Wed, Feb 26, 12:36 AM CST
Renderosity Forums / Poser Python Scripting
Welcome to the Poser Python Scripting Forum
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2025 Feb 05 6:41 am)
We now have a ProPack Section in the Poser FreeStuff.
Check out the new Poser Python Wish List thread. If you have an idea for a script, jot it down and maybe someone can write it. If you're looking to write a script, check out this thread for useful suggestions.
Also, check out the official Python site for interpreters, sample code, applications, cool links and debuggers. This is THE central site for Python.
You can now attach text files to your posts to pass around scripts. Just attach the script as a txt file like you would a jpg or gif. Since the forum will use a random name for the file in the link, you should give instructions on what the file name should be and where to install it. Its a good idea to usually put that info right in the script file as well.
Subject: Moving morphs between different figures
Spanki ( ) posted Sat, 29 March 2008 at 4:41 PM
And yeah, I don't have any current plans for doing that GUI stuff in the .pyd, so there's still plenty of room for python code :).
Cinema4D Plugins (Home of Riptide, Riptide Pro, Undertow, Morph Mill, KyamaSlide and I/Ogre plugins) Poser products Freelance Modelling, Poser Rigging, UV-mapping work for hire.
Spanki ( ) posted Sat, 29 March 2008 at 4:47 PM
Quote - ...snip...For the time-being, you should not pass the (optional)  'texpolylist' to the TriPolygonize() routine, or count on those elements being correct in tripolys unless you know that the entire mesh in question is fully uv-mapped.  The indices found in the Ngons (if not set to 'None') should be correct though.
I take (part of) that back... just to clarify, if you are using the MeshType interface to get your TriPolys, then the uv0, uv1, uv2 members of the TriPoly will either be correct, or all set to 0.
If you're using TriPolygonize() and pass in the optional 'texpolylist', there's a potential for crashing (or at least causing an exception).
Cage ( ) posted Sat, 29 March 2008 at 6:37 PM
I'll avoid the texpolylist stuff then, for the time being.
I'm having a bit of luck with this spring system implementation, finally.  Check out the attached image.  Did I make that square all cloth-y in the cloth room?  Nope!  I used Python and the _tdmt.pyd!
I'm still struggling a bit with collision implementation, however....
Spanki ( ) posted Sat, 29 March 2008 at 6:46 PM
Hey, that looks pretty darned cool! ;).
I breifly looked at your cloth/bouncy script above... and had some problems with it (had to reduce the step-size from 10 to 1 for my faster machine, for one thing :) ), but I didn't spend enough time with it to figure out what all the issues are.  I managed to get the ball to collide with the floor (instead of passing through it), and it bounced back up, but some of the verts stay on the floor, so it eventually mangles itself up pretty bad.
Cage ( ) posted Sat, 29 March 2008 at 8:36 PM
The bouncy script was broken.  Basically, I didn't understand how he was doing things; I only knew how to translate his bits to Python.  I'm getting closer.  Now I have collisions (albeit slightly hackish ones).  The "soft bodies" aren't working, although cloth is.  Perhaps someone can take a look at it when I post the script, later tonight, and see if they can envision a decent collision loop that could work with the simulator.  The original C code uses while loops three deep, and it has me all mixed up.  Hard to debug that sort of thing, because Poser keeps getting caught in infinite while loops.  Sigh.
Here's another, higher res square, colliding with a cube.  Firefly doesn't like to render smoothing and shadows on these, unfortunately, so no shadows....
Cage ( ) posted Sun, 30 March 2008 at 12:09 AM
file_403078.txt
Okay.  Here's the current version of the script, for anyone who's interested (which means, basically, me...).  There are basic instructions in the comments at the top of the script.
Cage ( ) posted Sun, 30 March 2008 at 12:11 AM · edited Sun, 30 March 2008 at 12:12 AM
file_403079.txt
And here's a prop set, including my testing cloth patch, two boxes to show how to "pin" selected vertices, and a box against which to collide.  Change the extension to .pp2 and open it from the Poser library.
Cage ( ) posted Sun, 30 March 2008 at 12:14 AM
And just because I'm carried away... a test render, draped over a torus.
Cage ( ) posted Sun, 30 March 2008 at 12:16 AM
Finally, a test of my idea for converting object normals to gravity, to shrink the cloth inward against an object.  It basically works!  Surprisingly.  Actually, it's surprising when anything Cage does works....
The script above has instructions for setting up this effect.
Spanki ( ) posted Sun, 30 March 2008 at 1:50 AM
hmmm....
def normToForce(mesh,intensity):<br></br>
 """Convert normals to force
information"""<br></br>
 if intensity !=
0.0:           #
shouldn't this be...<br></br>
  for vi in
range(len(mesh.particles)):   # swapped with this
line?<br></br>
   norm = mesh.vnorms[vi]<br></br>
   mesh.particles[vi].f = norm.Scale(1.0/intensity)
#?<br></br>
  else:<br></br>
   mesh.particles[vi].f = Vector()<br></br>
...and...
def normToGravity(mesh,intensity):<br></br>
 """"""<br></br>
 if intensity !=
0.0:         # shouldn't
this be...<br></br>
  for vi in range(len(mesh.particles)):  # swapped
with this line?<br></br>
   mesh.particles[vi].gravity =
norm.Scale(1.0/intensity)<br></br>
  else:<br></br>
   mesh.particles[vi].gravity = Vector()<br></br>
   mesh.particles[vi].oneOverM = 0.0<br></br><br></br>
...see the # comments, above.
Cage ( ) posted Sun, 30 March 2008 at 1:59 AM · edited Sun, 30 March 2008 at 2:09 AM
file_403082.txt
Well... I guess it could be swapped.  It needs to just globally prevent that case from occuring, doesn't it?  So it won't reset the normals if intensity is zero, and we'll keep the regular normals.  Hmm.  Hadn't thought about it, actually....  As is, it prevents the loop from starting in the case in which it would try to do something which would crash each....
I'm babbling, aren't I?  I may have screwed the tabs up when I converted from spaces to tabs.  The else pertains to the global if at the opening.
Oh, bugger.  I just checked, and the spaces to tabs script broke it.  Sorry.  Here's a correct one - but you'll have to suffer through spaces again.  :(
Edit.  Nope, you were right.  I had it wrong in the clean copy, too.  Huh.  Thank you.  The question is, why did the function still work when I called it, with wonky syntax like that?  Hoofa....
Spanki ( ) posted Sun, 30 March 2008 at 2:04 AM
I didn't really look at what it was trying to do.. just the syntax ("if: , else:" should be inside "for:" loop). :)
Spanki ( ) posted Sun, 30 March 2008 at 2:11 AM
...also, you should (now) be able to replace tests like this:
    if (abs(vec.x) > FLT_EPSILON) or (abs(vec.y) > FLT_EPSILON) or (abs(vec.z) > FLT_EPSILON):
..with just:
if vec:
Cage ( ) posted Sun, 30 March 2008 at 2:13 AM
file_403090.txt
Oh, man!  Okay, I'm out of editing time.  Here's a fixed fixed fixed version.  And Cage needs to go to bed now, because he's dumber than usual and pleads sleepiness.  😊  Cough.
Thank you, Spanki!  :D
Cage ( ) posted Sun, 30 March 2008 at 2:14 AM
Thanks for the heads up on the if vec.  :D  I had asked about that, you answered, and I knew I could use it now.  I've just been focused on WHY THE SILLY SPRINGS WOULDN'T WORK, y'see, so I kind of neglected a lot of other brainy-think-y type stuff.  Sigh.
Spanki ( ) posted Sun, 30 March 2008 at 2:18 AM
no problem... was just reminding, in case I hadn't mentioned it yet.
Cage ( ) posted Sun, 30 March 2008 at 2:20 AM
I think you put it in one of the very early .pyd updates, didn't you?  It's been a week or more since, but I think it was covered up above somewhere.  Always good to have reminders, though.
Cage ( ) posted Tue, 01 April 2008 at 2:22 PM
Have I killed the thread again, like I did with my long digression into UV handling?  😟
Miss Nancy ( ) posted Tue, 01 April 2008 at 6:30 PM
not dead, just resting.  :lol:
wanted to mention my gratitude to cage, spanki et al. for their work on this.
I have tried some of the scripts in OS X and am impressed with their capabilities.
Spanki ( ) posted Wed, 02 April 2008 at 5:12 AM · edited Wed, 02 April 2008 at 5:15 AM
Quote - Have I killed the thread again, like I did with my long digression into UV handling?  😟
Nope, just the aforementioned planned absense (other obligations).  Here's a new one to tide you over a while...
Update: 03/30/08 (search on: "03/30/08" to see changes)
First off, a word about direction... as might be gleaned from recent developments within the class, my plan is to move away from the old 'Polygon List' and only develop new functionality based on the newer class. For the script writer, this typically adds one additional line of code to get to the vertex indices...
poly = polylist[i]
...becomes...
ngon = ngonlist[i]
poly = ngon.vertIndices
...or even just...
poly = ngonlist[i].vertIndices
...but that extra effort also gives you easy access to the other Ngon members (it's normal, plane equation, uv indices) - all in one place - so you don't have to manage 4-5 different lists of data for every polygon.
This (and use of the class in general) also helps me keep track of things internally, because (for example) the TriPolys can be directly generated from Ngons, instead of having to track and pass around 4-5 lists of data to create them (it also lets me make certain assumptions about the validity and formating of the data in many cases, reducing the amount of error and range-checking bloat in the code).
In short... the various old 'Polygon List' routines might (or might not) remain available, but my advice would be to try utilizing the instead. The routines I'm referring to are:
psrPolygonList() -> mesh.GetNgons() /
psrNgonList()  (new)<br></br>
psrTexPolygonList() ->
ngon.texIndices
(member of NgonType)<br></br>
TriPolygonize() -> mesh.GetTriPolys() / TriPolysFromNgons()
(new)<br></br>
PolyFaceNormals() ->
ngon.normal
VertexPolys() -> mesh.GetVertNgons() / VertexNgons() (new)<br></br>
PolyVertexNormals() ->
mesh.GetWorldNormals()        (stand-alone
routine to come)<br></br>
...once I have suitable Ngon replacements in place for the above (which I mostly already have), the above routines (left-most column) hit the endangered-species list :).
[NOTE: rather than try to use the stand-alone functions, it's recommended to use the MeshType class, which does a lot of things like generating Ngon and tripoly face normals for you automatically. (ie. if you do: 'ngons = mesh.GetNgons(geom)' then the normals and plane equations (and tex indices list) of the Ngons are already filled in - if you call the new stand-alone 'ngons = psrNgonList(geom)' instead, the tex indices list is filled in, but the normal and plane members are not]
Individual updates list:
  • added psrNgonList()
  • added TriPolysFromNgons()
  • added VertexNgons()
  • added mesh.GetVertNeighborsByNgons()
Cage ( ) posted Wed, 02 April 2008 at 1:47 PM
Whoa!  More new stuff!  :D  :D
I started to adapt my WIP testing script to the new Mesh type, but ran up against the fact that it's read-only.  Which is probably a good thing, except that I've been using the mesh class instances to store additional data beyond what we're handling in the pyd.  Which means I need to change my approach somewhat, and end up with a pyd Mesh instance running alongside a class container which will operate for the other things.  Since that involved some major restructuring, I set it aside for a bit.  But I think I should probably go ahead and make those changes, to get a sense of how this new and apparently preferred approach will work.  I like the look of things in the pyd_shrinkwrap_test script.  Very clean and concise!  :D  :D
Thank you for a vertex neighbors function!  Woot!  I find that to be very useful, at times....
Spanki ( ) posted Wed, 02 April 2008 at 2:18 PM
file_403358.txt
Yeah, I saw that you were trcking some additional data per mesh... what I would probably do is just wrap your myMesh around the MeshType, so the MeshType pointers just become new members of your myMesh class.  Either that, or just create a new / separate class to hold the other data (particles, springs, inc_screen, etc.).
I'm also considering adding a few 'userdata' type members, which would allow you to store whatever you want in the MeshType.
BTW, I had added a few comments to one of your earlier scripts (attached), just search for 'Spanki' to see them.. nothing major, just a few comments/tips.
Spanki ( ) posted Wed, 02 April 2008 at 2:26 PM
re: on the oneOverM thing... I see from the comments that the 'M' actually does stand for Mass, but I haven't researched exactly how it was being used in the original C code (and wouldn't want to hazard a guess), so don't take my comments in there too literally... unless it can always be multiplied by (which may not be the case).
Cage ( ) posted Wed, 02 April 2008 at 2:53 PM
The source C++ code is extremely ambiguous on certain points, one of them being exactly what oneOverM represents.  I'm not exactly certain.  I only know that he receives the value from the GUI, where it seems to be preferred to have it clamped between 1.0 and 0.0.  Whether that represents mass or some pre-altered value related to mass, or something else altogether, I don't know.  I've retained his variable name with oneOverM, however, so presumably the name itself is some sort of indicator of what it is....
I was thinking about embedding your Mesh type in my container.  I'll try that, then!  :D  This seems like a bit of a serious paradigm shift, regarding the general approach we've had since the start, but I think I can see how it will be beneficial.  Among other things, I expect it to make calling up multiple actors easier.
Cage ( ) posted Wed, 02 April 2008 at 3:07 PM · edited Wed, 02 April 2008 at 3:10 PM
Y'know, I had in place the same basic simplified code that you've added for the gravity handling, but at the time I couldn't see the springs working (it turned out that I was setting the Ks value too low), so I more literally copied the source code's approach in order to be sure I wasn't mishandling anything.  Thanks for restoring the more concise version!
And the zero equivalency test for float... well... 😊.  That was initially just an else condition, and I unthinkingly made it more literal.  I had since changed it (along with a great deal else), but only ever seem to get penetration cases, never collision - which means the general while loop used to pop out the mesh and enable soft body dynamics never works.  Huh.  Anyways.  Thanks for the notes.  I'll see if I can refine this.  Unfortunately, it takes the speed gains for collision handling via the pyd and then applies them in a way that creates yet another Cage script that takes seven minutes to run in even fairly simple situations....  Sigh.  I'm not feeling optimistic about the pseudo cloth right now....
Cage ( ) posted Wed, 02 April 2008 at 3:35 PM
Okay, first question: how do I get the vertex normals using the Mesh/Ngon types?  Maybe that's explained in your recent .pyd update post....  Go through, uh...
<font size="2">PolyVertexNormals() ->
routine to come)<br></br><br></br>
???<br></br><br></br>
Help!  What happened to my text?  How do I un-format
this?  Jane!  Stop this crazy thing!<br></br><br></br>
I guess I should tinker and test....<br></br></font>
Spanki ( ) posted Wed, 02 April 2008 at 4:34 PM
Yes, to get vertex normals, you simply:
shrinkMesh = Mesh(shrinkActor.Geometry())
vertnorms = shrinkMesh.GetWorldNormals()
Spanki ( ) posted Wed, 02 April 2008 at 4:58 PM
...just as a reminder and/or in case anyone is wondering...
Obviously Poser Python already has a method for getting Normals, but we determined very early on that they were not 'correct' (at least for what we wanted to use them for - I don't recall the details atm), so we are computing our own.
Cage ( ) posted Wed, 02 April 2008 at 6:13 PM
file_403381.txt
Whoo!  Here's an updated cloth script, adapted for the new Mesh and Ngon types, including Spanki's changes.
I noted while working on this that the vertex neighbors routine recently added to the .pyd isn't returning the same data as the routine I've been using for TDMT classic, so I still use the hand-written version.  :(  The .pyd version is returning the index of the vertex itself, as well as fewer neighbors than the classic method.  My use requires that the neighbors include indices of all vertices which are part of ngons of which the vert is also part, excluding the index of the vert itself.  It's hard to express such things without being confusing, isn't it?  Cough....
Otherwise, all is well, and it does seem a bit faster, although the process as it stands is certainly not going to be robust enough to become an effective alternative to the cloth room.  My hope has been that this could expose the basic simulation handling for cloth for users to adjust as desired, in ways not allowed by the clothroom.  For instance, simulate a rope without having it collapse in on itself.  Or adjust the direction of gravity, to create a vacuum-wrapping effect.  The vacuum-wrapping works here, but can be painfully slow, alas....
Cage ( ) posted Wed, 02 April 2008 at 6:14 PM
BTW, a big "THANK YOU!" to Miss Nancy for the kind words, and thanks to Spanki, again, for putting up with my hack-ish ways.  I do fear that I may drive folks away, just by being as haphazard and air-headed as I can be....  :(
Spanki ( ) posted Wed, 02 April 2008 at 6:33 PM
Quote - I noted while working on this that the vertex neighbors routine recently added to the .pyd isn't returning the same data as the routine I've been using for TDMT classic, so I still use the hand-written version.  :(  The .pyd version is returning the index of the vertex itself, as well as fewer neighbors than the classic method.  My use requires that the neighbors include indices of all vertices which are part of ngons of which the vert is also part, excluding the index of the vert itself.  It's hard to express such things without being confusing, isn't it?  Cough....
Actually, you just described how I intended it to work (mimicing the functionality of your python code), so if it's not doing that, I'll have to look at it again.
Spanki ( ) posted Wed, 02 April 2008 at 6:49 PM
file_403383.txt
See if this fixes it (save it as "_tdmt.pyd")
Cage ( ) posted Wed, 02 April 2008 at 6:49 PM
*Actually, you just described how I intended it to work (mimicing the functionality of your python code), so if it's not doing that, I'll have to look at it again.
*I found it to be returning the index of the vertex itself, which isn't a big deal.  I just wrote something to screen that out.  The screened lists weren't giving me all the desired neighbor polys, so I stopped messing with it and just adapted the old function for Mesh use.  There is a chance that I erred while screening the index of the vert and ended up somehow screening valid neighbors as well.  I don't think I did, but it is always much more likely that Cage goofed, when something like this comes up....  :-P
Not a biggie.*
Cage ( ) posted Wed, 02 April 2008 at 6:51 PM
D'Oh!  Cross-posted....
I didn't know we could attach binary files as .txt....
I'll test this now!  :D
Cage ( ) posted Wed, 02 April 2008 at 7:01 PM
vertneighbors(mesh) #still need to run this manually - pyd isn't returning the same data.
mesh.vneighbors2 = mesh.mesh.GetVertNeighborsByNgons()
for vi in range(len(mesh.verts)):
    print vi, mesh.vneighbors[vi],mesh.vneighbors2[vi]
return
0 [1 2 3] [0]
1 [0 2 3] [0, 1]
2 [0 1 3] [0, 1, 2]
3 [0 1 2] [0, 1, 2, 3]
4 [7 6 5] [7, 6, 5, 4]
5 [7 6 4] [7, 6, 5]
6 [7 5 4] [7, 6]
7 [6 5 4] [7]
The above code prints the results of a comparison between the "classic" vertneighbors and the .pyd just posted, using the two-sided square primitive....
Am I mis-applying the code for GetVertNeighborsByNgons()?
Spanki ( ) posted Wed, 02 April 2008 at 7:03 PM
Just to clarify... I did find what was causing the vert itself to get added and fixed that.  As for the complete list of neighbor verts, I also found a potential problem with that (my fix needs testing), but what I'm doing internally is...
  • get list of vertex Ngon neighbors ( vngons = mesh.GetVertNgons() ) and then...
  • walk through the list of ngons each vert is a part of and building a list of (unique) vertices used by any/all of those ngons (now properly excluding the vertex itself).
...so just to clarify, my code doesn't know anything about any potential screening you might be doing, before or afterwards.
Spanki ( ) posted Wed, 02 April 2008 at 7:05 PM
<cross-posted>.... hmmm.. let me study that a minute.
Spanki ( ) posted Wed, 02 April 2008 at 7:11 PM
I need to go eat dinner and watch some shows... I'll look at this afterwards :).
Spanki ( ) posted Wed, 02 April 2008 at 11:59 PM
Ok, I'm not getting those results.  When you downloaded that new file above, did you quit Poser, download that file (overwriting the _tdmt.pyd file in the PoersRuntimePythonDLLs folder), then re-start Poser and try again?
I just tested with this:
import poser<br></br>
import math, Numeric<br></br>
import time, os<br></br>
from _tdmt import *
def vertneighbors(mesh): # _tdmt.pyd
GetVertNeighborsByNgons() doesn't return the same data....<br></br>
 ngons = mesh.GetNgons()<br></br>
 pgons = [i.vertIndices for i in ngons]<br></br>
 vpolys = mesh.GetVertNgons()<br></br>
 vneighbors = [[] for i in range(len(vpolys))]<br></br>
 for vi in range(len(vpolys)):<br></br>
  screen = [vi] # Need to exclude the vert itself!<br></br>
  for ps in vpolys[vi]:<br></br>
   for v in pgons[ps]:<br></br>
    if not v in screen:<br></br>
     vneighbors[vi].append(v)<br></br>
    screen.append(v)<br></br>
 vneighbors = [Numeric.array(i,Numeric.Int) for i in
vneighbors]<br></br>
 return vneighbors
scene = poser.Scene()<br></br>
actor = scene.CurrentActor()
if actor:<br></br>
 geom = actor.Geometry()<br></br>
 if geom:<br></br>
  mesh = Mesh(geom)<br></br>
  vn = mesh.GetVertNeighborsByNgons()<br></br>
  vn2 = vertneighbors(mesh)<br></br>
  for vi in range(len(vn)):<br></br>
   print vi, vn2[vi], vn[vi]<br></br>
...and got this result:
0 [1 2 3] [1, 2, 3]
1 [0 2 3] [0, 2, 3]
2 [0 1 3] [0, 1, 3]
3 [0 1 2] [0, 1, 2]
4 [7 6 5] [7, 6, 5]
5 [7 6 4] [7, 6, 4]
6 [7 5 4] [7, 5, 4]
7 [6 5 4] [6, 5, 4]
Cage ( ) posted Thu, 03 April 2008 at 12:08 AM
file_403398.txt
0 [1 2 3] [1, 2, 3] 1 [0 2 3] [0, 2, 3] 2 [0 1 3] [0, 1, 3] 3 [0 1 2] [0, 1, 2] 4 [7 6 5] [7, 6, 5] 5 [7 6 4] [7, 6, 4] 6 [7 5 4] [7, 5, 4] 7 [6 5 4] [6, 5, 4]
Hooray!  Yeh, I had failed to reinitialize the Python!  See what I mean... when something seems wrong, it's probably a Cage error.  LOL
Hoo boy.  Sorry for the concern.  😊  😊
And here's an update which applies the fixed version.
Spanki ( ) posted Thu, 03 April 2008 at 12:48 AM
Since it appears to now be working correctly, I replaced the download zip file with the new .pyd inside (didn't update the docs any).
Cage ( ) posted Thu, 03 April 2008 at 12:59 AM · edited Thu, 03 April 2008 at 1:01 AM
Thank you again, Spanki-sir!  :D
Here's a bit of a poser... does that qualify as a pun?  Hmm.  I'm thinking about cloth self-collision.  To do this, it seems one would have to send the cloth mesh as both verts and polys.  The likely result (borne out in a quick test I ran) would seem to be that the vert would collide with itself in all cases.  Indeed, my cloth just quivered in place.
The only obvious workaround I can think of would be to send each vert individually, as a one-item list, along with a poly list which screens out all the polys of which that vert is part (I assume it can't collide with those, but I may be wrong).  This seems like it would be quite slow, unfortunately.  This really isn't something for which this point-in-tri approach was designed.
Can you suggest any approach for this, other than the one I have above?  Is there anything in the .pyd that could make this easier?
Spanki ( ) posted Thu, 03 April 2008 at 1:10 AM
Erm, yeah, it wasn't really designed to account for self-collisions... let me think about that some (I'm actually afk right now, just doing a drive-by :) ).
Cage ( ) posted Thu, 03 April 2008 at 1:12 AM
It's a puzzler.  I don't think even adding a screening list to the optional submissions for the point-in-tri routine would help.  :(
Whenever you come back, you'll have to tell me what "afk" is....  LOL
Spanki ( ) posted Thu, 03 April 2008 at 1:44 AM
afk = Away From Keyboard :)  (which I still am, for the next hour or so)
Cage ( ) posted Thu, 03 April 2008 at 1:48 AM
S'okay.  I'm going to be otwdw (Off To Watch Doctor Who) pretty soon, anyways.  Going to reprise some Eccleston tonight, I think.  :D
Cage ( ) posted Thu, 03 April 2008 at 3:00 PM
Actually... I'm kind of wondering if collision detection of the robustness of the _tdmt approach is even necessary for this sort of approach.  The C++ example simply uses distances from objects.  His approach is far to simple and not really useful for Poser, but I wonder if the basic idea may still hols.  That is, for both self-collisions and other-collisions, with cloth or something like this, we don't really need the exact point of collision, or perhaps we don't even need to identify a specific collision poly or tri.  I don't know.  Could one simply use distances from all the poly or tri planes somehow, reacting if a vert comes within a certain distance of something?  Hmm.
But I guess the plane is infinite, so one might need to break that down into the area of the tri or poly, so....
Hmm.  Umm.  Where's my 3D math book....  Need a refresher....
Spanki ( ) posted Thu, 03 April 2008 at 3:32 PM
Yes, we're generating more data (weight values) than is needed by that code, and a lot of it could be by-passed with some simple bounding box tests (until you got within range of an actual collision)... but at some point (once you have the objects close to each other), you still need to determine ray->polygon intersections along with the distances generated in those tests.
Spanki ( ) posted Thu, 03 April 2008 at 3:36 PM
New toys...
Update: 04/03/08 (search on: "04/03/08" to see changes)
While it might not have been apparent or stated clearly in previous releases, the lists being returned by the various MeshType methods were pointers (by reference) to the actual lists being tracked (and used) internally by the MeshType class. This was implemented as such for two reasons...
  1. keep memory allocations smaller.
  2. consistancy with the behavior of other types implemented by this extension.
...the potential problem with this is/was that there was no 'Clone()' method for the Python Lists being returned (you'd either have to roll your own or Clone() the entire MeshType). So, while it was consistent in behavior (returning pointer/references for complex data types), it was inconsistent in functionality (not providing a way to easily get 'new' lists to play with).
As of this release - and at least for the time-being - I have changed the MeshType methods to always return fresh copies/clones of the lists that it's working with internally. This also has the side-effect that if you modify the vertex positions, you need to tell the Mesh class about it, so it knows to fetch/generate fresh data the next time it's needed (ie. face normals and vertex normals likely need to be re-computed and distances, positions and intersection locations would also be off). You can accomplish this with the new mesh.VertPositionsChanged() call.
If you actually make structural changes (ie. change which vertex indices are used by Ngons and TriPolys, the winding order used to create them or add/remove any polygons or vertices or tex vertices, etc.) then you need to call mesh.StructureChanged() instead. This one basically invalidates all internal lists, so any data will get re-computed when next needed.
The other new features of this release are an attempt to address the self-collision/correlation issue. For the purpose of discussion, assume we have a flattened spherical mesh (like seat-cushion). And that you wanted to write a script that flattened it out even more, but not so much that one side of it penetrated the other side... in this case (and most other self-collision cases), you need to correlate the vertices of the mesh with the tripolys of the same mesh - typically with tripolys on the other side of the mesh - but not necessarily. This poses a couple different problems for our current/original Correlate() routines...
  1. correlating a mesh with itself would always get 'hits' on the tripolys that the vertices lived in (one of them, more or less randomly, since the intersection would be AT the vertex).
  2. the current routine doesn't bother testing for collisions with any tripolys that face the opposite direction as the faces that use the vertices being tested (you might have to read that a few times for it to make sense :) ).
...so, to address these issues, there are two new Mesh class methods...
CorrelateToSelf()
CorrelateByIndexToSelf()
...see the documentation below for details, but for the record, neither has been tested :) and/so, I'm not even sure that the backface culling (or lack thereof) is working as it should (and, if it does produce the proper hits, what happens to or how to interpret the sign of HitDist, etc. [but I don't think that changes, actually - it should still give the same indication of direction to the intersection, in a positive or negative increment along the tested normal, so the only real difference is that the tripoly it intersects may be back-facing]).
Trial and Error is the order of the day - have fun! :)
Additions:
  • fixed bug in mesh.GetVertNeighborsByNgons()
  • added mesh.VertPositionsChanged()
  • added mesh.StructureChanged()
  • added mesh.CorrelateToSelf()
  • added mesh.CorrelateByIndexToSelf()
Spanki ( ) posted Thu, 03 April 2008 at 3:50 PM
WAIT  - that version has bugs.  ;)
