1 threads found!
solemnchaos | 2 | 100 |
20 comments found!
Thread: Attention all Renderosity artists!! | Forum: Community Center
"Yes, Renderosity has my permission to use my artwork from my art gallery for promotional use only".
Thread: Plantstudio to Vue | Forum: Vue
Attached Link: http://www.uvmapper.com/
If the plants don't import correctly into Vue (which happens a lot to me), it is sometimes helpful to open them in uvmapper (classic or pro) first and resave them. Uvmapper created .obj files seem to be more easily imported in to other programs. www.uvmapper.comThread: Thumbnail help | Forum: Vue
Attached Link: http://www.irfanview.com
If you don't have an image editor, I'd recommend downloading Irfanview. It's free and very useful. You can use it to resize your image for a thumbnail, and it will also allow you to compress your .jpg further to reduce file size.http://www.irfanview.com
Thread: Update numbers confusion | Forum: Vue
Lyne,
to find the exact version you are using, choose 'about' from the help menu in Vue. A box will pop up with the version number (including the exact build number).
Thread: How to create a texture map | Forum: Vue
Attached Link: http://www.solemnchaos.net/tutorials/vuecoffeepot.html
Glad I could help. I've actually clarified it and fixed some problems and added it to my website: http://www.solemnchaos.net/tutorials/vuecoffeepot.htmlThread: How to create a texture map | Forum: Vue
Hope that helps,
solemnchaos
Now remember where you wrote down the picture scale, picture offset, and mapping information? Change the values in the function editor to match what you wrote down.
Right click the sphere picture in the underlying material window and choose edit material. Then choose the white porcelain material (it's in the basic section).
Now right click the sphere picture in the transparency production box and select 'edit function' (or just ctrl-left click).
In the effects box (upper right), choose 'world-cylindrical' mapping. Then in the mapping box (lower right), choose 'cylindrical'.
In the picture scale and offset boxes, I found it was just a matter of trial and error to position the picture. Make a change then watch your main camera preview (click on the preview to force it to update if needed). I suggest scaling it first, then using the offset to position it.
Write down the settings you chose for picture scale, picture offset, and mapping (you will need them for the transparency section).
First, select just the coffeepot section of the coffeepot (see the pic...it's the cylindrical center part of the coffeepot object ).
Then double click the picture of the material at the top to enter the material editor (or right click and choose edit material).
Thread: jpg question... help??? | Forum: Poser - OFFICIAL
IE6 resizes images by default. Go to Tools..Internet options...advanced, then scroll down to the multimedia section and make sure 'enable automatic image resizing' is NOT enabled. This option causes the most problems with images that are larger than your screen resolution.
solemnchaos
Thread: Strange Transparency Rendering | Forum: Vue
Attached Link: http://www.3dmenagerie.com
I had the same problem importing the pz3, but was able to get it looking ok with obj import (after playing with the transparency settings of the juice and glass in the material summary).For those wondering where the drink is located:
(in the goodies/ poser section)
solemnchaos
Thread: Crashes | Forum: Vue
At least for me, Vue 4.03 is actually more stable than Windows ME:} Haven't had any crashes while running Vue.
Thread: a message to Varian... | Forum: Vue
Attached Link: http://www.zenstar.com/
Here's a link to the official Plant Studio page; it's great for plants, but not for trees: http://www.kurtz-fernhout.com/PlantStudio/index.htm I really enjoy using TreeDruid for trees: http://www.zenstar.com/ Neither program will help you very much with textures. solemnchaosThis site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Thread: Color Picker - Need to change it! | Forum: Bryce
