11 threads found!
beonalert | 5 | 178 | ||
beonalert | 13 | 357 | ||
beonalert | 5 | 114 | ||
beonalert | 12 | 413 | ||
beonalert | 10 | 243 | ||
beonalert | 2 | 288 | ||
beonalert | 1 | 101 | ||
beonalert | 15 | 243 | ||
beonalert | 13 | 244 | ||
beonalert | 6 | 152 | ||
beonalert | 11 | 186 |
25 comments found!
OK I'm back. So I now have Poser 6.....nice! I apply the textures to Ezster manually in the materials room, no problem. Her face still looks a little plastic and not quite matching the rest of the body so I'm wondering if there are other settings I need to look at. I'm getting closer but not quite there yet.
Thread: Eszter users out there? I have a question | Forum: Poser - OFFICIAL
ah, well I'm using P4 at the moment (will be upgrading to P6 in another 2 to 3 months) so maybe that's the problem. Although the product description doesn't mention anything about it not being P4 compatible (except for specular maps). Maybe I need to contact the vendor. Thanks!
Thread: Poser and photoshop layers | Forum: Poser - OFFICIAL
Got it! Works nicely! Thank you EVERYONE who took the time to answer my post. I love this forum! Give me a day or two and I will post the pic that inspired this post in the first place. Thanks again everyone!
Thanks for all the tips, but I think I am missing a step. When I click the alpha channel on my foreground, it selects my figure. Then I drag the channel to my background pic. What I get is a solid white representation of my figure. Then what? Do I drag my foreground pic over again on top of that white channel or is their an adjustment I need to make to the layer once it's added to my background pic?
Thread: Issues with loading a 2nd figure | Forum: Poser - OFFICIAL
The null solved my problem from the original post. Are you selecting "BODY" on the Null object before loading your Vicky figure? I am using V3 so maybe there is a different issue with V2.
Thread: Sydney Bristow - Jennifer Garner - Alias - V3? | Forum: Poser - OFFICIAL
Grey cat, Kevschmev and Ariah, All EXCELLENT work....especially considering you had about 48 hours. They are all great characters. Are any of you interested in making these inj/rem files available? Either as freebies or as purchases? I would love to add them to my growing collection of characters. The work is very stunning.
Thread: Asian texture for V3 | Forum: Poser - OFFICIAL
Yeah, BellaRane looks good but that 700Mghz requirement is a killer for me as I am only 600Mghz. Maybe it's time to upgrade?
Thread: A little moan | Forum: Poser - OFFICIAL
I'm on a Mac but I use the freebie "Graphic Converter" and, so far, it works like a charm. You can batch convert too so it makes converting several files a one step process. Having said that, I do agree that most of the best textures I've seen (Morris comes to mind) don't use bumpmaps, so I'm not sure what the benefit is.
OK, I was hoping I wouldn't have to ask but....what is a null? I mean, I know what null is.....it's nothing. But in Poser terms, what is it?
Thanks all. Someone had mentioned exporting one of the figures as a wave.obj and then reimporting it. This would not only help with crosstalk, but it helps on saving memory. I tried it, and it worked except for the the hair and the transmaps came out all funky.
Thread: Blurring in Poser | Forum: Poser - OFFICIAL
Wow! Thanks for all the help. You've all given me a couple of choices on this procedure. Thanks for taking the time!
Thread: Can't See Icons for a Pose package | Forum: Poser Technical
I contacted the vendor and figured out the problem. Something went whacky in my unzip process and I only got the ProPack version of the files. So after downloading a 2nd time and using Stuffit, I found the P4 specific files which did, in fact, contain the rsr files. Sorry to waste everyone's time but I learned a lot, so thank you all!
I received the solution from another board. I will post it here in case anyone else runs into the same problem. Since the poses themselves work, simply load the pose onto a Character and make sure the window is square (400x400 or 800x800) and then save it as a new pose with the same name. This will replace the old pose but it's still the same pose and it will automatically create the icon.
