Sat, Feb 15, 8:26 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 14 10:57 am)
Subject: Conforming Woes!! :-/
wolf359 ( ) posted Sun, 14 April 2002 at 6:41 AM · edited Sat, 15 February 2025 at 8:20 AM
Will poser clothing ever properly conform??
I have many Conforming clothing items both commercial and free
the option of turing off visibility of body parts works great if you plan on
only rendering stills in poser. BUT I animate in poser and render the animations
IN the true raytraced 3D environment of Cinema 4DXL7 so the skin poking
through will be visible in poser especially in animations
i should mention that the free stuff from THIP for mike never has this problem
( thanks THIP!!)
but many DAZ items do poke through and it very frustrating to have a cool outfit
that fits the requirement of my film project and discover it will be almost useless
without major compramises in my camera angles to hide the poke throughs.
and i really have no interest in hearing about applying some elaborate magnet setup
before i can even begin animating.
I really hope poser 5 addresses this!!
My website
Little_Dragon ( ) posted Sun, 14 April 2002 at 6:55 AM
Can you delete all the mesh parts that are supposed to be invisible? They won't poke through if they aren't there. In Poser, when I export a character to .obj format, for instance, any body parts with visibility turned off don't go along for the ride.
wolf359 ( ) posted Sun, 14 April 2002 at 7:09 AM
"In Poser, when I export a character to .obj format, for instance,
any body parts with visibility turned off don't go along for the ride."
That does not work for importing animations VIA the propack plugin
I Really wish I had time to learn to make my own conforming clothing
obviously Some people have determined how to do it properly
My website
MadYuri ( ) posted Sun, 14 April 2002 at 7:32 AM
There is always the option to apply a transmap to the figues. Nothing fancy, only a black/white image to make the troublesome spots transparent. BTW if you make a bodypart invisible with the hierachy window it should be invisible in C4D too. It works for me.
saxon ( ) posted Sun, 14 April 2002 at 7:33 AM
I think the problem comes from there being so few of us. It's nice to be unique but when it comes to beta testing these things, well, the majority use Poser for stills. I've never beta tested anything to check whether it works for an animation and I haven't heard of any others doing so. I felt exactly the same frustration when Daz released the high res maps for Vicky. OK, they just about do work for a single render but when it came to multiple renders for an animation either it crashed the thing eventually or I'd have had to allow about a year for render time and radiosity, when it came to creating the criteria for that, I wish the developers had considered a lower light count alternative. When (if ever) version 5 does eventually crawl out of the labs I hope they don't chuck away the fast render engine completely, I don't have a spare lifetime to wait for a full dress rehearsal render if it's going to be as long as Lightwave or Bryce. It's not as though we're exactly an unapproachable lot, or a clique. Maybe we should abandon the animation forum and talk more in here about our woes......
saxon ( ) posted Sun, 14 April 2002 at 7:40 AM
If I read you right Wolf, you're not looking for solutions (you're probably aware of them anyway) but just having a grumble.... It is frustrating to have to spend another hour or so setting up just to fix glitches like these and even more frustrating when you think you've fixed the thing only to see an error on frame 105.....
aleks ( ) posted Sun, 14 April 2002 at 7:51 AM
wolf, go back to black text. i can't light green on light gray... :)
saxon ( ) posted Sun, 14 April 2002 at 8:19 AM
Aleks, did you know you can change the way Renderosity looks for you by checking out your profile......
wolf359 ( ) posted Sun, 14 April 2002 at 8:23 AM
*"BTW if you make a bodypart invisible with the hierachy window it should be invisible in C4D too. It works for me."* Even when you import Via the propack hosting plug?? i will have to try again on that one.br> br> Hey there Saxon! I whole heartedly agree that most of the clothing is probably never tested for animation here is a still frame from an animation on my website. mike is wearing the basic bodysuit from the "Clothing pack1" i purchased from DAZ right after buying mike. this is a simple run cycle made with walk designer and mike is in is default state *( morph DIALS untouched)* note how the DAZ item pokes through at the thighs but ironicly, the light brown thigh boots from freestuff never have a single poke through!!
I may put my film on hold to learn how to make animatable conformers myself
My website
saxon ( ) posted Sun, 14 April 2002 at 8:39 AM
Bummer! That's another thing, Mike's hands. The troubles I've had with those. I use the Poser 4 lo res figure to sketch out my animation and then bring Mike in. Everything follows well but the hands are always in the default state....
Alleycat169 ( ) posted Sun, 14 April 2002 at 9:14 AM
No offense Wolf359, but I can't read your text at all. Between the neon colors against my slate blue background, and your tiny italicized fonts, I can hardly make out a word of it. What's wrong with standard text color and font size?
aleks ( ) posted Sun, 14 April 2002 at 1:37 PM
saxon, that's exactly why i can't read wolf's text. i have my background as light grey. green is not readable on grey.
wolf359 ( ) posted Sun, 14 April 2002 at 2:11 PM
Sorry Aleks, here is an example of what im talking about these FREE conforming items were made by THIP ( the mutistrand hairpeice by Customedia) note how there is no poke through even in this exaggerated pose. thank god for thips free stuff :-)
My website
aleks ( ) posted Sun, 14 April 2002 at 2:16 PM
yes, i couldn't agree more with mad yuri. i always do that. if it's impossible to hide body parts, they get fine, thick, black trans map... :) and, of course, thip IS good!
williamsheil ( ) posted Sun, 14 April 2002 at 3:43 PM
I've had these problems ever since I began animating. My Solution? Bite the bullet and animate the clothes scaling, or add a magnet to the offending area of clothing and animate it to pull the clothes from the skin in the offending frames. Of course you have to go through all the keyframing/spline breaks etc to make it work right, but, for me, that's always been just another part of the process.
saxon ( ) posted Sun, 14 April 2002 at 3:48 PM
My solution was to say 'sod the clothes' and go into porn....
Ghostofmacbeth ( ) posted Sun, 14 April 2002 at 3:51 PM
I think the biggest reason for no problem with Thip's stuff is that is all is rather baggy. Not that baggy is a bad thing at all :)
aleks ( ) posted Sun, 14 April 2002 at 4:06 PM
lol @ saxon
thip ( ) posted Sun, 14 April 2002 at 4:35 PM
Just for the record : thanx for the praise, Wolf, and you're right, Ghost. Most of my freestuff is rather baggy clothing items, such as jackets and parkas. Trans maps are really the only solution UNLESS you set up the figure-with-clothes as one figure, like the clothed standard P3 figures. You can do this by exporting figure and clothes from the base OBJ's, removing all non-supposed-to-show material in an OBJ-capable 3D app, bringing the figure back in, and using Pro Pack or CR2 hacking to set it up as a new figure. Have fun, thip
cliffwms ( ) posted Sun, 14 April 2002 at 6:40 PM
It certainly is ironic that I have been experiencing ?poke through? with the Mike Suit Pak. I just been tweaking the model to eliminate the poking since getting the package. Then just today I receive an email from DAZ to download a Suit Pak update for the object file. This make the third update I have received. Is there something going on that I do not know about?
wolf359 ( ) posted Sun, 14 April 2002 at 7:01 PM
HMMMM Speaking AS a merchant with items in the marketplace here
if one of my BVH files made vickies head do a 360 degree spin
i am trying to imagine telling my buyers to "Bite the bullet"
open the graph editor and fix it themselves.
My website
MadYuri ( ) posted Mon, 15 April 2002 at 1:30 AM
I think it is impossible to have thight fitting clothes without poke through in some poses. The figure and the cloth have different meshes and those bend differently. Without collision detection those meshes will sometimes intersect. And collision detection is probably too time-consuming for animation anyway.
thip ( ) posted Mon, 15 April 2002 at 3:27 PM
I think you're perfectly right, Yuri. That's why I recommend "re-packaging" a clothed figure as one figure-and-clothes figure as suggested above. If you prefer not to do figure setup as such, exporting the clothing parts one by one, re-importing and using "replace body part with prop" can do a fine job in most cases. I know it's an extra chore, but animation is such a demanding task anyway, so a few hours extra probably won't kill the "time budget" ;o)
Uzilite ( ) posted Tue, 16 April 2002 at 9:01 AM
Hi If you are using other 3D application to render your animation you can create new material maps. I don't know C4D very well, but in Lightwave I'd open the exported obj file. Then I'd select the offending body part and create new material which I then set to transparent. In Lightwave it is very easy to do, a matter of selecting polygons almost like the grouping tool in Poser. Also, MadYuri is correct, Poser will not export body parts which has its visibility turned off via the hierarchy setting window.
