many issues reported with the ATI Mobility Chipsets, so I suspect they are okay. You can run Preview in SreeD, so it is not something that will prevent you from running Poser on a Laptop.
ratscloset
aka John
gagnonrich ( ) posted Thu, 14 January 2010 at 4:08 PM
I've even run Poser on a netbook, so a laptop should not be an issue. Screen size is pitiful, so it would have to be hooked up to an external monitor. I haven't rendered anything of significance on it, but it ought to be slow compared to a regular laptop or desktop. The netbook does have a very spacious 160gb hard drive. It's not my computer of choice for doing Poser renders, but it's great for laying out stuff and playing around with Poser content when I'm away from home.
My visual indexes of Poser content are at http://www.sharecg.com/pf/rgagnon
mathman ( ) posted Thu, 14 January 2010 at 5:58 PM
On a netbook ? ... wait until I pick up my jaw from the floor ! .... what RAM and what clock speed ? .... is it easy to hook up a big monitor to it ? .... alt, could you render an image larger than the netbook's screen size ?
seachnasaigh ( ) posted Thu, 14 January 2010 at 7:06 PM
Don't get too excited by the prospect of running Poser on a netbook.  While you could run the UI and do scene setup, you would be very limited in rendering, in terms of scene complexity, quality settings, and pixel dimensions.
Plutom ( ) posted Thu, 14 January 2010 at 7:36 PM
Just don''t purchase a laptop mounting device that  connects to your car's steering wheel.  There is a good chance that it will disable Poser if not used correctly.  Jan
Faery_Light ( ) posted Sat, 16 January 2010 at 9:43 PM
I have the same type of Laptop as wheatpenny, a compaq Presario CQ60 laptop, 3 GB ram,  and it runs Poser good.
Only problem is the disk  space for me as I have a very large runtime and only 260GB disk.
So I only put what I'm working on currently on it and keep all else on a removable drive with a1TB disk.
Screen resolution is 1366X768
