Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 12 9:36 pm)
SerpentFire, you really should do a search for bagginsbill's various posts on water shaders and start off with exactly the shaders he posted.
Also handy if you post a screenshot of your shader setup so we can see what you're doing.
I don't know what the link in your first post was about, but it doesn't work.
PoserPro 11 - Units: Metres
Adobe CC 2017
Attached Link: "Water In Poser" Forum
> Quote - SerpentFire, you really should do a search for bagginsbill's various posts on water shaders and start off with exactly the shaders he posted. > > Also handy if you post a screenshot of your shader setup so we can see what you're doing. > > I don't know what the link in your first post was about, but it doesn't work.I did start off with the EXACT shaders he posted in that link. But his scene did not really have a background so I had to tweak it. I am using the same ones again except that I just changed the color of the Diffuse Color and I also put Turbulence instead of clouds. I reattached the link to the Forum I used.
Poser 11 , 180Gb in 8 Runtimes, PaintShop Pro 9
Windows 7 64 bit, Avast AV, Comodo Firewall
Intel Q9550 Quad Core cpu, 16Gb RAM, 250Gb + 250Gb +160Gb HD, GeForce GTX 1060
Attached render using material above
SF
Change the transparency in the main Posersurface node. Same with diffuse colour to get bath/river/sea water.
Got a node plugged into Displacemnet so don't forget to enable this in your render settings. Also needs a sky dome for reflections.
SP
Material was applied to the Poser 8 Hi-Res Square, Z-Scale and X-Scale set to 1000%. Changing the x-scale and z-scale in the Fractal Sum node changes the distance between the ripples. I'm not v good with nodes so a better explaination from an expert would be appreciated. Can this be used as a ripple and combined with another node to create the bigger waves. Maybe it easier to morph the square prop? More help needed!
Quote - SP
That sounds logical, and I was actually wondering the same thing. Would be nice to be able to create something akin to a rough sea. I am sure BagginsBill would be able to say, he seems to be the guru on this sort of thing :) Also he might be able to suggest, or someone might be able to, how to light the water as if there are lights in the water. That was a very long winded way to ask that LOL But say for instance you wanted to create a swimming pool and it was going to be a night time scene, do you simply place a light under the surface of the water or is there a better way? I think I may be a little OT but I say things as they come into my head :)
Oh by the way, I was following advice given in another forum topic (http://www.renderosity.com/mod/forumpro/showthread.php message_id=2811816&ebot_calc_page#message_2811816), but I tweaked it a little. The settings are pretty much the same only the Diffuse Color is not black because it was far too dark when I did that, and I tweaked the Bump and Clouds as well. I am looking for how to get rid of the.. noise for want of a better word. I mean I want it wavy so to speak but as you can see there is... static or something. Sorry, these aren't technical terms, but you know what I mean :)
