Mon, Jan 20, 12:14 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 11:41 am)
Subject: Hair room / skullcap experiments
Believable3D ( ) posted Fri, 15 August 2014 at 8:55 PM · edited Thu, 16 January 2025 at 7:43 PM
Here's a little lesson on assumptions.
[Note: the discussion below relates entirely to Hair Room hair, but I'm sure there are implications that go beyond that.]
I had assumed that setting the skullcap to invisible in Properties would be equivalent to leaving it visible in Properties, but making its material settings fully transparent.
Not even close.
Check out these comparison area renders. Nothing else changed, just the skullcap Properties.
Some things to draw from this:
  • Making the skullcap visible but transparent will make it much easier to hide the head with the same amount of hair density set in the Hair Room. In fact, in order to make the roots look only half decent, the strong part on this hairstyle required density to the level of making the rest of the hair unrealistic, somewhat helmet-like.
  • Making the skullcap invisible results in virtually zero shadowing artifacts in Hair Room hair.
  • Making the skullcap visible but transparent with light emitter unchecked results in blotchy artifacts.
  • Making the skullcap visible, but with "Light emitter" on also leaves artifacts, but in such a way that at least with this hair colour they pretty much look like natural shadows. (More testing required.)
  • One of the takeaways is that the intuition that transparency + light emitter on is resource hungry is not correct in this case, since we can make do with much lower hair density, at the same time gaining in realism.
Maybe all this is old hat to everybody else, but it's valuable lessons to me, especially as someone who uses the hair room a lot.
______________
Believable3D ( ) posted Fri, 15 August 2014 at 9:01 PM
I should also add that in render settings, I was using Sinc 1 and a .2 minimum shading rate. I'm now testing lowering the MSR only on the skullcap and render settings and seeing what happens.
It may also be that another post filter type will result in less artifacts than Sinc 1.
______________
Believable3D ( ) posted Fri, 15 August 2014 at 9:09 PM
Interesting. It appears that lowering the minimum shading rate actually makes the artifacts look *worse*—more pronounced and distinct—at least with these settings.
Of course, they might also go away altogether if I crank Irradiance Caching. But at the moment I'm aiming for something usable for medium quality renders.
______________
Believable3D ( ) posted Fri, 15 August 2014 at 9:17 PM
As I suspected, cranking the Irradiance Cache makes the artifacts much better. This is at 80 (previous images were set at 24).
______________
Believable3D ( ) posted Fri, 15 August 2014 at 9:34 PM
My suspicion about Gaussian being less jarring with artifacts than Sinc turned out to be largely unfounded. The resulting area render looked like the artifacts were arguably slightly less defined, but minimally so at the very best. (That with both render settings having Irradiance at 24.)
Am doing further experiments with shutting off IC altogether—which of course slows rendering to a crawl—as well as softening my shadows further. (Currently the shadows on the lights are set at 2.9.)
______________
Believable3D ( ) posted Fri, 15 August 2014 at 10:51 PM
Turns out that with IC off, Poser Pro doesn't really know what to do with the skull cap. The blotchies are all gone, but only by virtue of the whole skullcap essentially becoming one big shadow. Essentially, the render has the "shadow" tracing the contours of the edge of the skullcap. Not what we want.
______________
Believable3D ( ) posted Fri, 15 August 2014 at 11:09 PM
IMO, this is about the best so far. Shadow Blur Radius on the lights: 8.5. Sounds high, and not sure if it would be ideal for the rest of the image other than the hair. But I think this looks pretty good.
______________
aRtBee ( ) posted Sat, 16 August 2014 at 2:55 AM
sorry to interrupt, but I don't understand what you're doing. Things that popped up my mind when reading:
  • skull caps are meant to remain invisible
  • filter: sinc is sharper than gaussian (see the manual)
  • filter: 1 means NO filter, 2 means soft (female skin), 3 means crisp (hair and male skin) and 4 is too much for about everything
  • min shading rate .2 means at most 1/.2=5 subpolys per render pixel. It mainly affects displacement sharpness and texturemap subsampling. Lower is sharper. The value should stay in sync with Pixel Samples.
  • IDL splotches are the result of a too small amount of rays at a too high intensity. Irr cache rebalances these at the cost of render time. Use 80 for final, 40 for draft. IDL Quality supports that without the rendertime penalty. Keep that at 80 or so.
  • Increasing the size of the IDL light sources in the scene (and reducing their strength) might be an option as well. Usually, having lightsources with Ambient > 2 is an indicator for blotches coming up.
  • the working of Direct-Light Blur Radius depends on the kind of shadow (raytraced / mapped) and the kind of light (infinite or point/spot). Your 8.5 sounds low for spotlight, to me.
    For raytraced shadows, it's adviced to keep the blur-radius : shadow sample ratio on 1 : 10, so your 8.5 requires a 80-100 samples value.
Perhaps this is a bit of help, questions welcome. Poser lighting and rendering is a horror story, but not a bad one... Please give us your lighting rig to help you with specific issues.
And yes... your last result looks pretty cool indeed. Compliments.
Believable3D ( ) posted Sat, 16 August 2014 at 5:44 AM
Thanks for the tips, but I think you're missing a lot of the point, which in part is that the skullcap actually should not be Visible unchecked if you want best results. Checking it does introduce other issues, but it also makes the overall rendering of the hair close to the root more believable and requiring less density.
______________
Believable3D ( ) posted Sat, 16 August 2014 at 5:50 AM
Also, leaving the skullcap invisible means that the roots of the hair do not leave proper shadows, at least in my test.
______________
aRtBee ( ) posted Sat, 16 August 2014 at 6:14 AM
Okay, we're just struggling with you...
Actually, I've observed Poser to have rendering issues when two surfaces coincide exactly. Therefor: is the skullcap over, coinciding or slightly under the skull/skin? I usually do the latter you know, just shrink it 1mm and it becomes invisible whatever the settings, as the head itself is all over it...
Then: do you use (Custom_)Scatter for the head material?
I also assume for the moment that Shadow Bias settings do matter, as they calculate shadows somewhat away from the surface and then project the result upon that surface. Values are in user units, as set in prefs. Perhaps worthwhile to experiment with.
Useful info, anyway.
Believable3D ( ) posted Sat, 16 August 2014 at 2:45 PM
I try to get the skullcap to be as close to the surface as the head as possible, rather than under it. Under it would certainly be ideal in some respects, but it would create problems with collision, would it not? (Of course, this wouldn't matter if you're not going to run any dynamics simulations, but I presume that Hair Room hair is going to get dynamics treatment sooner or later.)
______________
Believable3D ( ) posted Sat, 16 August 2014 at 7:30 PM
I ultimately settled on IC 80, with Gaussian 2. This has IDL quality at 60 and pixel samples at 12. There is one spot and one infinite with a 5.0 Shadow Blur Radius, and Shadow Samples are between 90–100 (which is pretty much my standard setting). There is also one wall of the room with ambient.
The hair itself needs a bit of tweaking in the back, as I have a little chunk of hair roots intersecting other hair. But overall, really liking how this turned out.
______________
Believable3D ( ) posted Sat, 16 August 2014 at 9:05 PM · edited Sat, 16 August 2014 at 9:06 PM
Well, I had a hunch on this and thought I'd try it. Counterintuitively (unsurprising, since this whole thread seems counterintuitive), I applied my V4 skin face setting to the skullcap, then re-added my transparency settings.
The result: the splotchiness is almost completely gone.
The problem of course is that you can't really distribute any such materials on the skullcap, because you don't know what the user is going to be doing with his character's skin.
______________
Believable3D ( ) posted Sat, 16 August 2014 at 9:46 PM
Really curious if e.g. Bagginsbill can give an accounting for this as expected behaviour. As I noted, I expected Visibility off and full transparency would have been equivalent, but it's not even close.
______________
aRtBee ( ) posted Sun, 17 August 2014 at 2:11 AM
just did some tests in a very splotchy IDL setup, and I cannot determine noticeable differences between 100% transparent and fully invisible. Of course, only unchecking Visible to camera leaves the shadows intact. But - in my test - there are no ghost splotches floating around on an otherwise absent surface.
but given your lighting: transparency only works on (alt_)diffuse. Specularity is not affected (unless plugged into alt_diffuse as well). Does it make a difference when the specularity channel is blacked out on the direct lights? Just guessing.
Believable3D ( ) posted Sun, 17 August 2014 at 9:17 AM · edited Sun, 17 August 2014 at 9:22 AM
If I was looking for a bug to track down, I would try that. But I don't want specularity off on direct lights, and have difficulty imagining that I ever would. Moreover, if you want to redistribute something, you don't want to be dependent on the user having spec off on the lights.
Right now, my transparency map and value is plugged into the native transparency channel (and is obviously working, or you would actually see the skullcap itself, not just its effects on light and hair). Are you suggesting it will work differently if I use Alt_Diffuse? Edit: and if so, how do I get transparency into Alt_Diffuse. I've never had a reason to attempt it, and don't see how.
______________
aRtBee ( ) posted Sun, 17 August 2014 at 10:12 AM
no, all I'm saying is that Transparency (and all attached to it) works on whatever is in/attached to Diffuse and Alt_Diffuse. But it does not work on Specularity, Alt_Specularity or anything else. And no indeed, there is no node for it.
Since it does work on Diffuse (and therefor on the surface elements that capture and re-emit IDL) but not on Specular, and your lights do have specular for good reasons, I got the idea (and nothing more than that) that the undesired effects you're facing might be a result from specularity, not from diffuse/transparency/IDL at all. To find that out, I suggested to run a test without the specularity, to see if that makes the unwanted effects disappear. It might be of help in looking in the right direction.
I was also implying a difference between invisible and transparent. Transparent means invisible to diffuse, to IDL, but NOT to specularity. Invisible means invisible to everything. So a transparent skullmap still responds to the specularity in your lighting, unless that's switched off on either side.
Note: in another thread on SR4, Vilters has reported that raytraced shadows on dynamic hair are improved / properly working in the new SR. For whatever reason, the availablity of SR4 is not flagged when starting Poser.
Believable3D ( ) posted Sun, 17 August 2014 at 2:11 PM
artbee, I'm using SR4. I don't see any improvement. But perhaps the improvements are in different conditions.
Now, to your point, no: the artifacts are not from specularity, at least not in isolation from IDL. They are from IDL. I know this, because they disappear if I don't render with IDL, just raytracing. But of course I don't want to do that, since in every other way IDL looks infinitely better.
______________
aRtBee ( ) posted Sun, 17 August 2014 at 3:16 PM
okay, that puts some possibilities out of the way.
re-reading your posts to grasp the situation in full detail, I must admit that I've no info on the hair itself, it's all on the skullcap only. Is light-emiitor for the hair itself on or off? An what about the head (since the cap is made to vanish in some way or another).
I also must admit that I've lost track of the skullcap settings. Do I understand correctly that splotches occur and shadowing improves when the cap is visible and fully transparent and light-emitter off, and that the splotches are minimal under IDL when its visible and fully transparant and uses all the face material settings and light-emitter on? It's mainly the combi of fully transparent AND using all face settings which wonders me. How can material settings (especially: any content in Diffuse / Alt_Diffuse) make a difference when it's fully transparent?
Time for some (Mat Room & Properties) screenshots, I'm afraid.
Interesting anyway, thanks for the puzzle :-)
Believable3D ( ) posted Sun, 17 August 2014 at 3:40 PM · edited Sun, 17 August 2014 at 3:46 PM
My settings for the hair itself is for optimal realism, not for speed. Therefore, yes, the hair is set to Light emitter, Casts shadows and all that good stuff.
To recap the skullcap situation:
Visible unchecked: Hair roots exposed and not properly shadowed. If there is a visible part of any sort, the hair density has to be cranked to ridiculous levels to avoid showing too much skull, and even then the shadows near the roots don't look right. On the bright side, no IDL artifacts. This, by the way, is the same as parenting the hair props directly to the character (in this case, V4) rather than to a skullcap.
Visible checked, Light emitter on, Visible in Raytracing on in Properties; Transparency 1.0 feeding to a fully black transparency map: Great hair shadowing, especially at the roots, but varying levels of splotchy artifacts. Just how splotchy varies by playing with other settings.
So far as the difference that using the face's materials goes, the jury is still out, but it looks like it does have an effect, although I don't know why. I thought it would be the SSS, but the SSS pass still shows the skullcap area as dark. So I don't know.
At any rate, the bottom line for now is that using a skullcap set to Visible/Light Emitter/Visible in RT + full transparency results in much better looking root shadowing, but also results in artifacts. I guess this is probably why Vilters thinks the artifact issue with hair room hair is gone: he hasn't attempted to do what I've done here. For myself, the improvement of root shadowing is worth the splotches if I can blur them enough to make them look like natural shadows, but it obviously would be better if I could get those results without the artifacts. Hence all my experiments above.
Unfortunately, I'm almost thinking that the role that the skullcap plays in this case is unintentional, which would mean it may not work forever.
I say this because what is happening with the skullcap should also be happening when the hair is parented to the head without a skullcap (I think), and it isn't. Theoretically, if the skullcap is set to Light emitter etc and gives this sort of root shadowing, that same sort of root shadowing should occur if the hair is parented directly to the head (which obviously is set to Light emitter). But in fact it doesn't.
______________
Believable3D ( ) posted Sun, 17 August 2014 at 4:04 PM
Another datum to consider: the "root shadowing trick" doesn't work if Visible in Camera is checked on the skullcap.
______________
aRtBee ( ) posted Mon, 18 August 2014 at 1:44 AM
can't get my head around it.
So I will set up some tests myself and start playing. May take a while.
aRtBee ( ) posted Wed, 20 August 2014 at 3:00 AM
Hi, back again.
I've tried to my best to recreate the setup as described in all the above posts:
  • One infinite light, one skydome with no ambient (passive IDL deflector), IDL set ON with high quality settings
  • Head with only Scatter (in Alt_Diffuse) and specular
  • Cap like Head, and transparency
  • Hair with regular hairnode setup, and varying densities (1, 10 and 100 hairs/cm2)
  • Head, Cap and Hair have all properties ticked ON
Findings:
  • Light Emitter on/off on hair does not make any difference in result or rendertime. That's a new one!
  • Scatter is not of influence in all this, it's an independant (diffuse) effect that disappears with all other diffuse effects at 100% transparency. Good.
  • No difference between 1.0 transparency and 1.0 transparency with black color attached, so there is just one kind of "100% transparent", as expected
  • Main difference between 100% transparent and (total) Visibility OFF is in specularity (in transparent, not in invisible), as expected
  • The overlap between 100% transparency and Visible in Camera OFF is in shadowing and IDL emission, both do that.  The ViC check only removes the source of the shadows / IDL emission, not the effects on other objects. As expected.
  • 100% transparency does leave traces in the render, on darkening/shadows and visibility, when Transparency_Falloff is not 0.0. In combi with the previous: 100% transparency, Falloff > 0.0 and ViC unchecked does leave the darkening/shadows on other objects. IDL emission is minimal.
  • So for invisible SkullCaps shadowing on the Head, the Falloff dial is your friend (or enemy).  And since the object is invisible in camera anyway, transparency can be reduced a bit too. That will increase shadows and IDL. Then Scatter will have some effect, softening the shadow pattern and reducing brightness somewhat too.
So:
  • Put the SkullCap slightly over the head, such that the hair fits the head while the cap warps shadows onto the head
  • For the cap, set Visible in camera OFF, give it a dull black material and assign a hair-shadow map to transparency such that the cap is opaque where you want shadows on the head.
  • For the cap, set Transparency_Falloff to 0.0 or raise it, put scatter on the cap at will and so on affect the shadowing on the head somewhat. Or leave it all and let the hair-shadow map do the work.
Now the scatter on the head itself might produce some red or cyan artefacts, but that's something entirely different. Custom_Scatter offers uncolored scattering instead.
happy Posering.
Believable3D ( ) posted Wed, 20 August 2014 at 9:14 AM
Thanks, aRTbee. You're right about Transparency_Falloff ... hadn't noticed that was at 0.6. If that's contributing, that's a good thing, since it's something I can control the amount of—different amounts for darker or lighter hair.
But nonetheless it still does not make complete sense.
For one, if there is no skullcap and the hair groups are parented directly to the figure's head, the hair should be providing shadowing on the head ... but it does not. Is all the shadowing here completely illusion? If so, why does the hair not cast shadows onto the scalp? I always have casts shadows set to on.
Meanwhile, I've got more experimenting to do....
______________
Believable3D ( ) posted Wed, 20 August 2014 at 9:23 AM
As I reread you're post, I don't think you're replicating my settings. I do not have Cast Shadows on for the Skullcap, so that is not where the shadowing is coming from. It's the only thing I never put Cast Shadows on, and the reason is basic. I don't want shadowing along the edge of the cap where it is not absolutely 100% snug with the head.
Here's an image with the settings I've actually been using.
______________
Believable3D ( ) posted Wed, 20 August 2014 at 10:00 AM
My further experiments indicate that none of the colors in the skullcap materials matter to the render. In my current render, I set all of them, including the transparency background colour, to a very pale blonde, and the render is identical to the previous render. So the question is, where is the shadowing coming from, since the skullcap is not set to cast shadows? Why in this particular circumstance does Transparency Falloff have any effect at all, and what exactly is it picking up?
______________
Believable3D ( ) posted Wed, 20 August 2014 at 10:14 AM
Well ... I set Transparency_Falloff to 0, and I'm still not getting your results. It still renders with the shadowing. So I think we need another explanation.
______________
Believable3D ( ) posted Thu, 21 August 2014 at 5:00 PM
Well, I think I've identified the difference in my experiments. I assigned materials to the hair growth groups when I originally did grouping in the Hair Room. I do not have those materials set to transparent, although Diffuse etc are 0. With Light Emitter set to On for the skullcap, that "kicks in" and provides the shadowing we hadn't been able to account for, although to be honest I'm still not 100% sure *exactly* what it's doing.
______________
Believable3D ( ) posted Thu, 21 August 2014 at 5:56 PM
This discovery really helps, because now I have access to settings that can attenuate the effect. What I'm doing now is plugging an Edge_Blend node into the Alternate Diffuse for these materials. Results pending, but so far things are looking very promising.
______________
Believable3D ( ) posted Tue, 26 August 2014 at 2:00 AM
The Edge_Blend experiment didn't work, so far as I can tell, but I'm pretty sure I didn't use it properly.
Anyway, I learned that under the Env Sphere with high quality IDL settings, what previously looked like artifacts above no longer does so. I may have to experiment again with indoor settings and see if high enough IDL quality fixes it there too.
I almost don't need the faux shadowing here, although it's still on. I added an additional short hair group hugging the scalp next to the part to make things look better.
______________
