Tue, Nov 19, 8:34 AM CST
Subject: The LuxPose Project - Alpha Stage
Latexluv ( ) posted Thu, 23 September 2010 at 11:25 PM
Quote - Ok, last render of the car ;o). If I do anymore, it'll have more stuff in the scene..hehe.
This is my favorite color yet. And I posted the recipe for this one on the wiki.
Love the color! I copied the information. Last night I added the two black car shaders you gave me.
Weapons of choice:
LaurieA ( ) posted Fri, 24 September 2010 at 7:33 AM · edited Fri, 24 September 2010 at 7:45 AM
Quote - Looks really good.  Since no one reads the general question topic, I'll have to ask here.
I have 2 questions:
1.  I was under the impression that distant lights were converted to sun.  If so, does it have to be a special name?  I tried, and it didn't convert; but i didn't try all combinations of sun names.
2.  With the editing of materials, I looked at the wiki and I am somewhat confused.  It says:
Please pay special attention to material names as you will need to replace "YourMaterialNameHere" with the name of your material.
Does that mean there are only certain materials that can be used, or does it mean we can name it anything we want as long as it is unique?   I guess it would help me to see the syntax of a sample material, along with a working example.
Thanks!
As to question 1, I'm not sure the exporter does convert distant lights to sun as of yet. I think BB is working on materials and lighting and he's been crazy busy this month with paid work ;o).
As to question 2, the name you need to insert into "YourMaterialNameHere" is the name of your geometry, for example, here is the entire code line for the material for Bazze's car's body material with my changes:
#----->   MuscleCar/Body    <-----
MakeNamedMaterial "MuscleCar/Body" "string type" ["glossy"]
"color Kd" [0.1 0.0 0.50]
"color Ks" [0.5 0.0 0.7]
"color Ka" [0.43 0.48 0.22]
"float uroughness" [-0.005]
"float vroughness" [0.005]
"float d" [0.4]
"float index" [2.0]
The first line is the geometry that the material will be applied to. That is what you have to name your MakeNamedMaterial. So in this case, it's "MuscleCar/Body" but you can apply it to "V4Bodysuit" or whatever you want as long as you replace the line "YourMaterialNameHere" with whatever the geometry name is from the line with ----->  <-----. Keep the main geometry line and don't change that - only change what's underneath, starting with MakeNamedMaterial :o).
Now, if you're doing a material mix, the first two materials in the mix that you are trying to describe must have the geometry name, plus something you denote as that particular material. Let's say I were mixing the car paint and a glass for the body. I'd do it like this:
MakeNamedMaterial "MuscleCar/Body/glossy" "string type" ["glossy"]
"float d" [0.4]
"float index" [2.0]
MakeNamedMaterial "MuscleCar/Body/glass" "string type" ["glass"]
"color Kr" [1.0 1.0 1.0]
"color Kt" [1.0 1.0 1.0]
"float index" [1.52]
MakeNamedMaterial "MuscleCar/Body" "string type" ["mix"]
"string namedmaterial1" ["MuscleCar/Body/glossy"]
"string namedmaterial2" ["MuscleCar/Body/glass"]
"float amount" [0.30]
Since the mix is the material result, that's the one that has to carry the geometry name. Hope that made sense.
LaurieA ( ) posted Fri, 24 September 2010 at 7:49 AM · edited Fri, 24 September 2010 at 7:51 AM
For what it's worth, I find Poser shaders to be terribly complicated and Luxrender's materials much less so, probably because there's much less to them ;o). Having said that, the procedural textures codes and things within Luxrender still befuddle me a bit, but no more than Poser shaders have in the past...lol. I'd love to start adding procedural bump and other things to textures now, but I have to get straight on how they're used first.
rjjack ( ) posted Fri, 24 September 2010 at 7:59 AM
yes if you set the following parameter in dataOut.BBml, the name is not important, the light will be named "sun",
Light
  sunsky
    enabled=true
LaurieA ( ) posted Fri, 24 September 2010 at 8:03 AM
Quote - > Quote -
Light
  sunsky
    enabled=true
Yes, it does do that, but what I'm not sure of yet is whether or not it's truly acting as a Luxrender sun or sunsky ;o).
rjjack ( ) posted Fri, 24 September 2010 at 8:44 AM
they are converted to a sun but the sun alone give a black image, if you use sky or sunsky they are working.
below some lights, sun sky and sunsky in separated groupes so you can experiment, gain must be around 0.01
start lights
LightGroup "sun"
start light "sun"
AttributeBegin
LightGroup "sun"
LightSource "sun"
 "vector sundir" [-0.0 -0.550000011921 -0.0]
AttributeEnd
end light "sun"
LightGroup "sky"
start light "sky"
AttributeBegin
LightGroup "sky"
LightSource "sky"
 "float aconst" [0.5]
 "float bconst" [0.5]
 "float cconst" [1.0]
 "float dconst" [1.0]
 "float econst" [1.0]
 "float turbidity" [2]
AttributeEnd
end light "sky"
LightGroup "sunsky"
start light "sunsky"
AttributeBegin
LightGroup "sunsky"
LightSource "sunsky"
AttributeEnd
end light "sunsky"
end lights
adp001 ( ) posted Fri, 24 September 2010 at 9:22 AM
Quote - they are converted to a sun but the sun alone give a black image, if you use sky or sunsky they are working.
start lights
LightGroup "sun"
start light "sun"
AttributeBegin
LightGroup "sun"
LightSource "sun"
AttributeEnd
end light "sun"
LightGroup "sky"
start light "sky"
AttributeBegin
LightGroup "sky"
LightSource "sky"
AttributeEnd
end light "sky"
LightGroup "sunsky"
AttributeBegin
LightGroup "sunsky"
AttributeEnd
end light "sunsky"
end lights
There is no "gain" with the sun yet. It's a part I'm playing with. Will be ready later this evening. Along with "IBL" and/or environmental-light (skyglob replacement).
adp001 ( ) posted Fri, 24 September 2010 at 9:24 AM
LightGroup "sunsky"
AttributeBegin
LightGroup "sunsky"
AttributeEnd
end light "sunsky"
end lights
Whatever I do, I get a ignore message in the Log for each of the parameters aconst to econst. But the parameters are definitively used.
rjjack ( ) posted Fri, 24 September 2010 at 9:30 AM
gain in the Luxrender light panel, if you leave it to 1 for the sky or sunsky you get a white picture with few black spots
no waning on my side for the parameters, i use 0.8 dev
the pic is a render with the sky only
ayanematrix ( ) posted Fri, 24 September 2010 at 11:39 AM
Quote - For what it's worth, I find Poser shaders to be terribly complicated and Luxrender's materials much less so, probably because there's much less to them ;o). Having said that, the procedural textures codes and things within Luxrender still befuddle me a bit, but no more than Poser shaders have in the past...lol. I'd love to start adding procedural bump and other things to textures now, but I have to get straight on how they're used first.
Well, some of the material examples I've posted to the wiki already procedural bump mapping setup, but it's not quite as easy to implement by hand for Poser ready objects. In my experience, the scaling for majority of them needs to be fairly small to match the model, otherwise you would never see the intended effect. 😕 Also, since some of the code used to generate the procedural textures has been ported from Gimp, they don't exactly match the ones used in Blender, at least visually anyway. I could be wrong on this though as the Lux team has been pretty busy as of late.
In either case, all you'd have to do is experiment once you know what you look for. 😉
Latexluv ( ) posted Fri, 24 September 2010 at 7:16 PM
LaurieA,
When you get a chance, could you check the additions I made to the Material Wiki under the glass and Carpaint sections and make sure I put it all in correctly?
P.S.
Watching Lux render a scene is about as exciting as watching paint dry.
Weapons of choice:
LaurieA ( ) posted Fri, 24 September 2010 at 7:23 PM
Quote - LaurieA,
P.S.
They look fine.
I prefer watching golf myself. So amazingly snooze-making. Given a choice, I'll take the paint ;o).
Latexluv ( ) posted Fri, 24 September 2010 at 7:50 PM
I'm determined to render a wineglass in Lux and get it to look right. I'm on my fourth attempt right now. You think the developers will work in some code that might speed this renderer up some?
Weapons of choice:
rty ( ) posted Fri, 24 September 2010 at 8:44 PM
Quote - Whatever I do, I get a ignore message in the Log for each of the parameters aconst to econst. But the parameters are definitively used.
Yes, as I said several pages ago, don't heed the Lux messages. Those parameters are used, they define the sky colors. If you omit them you get a white sky.
Somebody please add it to the knowledge base, as it is a recurring topic (4th or 5th time I see it). IIRC I had already mentioned it when I first posted the sunsky setting, many weeks ago...
rty ( ) posted Fri, 24 September 2010 at 8:49 PM
Quote - You think the developers will work in some code that might speed this renderer up some?
Unlikely. Not because they don't want, but because you can't have an engine which doesn't take any shortcuts, and still is faster than one which does.
I fear that if we want more speed, we'll have to invest in the appropriate hardware.
Flenser ( ) posted Fri, 24 September 2010 at 9:06 PM
The developers are hard at work to add GPU acceleration for Luxrender 0.8, that should bring a significant speed increase if you have a recent well specced ATI or Nvidia graphics card.
Software: OS X 10.8 - Poser Pro 2012 SR2 - Luxrender 1.0RC3 - Pose2Lux
Hardware: iMac - 3.06 GHz Core2Duo - 12 GB RAM - ATI Radeon HD 4670 - 256 MB
Flenser ( ) posted Fri, 24 September 2010 at 9:19 PM
New render. The only material changes done are the mirror walls and the glass ball. The rest is straight Poser export.
Latexluv ( ) posted Fri, 24 September 2010 at 9:23 PM
Quote - The developers are hard at work to add GPU acceleration for Luxrender 0.8, that should bring a significant speed increase if you have a recent well specced ATI or Nvidia graphics card.
sigh Which I can't at the moment afford to buy a new laptop, even though I really do need one.
Weapons of choice:
ErickL88 ( ) posted Sat, 25 September 2010 at 7:19 AM
I get this, when trying to run the latest (1-23d)  LuxPose script:
Traceback (most recent call last):
  File "H:ProgrammeSmith MicroPoser Pro 2010RuntimePythonposerscriptsLuxPosePoserLuxExporter.py", line 218, in ?
    ExportFilm(globalParameters).write(f)
  File "H:ProgrammeSmith MicroPoser Pro 2010RuntimePythonposerscriptsLuxPoseworkersPoserLuxExporter_workers.py", line 751, in write
    if pFilm.hybrid.strip()=="true":
AttributeError: 'NoneType' object has no attribute 'strip'
Any ideas what it is?
Earlier versions are working perfectly for me.
ayanematrix ( ) posted Sat, 25 September 2010 at 7:46 AM · edited Sat, 25 September 2010 at 7:51 AM
Quote - I get this, when trying to run the latest (1-23d)  LuxPose script:
Current work around until the code is updated is as follows, from rjjack's original post on page 42:
** the error don't show if you add this line in the dataOut.bbml  in the Film part :
hybrid=true **
So, keep in mind that you have run the AIR installer that comes in the pack and edit the file above wherever it ends up being installed. Hope that helps! ^_^
ErickL88 ( ) posted Sat, 25 September 2010 at 7:56 AM
Quote - .... Hope that helps! ^_^
Indeed it did.
Thanks for the help :)
ayanematrix ( ) posted Sat, 25 September 2010 at 8:07 AM
Attached Link: Comparison render from 0.7
I don't know if this is considered cheating, but I ran a test on the updated exporter in Blender for 0.8 of Lux to see if any of the materials I made before rendered okay. For the most part, it seems that the skin shader I made needs tweaking, not to mention that using velvet on near black objects, even with a procedural texture, seems to make the outfit I made, well, black. :rolleyes: Though, it doesn't seem to be much of a problem if there's a texture map underneath as it looks a bit different.
Also, the lighting setup and rendering seems a bit different, if not brighter than normal and almost to the point that it washes out the skin tone. Anyone else notice this? :blink:
ayanematrix ( ) posted Sat, 25 September 2010 at 8:09 AM
Quote - > Quote - .... Hope that helps! ^_^
Indeed it did.
:thumbupboth: Awesome!
wolf359 ( ) posted Sat, 25 September 2010 at 8:13 AM · edited Sat, 25 September 2010 at 8:15 AM
"Unlikely. Not because they don't want, but because you can't have an engine which doesn't take any shortcuts, and still is faster than one which does.
I fear that if we want more speed, we'll have to invest in the appropriate hardware."***
Agreed  you cant beat The "price" of LUX  but other non free
unbiased renderers are much Faster
I stopped this MAXWELL SCENE @ 2 hours
Lit with only mesh lights.
I could have let it resolve more but  oh well
Cheers
My website
LaurieA ( ) posted Sat, 25 September 2010 at 8:43 AM
Give the Luxrender folks some time. I mean, it's not even version 1.0 yet ;o).
adp001 ( ) posted Sat, 25 September 2010 at 9:57 AM
Yes. The parameter "hybrid" isn't defined in your "dataOut.bbml". I missed to check this.
Fixed with the next version.
For the moment, just add the red line to ..AIRLuxPosedatadataOut.bbml ("true" or "false" doesn't matter at the moment). This Parameter will activated GPU-render later. But because some other parameters have to be correctly set to avoid Lux to crash it's not used in this version.
Film
enableStopSPP=true
stopSPP=50
enableStopTime=false
stopTime=600
overrideDimension=false
Dimension
width=600
height=400
saveAs=PNG
displayInterval=10
writeInterval=30
writeChannels=RGB
ToneMapper
kernel=Linear
linearSensitivity=200
linearExposure=.016
linearFStop=8
linearGamma=1
outputpath=.new
poserpath=.
imagepath=.
luxpath=.
filename=""
hybrid=true
Renderer
sampler=Metropolis
pixelSampler=Vegas
integrator=Path
bounces=6
accelerator=KD Tree
lightStrategy=auto
adp001 ( ) posted Sat, 25 September 2010 at 10:01 AM
(Click Image to enlarge)
Is this one good for a photostyle look (beside the hair)?
adp001 ( ) posted Sat, 25 September 2010 at 10:04 AM
I have just to make some small changes to get a version with good light-settings. Sky, sun, sunsky and environtment (last is used in my post above).
LaurieA ( ) posted Sat, 25 September 2010 at 10:17 AM · edited Sat, 25 September 2010 at 10:17 AM
Quote - I have just to make some small changes to get a version with good light-settings. Sky, sun, sunsky and environtment (last is used in my post above).
Quick question, because I haven't been able to find this info yet ;o)...
Can we use an image for sunsky? And how does Luxrender map the sunsky? Is it cube mapped or spherical? I have some nice skies, but most are spherical. Would be nice if I could use em and still have them supply some light ;o).
jancory ( ) posted Sat, 25 September 2010 at 10:43 AM
here's the 'skyglob' recipe i used on this image .  i think it needs rectangular images, not the spherical.  IIRC, bb is working on a way to use the env. sphere, but they need rectangulars also i think.  it'd be nice to be able to use my stash of sphericals as skies.....
start lights
start light "Light 1"
AttributeBegin
LightGroup "Light 1"
LightSource "infinitesample"
 "string mapping" ["latlong"]
 "color L" [1 1 1]
 "float gain" [500]
 "integer nsamples" [1]
 "string mapname" ["path to your hdr"]
end of infinite light 'Himmel-Objekt'
AttributeEnd
start light "Light 2"
AttributeBegin
LightGroup "Light 2"
LightSource "distant"
 "color L" [0.75649095 0.87289506 1] # sun color
 "float gain" [1637.0247]
 "point from" [1.0153754 -3.1502762 3.7476354]
 "point to" [0.81230026 -2.520221 2.9981084]
AttributeEnd
lost in the wilderness
Poser 13, Poser11,  Win7Pro 64, now with 24GB ram
ooh! i guess i can add my new render(only) machine!  Win11, I7, RTX 3060 12GB
 My Freebies
adp001 ( ) posted Sat, 25 September 2010 at 11:39 AM · edited Sat, 25 September 2010 at 11:40 AM
Quote - here's the 'skyglob' recipe i used on this image .  i think it needs rectangular images, not the spherical.  IIRC, bb is working on a way to use the env. sphere, but they need rectangulars also i think.  it'd be nice to be able to use my stash of sphericals as skies.....
start lights
AttributeBegin
 "color L" [1 1 1]
 "float gain" [500]
AttributeEnd
AttributeBegin
AttributeEnd
Seems this is a bit outdated.
Lux manages all types of HDRI now. The parameter "mapping" is not required anymore. Moreover, it forces a specified format.
Here is what I used (HDRI from Posers HDRFX folder):
start lights
LightGroup "IBL"
start light "IBL:HDR IBL"
LightGroup "IBL"
AttributeBegin
 TransformBegin
 Rotate 240 1 1 1
 Rotate 96 0 0 1
  LightSource "infinite"
   "float gain" [3600.0]
   "color L" [1.0 1.0 1.0]
   "string mapname" ["/home/fredi/poser/Runtime/Textures/HDRVFX/HDRVFX_Teen_Bedroom_HDR.hdr"]
 TransformEnd
AttributeEnd
end light "IBL:HDR IBL"
LightGroup "default"
AttributeBegin
LightSource "spot"
   "float gain" [1000.0]
 "point from" [-0.144115999341 0.792566001415 1.10967004299]
 "point to" [-0.01450496912 0.57405886054 0.142480552197]
 "float coneangle" [14.5]
 "float conedeltaangle" [3.0]
AttributeEnd
end light "Light 1"
end lights
The spotlight is only used as a filllight for my special scene and not really required, by the way.
The two Rotations are there for: 1) Rotate the image to a Lux-zero-point, 2) rotate the image to reflect the light rotation (Y) in Poser.
Using the old "skydome" is totally obsolete. Just an overhead on geometries and one has to use something like IBL anyway.
Maybe one want to use a skydome while in Poser just to see how it looks. But don't forget to switch the skydome to invisible before export.
LaurieA ( ) posted Sat, 25 September 2010 at 11:46 AM · edited Sat, 25 September 2010 at 11:55 AM
> Quote - here's the 'skyglob' recipe i used on [ this](http://www.renderosity.com/mod/gallery/index.php?image_id=2103403) image .  i think it needs rectangular images, not the spherical.  IIRC, bb is working on a way to use the env. sphere, but they need rectangulars also i think.  it'd be nice to be able to use my stash of sphericals as skies.....
The type of images BB's envirosphere uses are spherically mapped skies (as too apparently are the HDRFX images in Poser). They are just mapped to a rectangular format, but they are mapped spherically, like the example (which IS a spherical map)
facepalm ;o)
xantor ( ) posted Sat, 25 September 2010 at 11:47 AM
How do you set the angle of the lens in luxrender?  Is the number in the .lxs file the same as camera lens angles or does it use a different scale?
bagginsbill ( ) posted Sat, 25 September 2010 at 11:49 AM
Ironic isn't it?
We want LuxPose to convert Poser point lights to glowing mesh geometry and convert Poser EnvSphere (glowing mesh geometry) into a Lux light. LOL.
The sphere is not obsolete. Lux doesn't have clouds and I have ways to layer things one sphere inside another that you cannot do with lux lights. I have not revealed these things yet, so to current users maybe the env sphere is unnecessary, but it is not without any purposes. All will be revealed eventually. I have to work on things as I do not reveal them half-assed so it will take some time.
Note also that in my experiments of using an environment sphere in Lux, I have seen no performance problem. I don't know why people keep saying that large numbers of mesh lights are an issue - they are clearly not. I have glowing V4's, glowing spheres,  glowing ground planes - literally upwards of 70,000 light sources. It is really not a problem. People should test their assumptions before making claims.
dlfurman ( ) posted Sat, 25 September 2010 at 11:59 AM
Who says LuxRender doesn't do "Toon"-like renders? (Click to see bigger).
LaurieA ( ) posted Sat, 25 September 2010 at 12:00 PM
Quote - Who says LuxRender doesn't do "Toon"-like renders?
No offense intended, but eek!
jancory ( ) posted Sat, 25 September 2010 at 12:14 PM
thanks everyone for the updated info on using the sky images etc.  i haven't done much with it lately & it's no surprise to me that i used outdated info.  looking forward to bb's Big Reveal.
 My Freebies
dlfurman ( ) posted Sat, 25 September 2010 at 12:33 PM
> Quote - > Quote - Who says LuxRender doesn't do "Toon"-like renders? > > (Click to see bigger). > > > > No offense intended, but eek! > > Laurie
Yeah.
I was surprised at how this turned out also.
I have to examine what I did. It may be a fluke.
If someone wants a Toon style it may be in the lights, because I just cleared out the lights, loaded another set of lights and a look we are used to coming from LuxRender.
The light set used this time was the Daz Environment Lights.
Big difference.
ice-boy ( ) posted Sat, 25 September 2010 at 4:03 PM
toon rendering is not about lights. your render is not toon. its about shaders.
dlfurman ( ) posted Sat, 25 September 2010 at 4:38 PM
Quote - toon rendering is not about lights. your render is not toon. its about shaders.
I do believe I said Toon LIKE.
The resultant image was due to the lights, NOT the texture.
The image that followed was the SAME just different LIGHTS.
Thank you for the clarification.
dlfurman ( ) posted Sat, 25 September 2010 at 4:39 PM
bagginsbill ( ) posted Sat, 25 September 2010 at 4:50 PM · edited Sat, 25 September 2010 at 4:51 PM
Quote - > Quote - here's the 'skyglob' recipe i used on this image .  i think it needs rectangular images, not the spherical.  IIRC, bb is working on a way to use the env. sphere, but they need rectangulars also i think.  it'd be nice to be able to use my stash of sphericals as skies.....
facepalm ;o)
This format is called equirectangular. It covers a sphere.
There is also angular map. It covers a sphere as well, but in a different way. We use these for IBL.
There is also mirror ball which is what you get when you photograph a mirror ball. Unless the photo was taken from an infinite distance, it does not cover a sphere. It is often used in IBL because it's "close enough". It is not suitable for a 360 render where the camera can see the missing area.
Angular map and mirror ball format also severely distort some of the scene features. If you "look" at them in-scene, they don't look right.
Only the equirectangular format is really good at a full 360 capture with a consistent look to it in every direction.
LaurieA ( ) posted Sat, 25 September 2010 at 5:06 PM · edited Sat, 25 September 2010 at 5:07 PM
No matter what you call it, I can tell by looking at that map I posted and know that, while it might be rectangular, it's going to wrap around a sphere ;o). I've never mapped anything any other way for a sphere actually... I've seen cube maps for skies and was hoping that Luxrender didn't use those...
I know they use those mirrored ball images for things like light probes. Other than that, I've never found any other good use for them, at least not for the kinds of things I produce.
Latexluv ( ) posted Sat, 25 September 2010 at 5:22 PM
This is probably going to sound dumb, I know (but I only half understand what I'm doing), but do some sun/sky light set ups produce more noise than lights exported out of Poser?  I mean this is just an observation I've had and maybe it could be my five year old laptop.
Weapons of choice:
adp001 ( ) posted Sat, 25 September 2010 at 7:59 PM
**LuxPose Version 1.3 Alpha
To use Posers infinite light as sunlight rename the light to what type you want: "sun", "sky" or "sunsky". If you want be able to finetune the intensity or color of the sun use a Lightgroup: "sunlightGroup:sun", "sunlightGroup:sky", "sunlightGroup:sunsky" (or whatever you prefer insteed of "sunlightGroup" as group-name).
Attention: The size of the sun is taken from Posers infinite light scale-paramter (usualy 55% for me - so scale up to at least 100%)
Parameters aconst - econst and turbidity (fog) are set in the config file (./AIR/luxPose/data/dataOut.bbml).
If you don't know why it makes sens to have different "sun" and "sky", read the docu for LuxPose.
To use what we know as IBL (for scene-lighting) and skyglobe (for reflections) can now also be used.
In Poser define a light as IBL. Enter the material-room and attach a HDR-image as usually. The difference: DO NOT USE LIGHTPROBES.
Poser delivers some HDR-Images in folder Runtime/Textures/HDRFX. If you look into this folder, you will find each image in two variations. The larger ones are those we can use for LuxRender.
If an image is attached to an Poser IBL light, the converter assumes this light should be used as an environmental light. Setting other parameters in Posers material room for this light has no effect on what is exported. To rotate the images to what you want to see in your picture, use the Y-rotation of the light.
Note: Mostly other lights are only used to lit parts of a scene. But do this with greet care (low intensity). Too mutch intensity may result in grainy images. Good lighting will speed up the render process.
Another note: Don't use an object/figure without an environment. If you have now room around your object, a whole lot of rays are computed just to be discarded (they end up in nothing). So use at least a sky or better an environment light with an HDR image.
adp001 ( ) posted Sat, 25 September 2010 at 8:03 PM
Quote - This is probably going to sound dumb, I know (but I only half understand what I'm doing), but do some sun/sky light set ups produce more noise than lights exported out of Poser?  I mean this is just an observation I've had and maybe it could be my five year old laptop.
The amount of rays actually hitting your objects are lower with a sky-only light than with something around your object. Maybe you want to try an environment light insteed of a sky.
Another tip may be to experiment with the lightstrategy parameter (and others too).
adp001 ( ) posted Sat, 25 September 2010 at 8:08 PM
Quote - > Quote - I have just to make some small changes to get a version with good light-settings. Sky, sun, sunsky and environtment (last is used in my post above).
LuxRenders sky and sun objects are used if you have no skyimage. Or if you need a clear sky.
If you want to use something with clouds you better use an environmental-light. This is the better choice, by the way. It rendes faster und mostly gives better results.
LaurieA ( ) posted Sat, 25 September 2010 at 8:13 PM
Quote - If you don't know why it makes sens to have different "sun" and "sky", read the docu for LuxPose.
Did you mean LuxRender here adp? ;o). I was gonna say - I have seen a detailed readme for LuxPose yet ;o).
adp001 ( ) posted Sat, 25 September 2010 at 8:16 PM
People with not so fast computers may set the lightstrategy to "one". This parameter has to be used anyway if you want to try out GPU-rendering.
Change this parameter directly in File .lxs (search for "lightstrategy").
adp001 ( ) posted Sat, 25 September 2010 at 8:24 PM
{quote]
Oh, yes.
