13 threads found!
Sentenza | 10 | 308 | ||
Sentenza | 4 | 100 | ||
Sentenza | 7 | 144 | ||
Sentenza | 16 | 355 | ||
Sentenza | 3 | 91 | ||
Sentenza | 5 | 90 | ||
Sentenza | 2 | 118 | ||
Sentenza | 1 | 76 | ||
Sentenza | 4 | 124 | ||
Sentenza | 4 | 202 | ||
Sentenza | 5 | 169 | ||
Sentenza | 19 | 402 | ||
Sentenza | 5 | 32 |
9 comments found!
Thread: How to unhide x-, y-, ztran dials? | Forum: Poser - OFFICIAL
Works!!! Cool, thanks! Does this work for the Joint Editor, too? I got a model where the options to tweak the bend etc. settings don't show in the Joint Editor, although they are activated in the model itself...
Thread: How to switch off the red outlines, when posing a figure? | Forum: Poser - OFFICIAL
Just found something out, myself: If you choose "Color" in the toolbar, and do deformation then, the outlines are gone! The other trick with the poser.ini also works fine, thanks for the hint!
Thread: Turning off Selected Object highlighting | Forum: Poser - OFFICIAL
Thread: Python Script to apply Partial Joint Settings from one cr2 to another? | Forum: Poser - OFFICIAL
...well, could you give me a hint on what to delete in the cr2 editor? tried to trim down to the actors row, but did not really work out...?!
To Cage: yeah, the V3 clothing conformer was what I had in mind! I'll try the solution you just suggested, thanks a lot!
Thread: How to edit Poser 5 *.crz files manually? | Forum: Poser - OFFICIAL
It works! I renamed the result to *.cr2 and there we go... ...just found out it can also be done by just resaving the figure with "compressing files" disabled, we get the regular *.cr2 file. Thanks for you hint!
Thread: Adding more bodyparts to an existing character: My Problem!!! | Forum: Poser - OFFICIAL
To PhilC: Could you assemble a short tutorial how you did for example the other right arm of your figure? I guess from there I should be able to understand the steps necessary! Thanks a lot, LeeJ
Thread: How to get SPOT lights to cast shadows ???????? | Forum: Poser - OFFICIAL
Yeah! It works with the increase of "MAP SIZE"! I have to use spots, because I want to do some closed room renders, now it's OK! Thanks a lot, Sentenza
Thread: How to get rid of Full-Body-Morphs in cr2's and how to copy them? | Forum: Poser - OFFICIAL
