4 threads found!
johnkramar | 1 | 20 | ||
johnkramar | 4 | 18 | ||
johnkramar | 5 | 100 | ||
johnkramar | 3 | 71 |
5 comments found!
e is usually defined by the equation:
e = limit of (1 + 1/n)^n for n from zero to infinity
The number e was first studied by the Swiss mathematician Leonhard Euler in the 1720s, although its existence was more or less implied in the work of John Napier, the inventor of logarithms, in 1614. Euler was also the first to use the letter e for it in 1727 (the fact that it is the first letter of his surname is coincidental). As a result, sometimes e is called the Euler Number, the Eulerian Number, or Napier's Constant (but not Euler's Constant).
An effective way to calculate the value of e is not to use the defining equation above, but to use the following infinite sum:
e = 1/0! + 1/1! + 1/2! + 1/3! + 1/4! + ...
ref: http://mathforum.org/dr.math/faq/faq.e.html
Thread: [Image]-"In a galaxy not so far away" - Tie Interceptor | Forum: Carrara
Thread: Dowloaded Bryce .odp files fail format check | Forum: Bryce
Thread: Light Saber Tutorial | Forum: Carrara
Great tutorial -- one question: How do I turn on the 3D Aura I for one would appreciate some tutorials on building texture maps. I found the one included with the Light Saber tutorial enlightening. Cheers,
Thread: Boolean operations in the vertex modeler | Forum: Carrara
Thread: what is E in formulas? | Forum: Carrara
