47 threads found!
bigdave1960 | 3 | 135 | ||
bigdave1960 | 8 | 1358 | ||
bigdave1960 | 70 | 2368 | |
bigdave1960 | 3 | 186 | ||
bigdave1960 | 11 | 200 | ||
bigdave1960 | 0 | 128 |
(none)
bigdave1960 | 3 | 358 | ||
bigdave1960 | 1 | 193 | ||
bigdave1960 | 23 | 449 | ||
bigdave1960 | 9 | 250 | ||
bigdave1960 | 4 | 173 | ||
bigdave1960 | 10 | 287 | ||
bigdave1960 | 7 | 171 | ||
bigdave1960 | 2 | 80 | ||
bigdave1960 | 5 | 129 |
80 comments found!
Thread: object locked from export | Forum: Vue
The reason i wanted to do this was i wanted to try to render this figure in 3dmax just to see the differences between pose,vue and 3dmax render , but any file format ive tried to export from poser dosnt seem to want to open in 3dmax so thats when i thought may be i could export from vue instead and the found i couldnt hope that explains what seems like an odd thing to do
Thread: Apollo Maximus | Forum: Poser - OFFICIAL
Thread: water without eco plants in it | Forum: Vue
Yes that works rather foolish of me not to realise that water counted as a foreign object! thanks
Thread: How do i get rid of the box style display | Forum: Vue
Thread: unable to reinstall vue 7 infinite | Forum: Vue
Ok Ive fixed it now I think it was somthing to do with the updates , once i removed all the folders and traces of vue 7 it reinstalled ok
Thread: making ice in vue | Forum: Vue
Thread: where do the rendered animations end up in vue? | Forum: Vue
Bear in mind i have a dual boot system with 2 hard drives one called vista 32 the other called vista 64 i use the 64 bit system for rendering this is the exact file path on my system
C:usersvista 64picturese-on softwarevue 7 xstream  there is also one with the following file path for vue 6 infinite
C:usersvista 64picturese-on softwarevue 6 infinite
Thread: poser eye maps generation 4 | Forum: Poser - OFFICIAL
this is what you get in the read me
How to use the Reflection Masks:
First load the reflection method/map you would like to use.
Please note that a basic mask will already be loaded.
Next, choose an eyelid/lash mask that best suits the location just under the eyelid where you would like to block the reflection.
Load the mask.
If your eyes are posed side-side, reveal the "twist" dial on the eyes and rotate them into the best place.
Note that in DAZ|Studio this is accomplished by checking the "show hidden properties" box.
It helps to make the Eye Surface temporarily opaque at this point (in DAZ|Studio, make opaque and add the mask to the color channel), and then change back to original settings when posing is complete.
In Poser 5 and up: The MAT pose files for the Masks are partial files and will disconnect the bump map node. It simply needs to be re-plugged in. This problem is inherent to Poser and does not happen in DAZ|Studio.
A lot of original photography was taken for this set, please do not violate artist copyright by reproducing the imagery in any way.
Ive had a look ive not realy used the materials room much not sur whats supposed to be where a screen shot may be useful
Thread: unconform poser with out it moving | Forum: Poser - OFFICIAL
Thread: snap to python script | Forum: Poser - OFFICIAL
ive gotten it fixed now thanks, Ihave another pc with PP on and found it had MSVCR71.dll in runtime/textures/!DAZ so i copied that into the one on the pc that wasnt working and it replaced it and works fine now .all other python scripts were working ok any way . your advice and help is much appreciated.Ive no idear what happened maybe the dll got corrupted but any way its fixed now , so once again thanks for your help its nice to know that some one is prepared to go to the time and trouble to help out.
Thread: flight suit for modern jetplane | Forum: Poser - OFFICIAL
