Wed, Jan 29, 2:17 PM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Jan 28 7:46 pm)
Subject: Reality Render thread. A new beginning.
mrwakko ( ) posted Tue, 22 May 2012 at 1:06 AM
Going to see if I can get the image posted. Some great stuff so far. You guys know me as Kenneth Rowe at the Daz Forum. Friends call me Mac, but I'll answer to just about anything.
Reggie68 ( ) posted Tue, 22 May 2012 at 2:08 AM · edited Tue, 22 May 2012 at 2:11 AM
Quote - > Quote - The Champion Enters the Arena
Click for gallery
Reg, you've convinced me. From now on, all my characters bearing skin will also receive joint pads to cover up mesh creases!
But they are there for safety reasons not aesthetic. It may also interest people to know that the girls were exported from DS4 (needed collsion detection on the Nun outfit) while everything else was exported from DS3 as the spray tool doesn't work for me in DS4.
bbost ( ) posted Tue, 22 May 2012 at 5:43 AM
Quote - Question for the glass experts. I'm trying something a little different and want to get a window pane for detective's office to read his title and name. I've tried a few approaches to get the texture nice and readable, but now it's reflecting within the glass pane and reads like it is both forward and backward. I'll put up a pic when it gets a little farther on this attempt.
Would an alpha map on the window help separate things?
The cool thing about REALITY is it works like the real world. A sign on a Detective's door in the real world would be painted-on letters one side and/or stickied-on one side. Your letters should be on a separate plane (1 pixel distance) from the "glass" and ALpha mapped and that should solve your problem. And try "architectural glass" if you haven't already.
Pret-a-3D ( ) posted Tue, 22 May 2012 at 5:56 AM
Quote - Question for the glass experts. I'm trying something a little different and want to get a window pane for detective's office to read his title and name. I've tried a few approaches to get the texture nice and readable, but now it's reflecting within the glass pane and reads like it is both forward and backward. I'll put up a pic when it gets a little farther on this attempt. Would an alpha map on the window help separate things?
You should place the texture in the transmission channel of the glass, set the reflection channel to almost oure white, and set the glass to archi. Using an alpha channel with glass is not a good idea, it will make part of the glass disappear. There is no need to use the alpha channel unless you want to create irregular shape glass objects.
Cheers
Paolo
https://www.preta3d.com
FB: https://www.facebook.com/RealityPlugIn
Tw: @preta3d
G+: https://plus.google.com/106625816153304163119
The Reality Gallery: https://reality-plug-in.deviantart.com
59Burst ( ) posted Tue, 22 May 2012 at 9:06 AM
Quote - Here you go, for those interested. The chair, table and glass used in my render.
Custom OBJ files
You are most generous and kind, sir!  Thank you.
superboomturbo ( ) posted Tue, 22 May 2012 at 11:25 AM
Thanks for the replies on the glass issue. I do have the texture in the transmission slot with a reflection of 246 across the board and architectual as the glass setting.
I hadn't thought about doing the plane for it! Good idea! I ended up frosting it for the time being as I tried a few other things in the mean time with the same results. I do plan on doing a fog prop version, so I'll add the plane for the next round
crimsonworx.com; free ebooks and previews
I've bowed down to facebook: https://www.facebook.com/crimsonworx
john3d ( ) posted Tue, 22 May 2012 at 12:25 PM · edited Tue, 22 May 2012 at 12:26 PM
Sorry off topic but as Daz is down I could not contact anyone via PMs
Doc - Did you get the file I sent you at DA ?
callad ( ) posted Tue, 22 May 2012 at 12:45 PM
Quote - Sorry off topic but as Daz is down I could not contact anyone via PMs
I never could reach anyone in my entire life via PMS...
bobvan ( ) posted Tue, 22 May 2012 at 12:50 PM
Attached Link: http://adrikk.deviantart.com/#/d50tnu1
> Quote - > Quote - Sorry off topic but as Daz is down I could not contact anyone via PMs > > > >   > > > > Doc - Did you get the file I sent you at DA ? > >   > > I never could reach anyone in my entire life via PMS... ![](http://www.renderosity.com/mod/forumpro/art/emoticons/blink.gif)
LOL just my latest...
Plixy ( ) posted Tue, 22 May 2012 at 1:00 PM
Quote - Thanks for the replies on the glass issue. I do have the texture in the transmission slot with a reflection of 246 across the board and architectual as the glass setting.
I'm not sure if I'm going to put this right but this is what occurs to me...
Is it possible that your glass object is using the same surface for the front and back of the pane? Thus you are in fact puting the letters on both sides as byproduct of how the object is made? If so the plane in front is going to be the safest way to do it, or finding a window made differently.
bobvan ( ) posted Tue, 22 May 2012 at 1:25 PM
To Chalrey I will explain a bit here since ppl who are following my stories on D/A wont have the plot given away its going to get into gory detail (such is the power of Reality:) the v4 guts works quite well with genesis..... Its basically a nightmare sequence to open my current episode..
callad ( ) posted Tue, 22 May 2012 at 1:32 PM
Quote - To Chalrey I will explain a bit here since ppl who are following my stories on D/A wont have the plot given away its going to get into gory detail (such is the power of Reality:) the v4 guts works quite well with genesis..... Its basically a nightmare sequence to open my current episode..
Thanks Bob :) If it's very gory I do not mind not knowing the plot
bobvan ( ) posted Tue, 22 May 2012 at 1:34 PM
Quote - > Quote - To Chalrey I will explain a bit here since ppl who are following my stories on D/A wont have the plot given away its going to get into gory detail (such is the power of Reality:) the v4 guts works quite well with genesis..... Its basically a nightmare sequence to open my current episode..
LOL not sure if iy would be your thing so I figure id let you know I will be posting links to the renders but with the appropriate warnings...
DominiqueB ( ) posted Tue, 22 May 2012 at 1:46 PM
Hi guys! Nice to see the Rendo thread is a busy one there are some really nice renders already.
Does anyone have a recipe for Jade? I remember seeing a dragon somewhere that had the precise color I'm looking for.  I think the Stanford Happy Buddha would look a lot better in jade or maybe even bronze than the green glass I tried him in.
http://fav.me/d50ttsn
This was just a test to see how Lux would handle the 1 million triangles the model contains, I started the render at 1 pm Friday and let it bake over the weekend for 96 hours straight. it was still rendering happily when I came in to work this morning.
Dominique Digital Cats Media
bobvan ( ) posted Tue, 22 May 2012 at 1:57 PM · edited Tue, 22 May 2012 at 1:58 PM
Attached Link: http://adrikk.deviantart.com/#/d50u1rm
I will take these fast render times while the gettin's good...
UHF ( ) posted Tue, 22 May 2012 at 2:25 PM
Quote - Very cool UHF
The DAZ site is all fraked up
I feel anger for the 'tards that be over there.
The store has some namby pamby comment section... Like I need a longer page to scroll through all so I can comment on something I haven't bought yet.  They lost my first order completely.  I have no idea why yet, but they've been paid so what gives?
Its like they hired a newb to run the show. "You need this wowwie wizywig crappola!" "Cool Dude."
Couldn't they test it before going live?  In software that is all we do.  If you find a programmer coding more than 20% of the time, he's incompetant.  Documentation, and testing... is the other 80%.  It seems pretty obvious to me that they had a very poor set of test cases.  (It worked once... SHIP IT!  Oh... doesn't work under those conditions?)
And timing... Here's our latest test release let us know if you have any issues.  POOF! Site down.  Have they heard of this thing called MANAGEMENT?  Its not something you step in.
PFFFT!
They say Genius is step away from madness.   Lets just say they are one step beyond....
NOTE to Renderosity... copy Daz's old webpage and put them out of business.**
bobvan ( ) posted Tue, 22 May 2012 at 2:50 PM · edited Tue, 22 May 2012 at 2:59 PM
Its more like Daz Genius--Tsssssst (injesting puff of weed) I got it man! Lets put out a buggy version of studio and make sure no one can get support for it!!
Its like 2K video hockey if they flush theselves down the drain it will be their own doing. I certainly am not purchasing another item until this is resolved. They are promising a make up for it sale on FB.
Am I understanding this right? They will be charging again for the official studio 4.5??
Not only that if you install 4.5  and decide to go back for some reason it will apperantly mess up your previous saved stuff. I have 2 words to fix that System Restore...
For my needs I can stay with Stuido 3-4 Reality-lUX just fine...
Providing it stays free I may change but not before Reality is compatible and they have an official version..
RHaseltine ( ) posted Tue, 22 May 2012 at 3:00 PM
Online Now!
Wheer does it say 4.5 will be a purchased item?
FyraNyanser ( ) posted Tue, 22 May 2012 at 3:01 PM
Quote - Its more like Daz Genius--Tsssssst (injesting puff of weed) I got it man!
That really made me laugh, but somehow I don't see DAZ as a bunch of stoners—correct me if I'm wrong!
gwjgva ( ) posted Tue, 22 May 2012 at 3:13 PM
Quote - > Quote - Its more like Daz Genius--Tsssssst (injesting puff of weed) I got it man!
Judging from their Christmas dinnner pic, the strongest thing they ingest is tonic water.
But I agree that they're making a hash of it all again.
FyraNyanser ( ) posted Tue, 22 May 2012 at 3:25 PM
In terms of 4.5, I'm all over it. I did manage to find a computer to install it on and I'm impressed already. Plus there's some exciting developments hidden away in there that I won't be able to get to grips with until I have it on my main frame (highlights in Richard's post here—e.g. geometry shell). But I won't be upgrading until Reality is ready—and maybe Gen X (but I think I can live without that for a while).
bobvan ( ) posted Tue, 22 May 2012 at 3:27 PM · edited Tue, 22 May 2012 at 3:28 PM
Attached Link: http://adrikk.deviantart.com/#/d50ue4t
> Quote - > Quote - Its more like Daz Genius--Tsssssst (injesting puff of weed) I got it man! > > That really made me laugh, but somehow I don't see DAZ as a bunch of stoners—correct me if I'm wrong!
It was tongue and cheek... No matter what its pretty welfare... Richard that's why I said correct me if I am wrong thanks for doing that
Anyoo another render.....
bobvan ( ) posted Tue, 22 May 2012 at 3:52 PM
Quote - In terms of 4.5, I'm all over it. I did manage to find a computer to install it on and I'm impressed already. Plus there's some exciting developments hidden away in there that I won't be able to get to grips with until I have it on my main frame (highlights in Richard's post here—e.g. geometry shell). But I won't be upgrading until Reality is ready—and maybe Gen X (but I think I can live without that for a while).
Whats geometry shell??
Doctorjellybean ( ) posted Tue, 22 May 2012 at 4:12 PM
Ermm .... I'm sure I bookmarked your DA section, but do you think I can find it? Will look some more.
My DA Gallery
Doctorjellybean ( ) posted Tue, 22 May 2012 at 4:13 PM · edited Tue, 22 May 2012 at 4:14 PM
PMS or PMT
My DA Gallery
FyraNyanser ( ) posted Tue, 22 May 2012 at 4:20 PM · edited Tue, 22 May 2012 at 4:21 PM
Geometry shell is a technology that makes a second copy of a model (e.g. a Genesis or V4 character) which surrounds the original, and at the same time the original is scaled down slightly, so it becomes like a second skin, but so much more versatile. It has its own texture surfaces, so you can set these to add texture effects and blends to the original model. You could use it to make a character glow, add hair, moisture—whatever you might imagine. If you've ever seen Jepe's body jewels and tears, "body hair suit" and tattoo system, it's like that, except much easier to manage as it takes a lot less resources than simply loading another copy of your character. It's also going to be a great help with blending textures with Geografting.
You might have missed the link in my post as they are kind of hard to see here, but there is more explanation of it there:
http://www.daz3d.com/forums/viewthread/63/
Like Geografting, I'm pretty sure it's going to inspire some exciting new products.
bobvan ( ) posted Tue, 22 May 2012 at 8:06 PM
Attached Link: http://adrikk.deviantart.com/#/d50vjr9
More from my twisted mind Muahahahahah *cough cough* LOL!
Tako_Yakida ( ) posted Tue, 22 May 2012 at 9:30 PM
Hello peeps. It's Off Topic Man. That's my new alias. lol
I'm wondering if this DAZ site thingee is going to make sales harder. I feel no motivation to continue working on my next product with all the nonsense going on. I don't even feel like opening DAZ Studio for any reason whatsover. I can't believe I got an email from DAZ about a Grand Opening when the forums are not working yet....
I wish the new site thingee never happened. I am now considering opening up a new dreaded sales tax account so I can start selling prints of my photos at art shows. (I just bought a nikon by the way.) Of course, I'd need a truck and some racks and other stuff to transport and display everything. My laziness is making the change uncertain. :(
This totally sucks......
Reality Plug-in tips for DAZ Studio and other 3D stuff @ TakoYakida World
odadune ( ) posted Tue, 22 May 2012 at 9:38 PM
bobvan: which skin are you using on your Harrison Ford lookalike?
bobvan ( ) posted Tue, 22 May 2012 at 9:49 PM · edited Tue, 22 May 2012 at 9:57 PM
Attached Link: http://adrikk.deviantart.com/gallery/27853731?offset=2016#/d4zm4gu
> Quote - bobvan: which skin are you using on your Harrison Ford lookalike?
I think its Jeremy Elite one of the m4 elites LOL I also have the face & hands sub D'd at 3 and the torso at 2....
He is captain Han Solo in my series except for a different alliance...
odadune ( ) posted Tue, 22 May 2012 at 9:59 PM
Ah, ok!  It's a good match for him though.  WERTS did great work modelling those faces, but how well they look depends heavily on the choice of skin.
bobvan ( ) posted Tue, 22 May 2012 at 10:01 PM · edited Tue, 22 May 2012 at 10:05 PM
Quote - Ah, ok!  It's a good match for him though.  WERTS did great work modelling those faces, but how well they look depends heavily on the choice of skin.
If you look at my Trek story I use all of his morphs
For my main Land of the giants female character there is no good current Deanna Lund pics or model so I have her fece genned on Genesis..
superboomturbo ( ) posted Tue, 22 May 2012 at 10:19 PM
Quote - Hello peeps. It's Off Topic Man. That's my new alias. lol
Tak, there's no time like the present to take advantage of other markets. I've seen the shift here at Rendo towards a more friendly environment towards Daz, which makes me quite happy. A lot of new products are popping up with 'tested in Daz studio...' so don't give up yet! I agree, the new site nonsense was poorly, well, everything, but it'll get sorted as we both know. Hang in there champ. All good things come to those who wait!
If you find a cure for your laziness, give me a shot too. I've been trying to get a new novel done for, uhh, quite a while. Just can't seem to find the drive to get more than a few pages down a month.
Tollaris ( ) posted Tue, 22 May 2012 at 10:20 PM
Trying my hand at a dark portrait type pic.
Iteri
Full size in my gallery at
http://www.renderosity.com/mod/gallery/index.php?image_id=2331853
bobvan ( ) posted Wed, 23 May 2012 at 12:36 AM · edited Wed, 23 May 2012 at 12:37 AM
Attached Link: http://adrikk.deviantart.com/#/d50wejf
Tiny Valerie in big trouble
Warning nudity bondage Adults only please..
Tako_Yakida ( ) posted Wed, 23 May 2012 at 1:17 AM
Quote - > Quote - Hello peeps. It's Off Topic Man. That's my new alias. lol
Thanks Super. I suppose I could try my hand at some V4 stuff again. V4 still seems to be the top chick on this site.
Here's to finding the cure to laziness. :)
Doctorjellybean ( ) posted Wed, 23 May 2012 at 4:47 AM
Quote - Doc - Did you get the file I sent you at DA ?
Nope. I sent you a PM through here.
My DA Gallery
Doctorjellybean ( ) posted Wed, 23 May 2012 at 4:49 AM
Quote - Friends call me Mac, but I'll answer to just about anything.
And friends call me the good Doctor :) If you need an examination or something .....
My DA Gallery
bobvan ( ) posted Wed, 23 May 2012 at 10:21 AM
Thank you Robert and Charley for the encouraging feedback on D/A coming from you guys thats quite a compliment!
bobvan ( ) posted Wed, 23 May 2012 at 10:46 AM
Question what is the best settings to create wet looking skin?  Just turn up the gloss??
OT topic one thing I dont understand with these supposed improved version of studio is why the lighting rendering engine never seem to improve much? I think UE pretty well looks the same as it does in 3...
superboomturbo ( ) posted Wed, 23 May 2012 at 11:13 AM · edited Wed, 23 May 2012 at 11:18 AM
Quote - Question what is the best settings to create wet looking skin?  Just turn up the gloss??
Aside from having a wet skin map, gloss of 8500-9100 or higher and a light blue specular color gives the wet/slick look.
As for the render engine, 3Delight is actually a product that you can update separately from here last I checked (around a year ago mind you) http://www.3delight.com/en/index.php
I'm not sure if Daz ever has gone above the 8.x version for Studio, but I have 9.something and its not much different either. You can get pretty good results running the Renderman version but I haven't the foggiest how you go about that. Seen it done, never done it myself. At any rate, it's not Lux
Correction: latest version is 10.4, here http://www.3delight.com/en/index.php?page=3DSP_download
In the nearly fine print, it does say the free version is limited to dual core performance, meaning if you have more than a dual core, it's gonna cost you some bucks to unlock full potential.
bobvan ( ) posted Wed, 23 May 2012 at 11:33 AM
Like you said we have LUX and I have been cranking fast renders the past few days just a few mesh lights. Like hair & foilage will slow down 3Dlight renders I am finding out its the amount of lights in LUX..
Reggie68 ( ) posted Wed, 23 May 2012 at 11:38 AM
The Off Topic Police might be watching...
superboomturbo ( ) posted Wed, 23 May 2012 at 11:57 AM
Quote - Like you said we have LUX and I have been cranking fast renders the past few days just a few mesh lights. Like hair & foilage will slow down 3Dlight renders I am finding out its the amount of lights in LUX..
Interesting that you should mention the amount of lights with Lux. This morning I checked up on a 3 day render that was turning into a mess of noise which had very adequate light, or so I thought. I wanted to do a fog version, so I ended up killing it. Adding fog and my glass fix, I plugged in a spot for my fog effect and rearranged my mesh for an interior fill. The speed dropped like a rock, but my effeciency went from 115% to 610%! With an added bonus, this version looks better at 95 samples than the other did at 3.15k. I'm now finding that the amount of lights isn't as important as I once thought... Its the quality of the light, which makes perfect sense in Lux.
bobvan ( ) posted Wed, 23 May 2012 at 12:27 PM · edited Wed, 23 May 2012 at 12:28 PM
I am referring to something like this. I converted all the bridge lighting to lights and called it at 2 1/2 days kind of cheated with the ps blur tool. I could of baked it longer http://fav.me/d4zm4gu
This one http://fav.me/d4zna8d with 3 mesh lights took only 3 to 4 hours. I tried the one above for heck of it without the converted lights and it too would rendred in a few hours..
Doctorjellybean ( ) posted Wed, 23 May 2012 at 12:27 PM
You could try this
http://www.daz3d.com/shop/wet-body
My DA Gallery
bobvan ( ) posted Wed, 23 May 2012 at 12:31 PM · edited Wed, 23 May 2012 at 12:31 PM
Attached Link: http://adrikk.deviantart.com/#/d50xsdb
Thanks doc, I am just looking to simulate sweaty skin from whan she pops up in bed waking  up from this nighmare...
The same warnings as my last render applies to this one..
john3d ( ) posted Wed, 23 May 2012 at 1:17 PM
Hello Tako, I feel your pain.
Off topic again, sorry folks - blame Daz.
Doc got your message and sent you a note here about the link.
bobvan ( ) posted Wed, 23 May 2012 at 1:38 PM · edited Wed, 23 May 2012 at 1:39 PM
Oooo thats 2 now thanks to bring her out Reggie!
bobvan ( ) posted Wed, 23 May 2012 at 3:55 PM
Attached Link: http://adrikk.deviantart.com/art/LOTG-Home-14-303943461
The preil gets deeper warnings and all..
