Tue, Nov 26, 7:18 AM CST
Renderosity Forums / Poser 13
Welcome to the Poser 13 Forum
Forum Moderators: nerd, RedPhantom
(Last Updated: 2024 Nov 25 10:18 am)
Subject: Show your Poser 13 renders!
shvrdavid ( ) posted Sat, 22 April 2023 at 12:17 PM
Content Advisory! This message contains profanity
Wow, blocked by vopehov506 for just explaining how I set the animation the up and why the light turns on and off...
And by the way, all you have to do to read what someone that blocked you wrote, is log out or use a browser that is not logged in..
How is explaining what I did, and how I did it a tense reaction to criticism?
And make my work better by who's standards? It was a quick animation, I am not trying to win any awards here.....
I am not making stuff to please anyone other than myself, or to match what someone else says it "should" be to be better.
I don't even know why I bother anymore. I really don't.
20+ years of using with Poser... Years working with the Development of Poser.
And now explaining why and how I set up an animation is an unacceptable reaction to someone not even noticing why a light comes on and off...
I don't give a shit what someone else thinks I should do in Poser, I really don't....
I will help just about anybody do things in Poser, but I don't tell them "they should do this better" with everything they post either....
Some things are easy to explain, other things are not........ <- Store ->   <-Freebies->
Thalek ( ) posted Sat, 22 April 2023 at 2:21 PM
shvrdavid posted at 11:00 AM Sat, 22 April 2023 - #4463041
The gif was made with Median Cut dithering, which always creates grain.
I use an old 32 bit program which does the conversions very fast, and I like the effect.
The lighting that changes is animated on a light just out of frame in response to where the orb is..
If the orb is behind her near the ladder, the other light is on. To her left and close behind her is height conditional.
I set up the orb to light relationship up in the preview with hit boxes. When the orb entered those boxes, I set the animated values of the light.
It adds to the effect as well, so much so you instantly notice it, but not why right away.
I set many of my animations up very quickly using tricks like that. And try to make it a small effect not to completely distract.
I am just having fun messing with it and showing what Poser is capable of, and how fast it can do it.
I try to inspire other people to try it.
And get them to question how and why I did something.
Like the orb turning on a light from hit boxes used in setting up the scene....
You completely missed the fact the orb was used as a controller to set the light up, didn't you?
Mission accomplished..
I was most impressed, especially that you went to that much effort for a quick demonstration.
I don't know what hit boxes are, but it sounds like a useful technique for triggering an action.
Me, I'm overly proud of learning about using the Greater Than math function for improving transparency masks for b&w and color images when plugged into the transparency input. (Been having transparency issues with both b&w and colored images both being too transparent, causing the colors to be less vibrant, and the blacks (which weren't true black, Charles explained to me) were turning brown. Using the Greater Than function not only guarantees me nothing but pure black and pure white, but it allows me to tune the aggressiveness, so that lighter colors still mask out the image.)
But yes, I do have a touch of "attention disorder", or I would never have become an amateur actor.  [grin]
GiveitUp ( ) posted Sat, 22 April 2023 at 2:27 PM
The Abandoned Star Cruiser. Dreaming navigator android in standby mode.
GiveitUp ( ) posted Sat, 22 April 2023 at 2:37 PM
Poser 13 has serious problems with morphing. The figure assumes its original shape when you click the morph button and the figure settings from the standard menu are massively deformed. I'll probably have to continue morphing with Poser 12. Has anyone noticed anything similar???
Thalek ( ) posted Sat, 22 April 2023 at 2:37 PM
Speaking of my recent conversion efforts on older tattoos, I put a few of them on this young lady.  I wanted to experiment with a moonlit scene with a camp fire providing part of the light.  This is Nerd3D's old beach package, someone else's campfire and sticks to feed into it, a large driftwood log, and someone's sitting on a rock pose that turned out to need no adaptation at all to work.  Then I gave her a beverage because I don't know about her, but /I/ was thirsty.  Not particularly impressive, but fun.  (I also discovered the baffling weirdness that can happen when Victoria 4 decides to conform herself to a beach set; took me half an hour just to find her, and then her directions and orientation were all screwed up. So I gave up trying to correct that and brought in a new Victoria and let the other one go on vacation.)
GiveitUp ( ) posted Sat, 22 April 2023 at 2:52 PM
f09b9tnjnH0YAIvtRI7eCgfASN470E8HgdlcfILF.jpgThis is what it looks like when I click the Morph button. Maybe it's the PE figure that's causing the problems?
Thalek ( ) posted Sat, 22 April 2023 at 4:26 PM
Trantuete posted at 2:52 PM Sat, 22 April 2023 - #4463061
If it was me troubleshooting the problem, I'd compare several different figures from different creators to see if the problem can be replicated or at least has common elements.  Antonia, something from Daz, one of the Poser figures, and you're already experimenting with PE.  I found comparisons, especially with working instruments, to be invaluable as an electronic service tech.
Also, is this unique so far to P13?  You haven't seen this in P12 or P11? If you decide to put in a bug report, details like this can help them narrow down the problem.
GiveitUp ( ) posted Sat, 22 April 2023 at 5:18 PM
Thanks for the trouble, I will continue to monitor the problem and try it out a bit. I will then report...
RedPhantom ( ) posted Sat, 22 April 2023 at 5:18 PM · edited Sat, 22 April 2023 at 5:19 PM
Site Admin Online Now!
So I couldn't resist testing out a crowd scene. Poser couldn't handle 40 people. It seemed to top out at out 15. But I was able to render all 3 sections this afternoon.
hborre ( ) posted Sat, 22 April 2023 at 5:18 PM
Online Now!
The button is the Morphing Tool, you need to get the terminology right if you are going to file a bug report.  Which version of PE are you using?  There are 2 flavors of the figure, one for P10 and the other for P11.  I loaded her into P13 and activated the Morphing Tool and I see no deformity of the shoulders but the P11 figure does exhibit unnaturally rounded shoulders.  As Thalek posted, try different models for repeatable deformities.  The techs need to replicate the problem consistently for it to be classified an actual bug.
GiveitUp ( ) posted Sat, 22 April 2023 at 5:20 PM · edited Sat, 22 April 2023 at 5:20 PM
hornet3d ( ) posted Sat, 22 April 2023 at 5:24 PM
Just playing.
hborre ( ) posted Sat, 22 April 2023 at 5:30 PM
Online Now!
Thalek posted at 2:37 PM Sat, 22 April 2023 - #4463060
Select V4 and use the Posing Camera to locate her or use the Top Camera and pull it back far enough to see her outline.  Wow, that scene needs major work.  No occlusion under her feet, looks like she's sitting on air, and not dark enough to simulate moonlight.
Here's a tip, turn down the intensity of your infinite light very low and change its color to pale blue.  If you have a construct stage, change its color to black, you want no environmental reflection from other large objects.  If the campfire is relying on ambient illumination, you want it to emit orange-tinted lighting.  If you can control Inverse Square, apply it to the campfire.  Play with the intensity until you get something satisfactory.  Now, is this Firefly or Superfly rendering?
hborre ( ) posted Sat, 22 April 2023 at 5:31 PM
Online Now!
RedPhantom posted at 5:18 PM Sat, 22 April 2023 - #4463075
Is this composited?
GiveitUp ( ) posted Sat, 22 April 2023 at 5:59 PM · edited Sat, 22 April 2023 at 5:59 PM
Ok.... All the PE characters have the same Problem... PE for P10 and P11pBn9JTvur4RmwtAoHcpm6WdbOaT6v8Wah9TgQin8.jpg
shvrdavid ( ) posted Sat, 22 April 2023 at 6:11 PM
I am about half way thru rendering a fairly long animation, and then I will look at what is causing PE to do that.
I know you said it does it with all of them, but what version of PE do you have?
I ask that because I have lots of versions of PE, some that were never released, and that may help me narrow the issue down faster....
hborre ( ) posted Sat, 22 April 2023 at 6:29 PM
Online Now!
Which body controls are you trying to modify?  I'm seeing any activation of the Rig Control elements with the Morph Tool on.
Y-Phil ( ) posted Sat, 22 April 2023 at 6:31 PM
Trantuete posted at 5:59 PM Sat, 22 April 2023 - #4463086
Poser11 (and Poser13 as well RBWaspPQ230gEDG26TKNb6Gl2VFG4boGZgvMxHLa.gif)
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
👿 Mac Mini M2, Sonoma 14.6.1, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
Thalek ( ) posted Sat, 22 April 2023 at 6:36 PM
hborre posted at 5:30 PM Sat, 22 April 2023 - #4463079
I agree that it needs major work, and I appreciate your bluntness. I also appreciate the advice. I was using a full moon image that was apparently for the construct. I'm not sure where the lights came from; I started from an empty scene.  I don't know when they loaded in.  The ambient channel and the diffuse channel both have the same orange color.  I bumped up the ambient to 3.0.  I'm not certain how to set up the Inverse Square you mentioned.  This is a Superfly rendering, and having seen some of my other Superfly renderings, I'm rather disappointed.  Although everything in this scene predates Superfly, so probably no Superfly materials (except the material layers for the tattoos) are present.  I also ran EzSkin on her because her skin was too shiny at first. I've managed to remain remarkably ignorant of the software in all of its iterations, never having really spent enough time on it.
hborre ( ) posted Sat, 22 April 2023 at 6:48 PM
Online Now!
Predated Superfly material has become such a nightmare to convert.  Vendors that thought they knew what they were doing really didn't.  It is best to break everything down to the basics and then rebuild as simplistically as you can to make the scene render the way you want it to and as it should, which means understanding how lights, materials, and scenes interact with each other.  No more faking it.
Y-Phil ( ) posted Sat, 22 April 2023 at 7:58 PM · edited Sat, 22 April 2023 at 7:58 PM
87 seconds for this, using my 4 yo rtx 2080 ti... Woah SIwFEHR8jgbaIwwyGPXW7Ckurrxo7qqu28rU71Yg.gif
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
hornet3d ( ) posted Sat, 22 April 2023 at 8:14 PM · edited Sat, 22 April 2023 at 8:17 PM
Thalek posted at 6:36 PM Sat, 22 April 2023 - #4463095
Speaking of my recent conversion efforts on older tattoos, I put a few of them on this young lady.  I wanted to experiment with a moonlit scene with a camp fire providing part of the light.  This is Nerd3D's old beach package, someone else's campfire and sticks to feed into it, a large driftwood log, and someone's sitting on a rock pose that turned out to need no adaptation at all to work.  Then I gave her a beverage because I don't know about her, but /I/ was thirsty.  Not particularly impressive, but fun.  (I also discovered the baffling weirdness that can happen when Victoria 4 decides to conform herself to a beach set; took me half an hour just tfind her, and then her directions and orientation were all screwed up. So I gave up trying to correct that and brought in a new Victoria and let the other one go on vacation.)
ZSahgmECJOIx06zYhFeMaSRPCZejxeR5ieZnILFn.jpgUWlnsiFdAaYNOiCejRhbVTket7RDFVfpeknCJcR3.jpg
This is where you will find the attenuation properties such as Inverse Square, Constant is the Default but both Inverse Linear and Inverse Square can be useful.  The options are only available for Spot and Point lights and you may need to adjust the Intensity of the light to get the effect you are looking for.  Inverse Square can be particularly useful used when illuminating campfires, as in this case, and also candles.
hornet3d ( ) posted Sat, 22 April 2023 at 8:20 PM · edited Sat, 22 April 2023 at 8:20 PM
Y-Phil posted at 7:58 PM Sat, 22 April 2023 - #4463102
Breath taking, particularly considering the equipment being used and remembering when rendering overnight was not unusual just a few years ago.
hornet3d ( ) posted Sat, 22 April 2023 at 8:26 PM
hborre posted at 6:48 PM Sat, 22 April 2023 - #4463096
Very good point and you have to question whether it is worth all the effort, the decision will often have to be on a case by case basis and ultimately down to the individual user.  It does however highlight the fact that while backwards compatibility is nice to have, there will times when it is best to just let go.
GiveitUp ( ) posted Sat, 22 April 2023 at 8:28 PM · edited Sat, 22 April 2023 at 8:28 PM
Y-Phil posted at 6:31 PM Sat, 22 April 2023 - #4463093
Thank you Y-Phil.... good idea!   May be i'm the only one with this problems.s04m0O80jRu5NqeKzLAUhdLA7DKAD8kWR8buTlKR.jpg
GiveitUp ( ) posted Sat, 22 April 2023 at 8:32 PM
It would be nice if Erogenesis upgraded its PE.
PROJECT EVOLUTION TWO
hborre ( ) posted Sat, 22 April 2023 at 8:44 PM
Online Now!
That would be nice considering that I noticed that the skin shaders for Superfly are off.
Thalek ( ) posted Sat, 22 April 2023 at 8:53 PM
Which means I'll have to come to understanding Superfly materials myself..  [wry smile]
hborre ( ) posted Sat, 22 April 2023 at 9:15 PM
Online Now!
The best way I learned was to watch Blender YouTube tutorials and attempt to duplicate the same arrangements in Poser.  This is given that certain nodes do not exist in Poser and workarounds are very difficult to solve.
hornet3d ( ) posted Sat, 22 April 2023 at 9:15 PM
Thalek posted at 8:53 PM Sat, 22 April 2023 - #4463111
Which would be useful but there is the possibility to use some of the commercially available materials such as the collections from Ghostship2 or Vince Bagna to replace the old materials that do not work.  Certainly for props, be it buildings or clothes this can be a way forward.
GiveitUp ( ) posted Sun, 23 April 2023 at 6:59 AM
UmVowFujZ7P6xYSeN88c65IblxDzRcX7HGu8Cz5E.jpgOk, it's kinda gross and I promise this will be the last pic with Rufus (I hope). I am not satisfied with Poser 13. There are still too many construction sites and adjustments to be made. CyclesX is fantastic and I'm excited to see what's to come. I see here that some people have their little problems, but hope dies last.
Y-Phil ( ) posted Sun, 23 April 2023 at 7:44 AM · edited Sun, 23 April 2023 at 7:51 AM
Trantuete posted at 8:28 PM Sat, 22 April 2023 - #4463106Thank you Y-Phil.... good idea!   May be i'm the only one with this problems.s04m0O80jRu5NqeKzLAUhdLA7DKAD8kWR8buTlKR.jpg
The best answer ever: humorous! great.
"Evolution One for P10"? I've got all of them and this one, too works as expected.
Well, the oldest Poser I have is Bondware's Poser11 and I don't if there's something special with the previous versions, I mean: there are more advanced users around here that know how to create a morph that controls the visibility of something, that's where it may be broken, or is broken only with the morphing tool active?
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
GiveitUp ( ) posted Sun, 23 April 2023 at 8:11 AM
6Ce00p9NujHhDjltsVfG48naCopOIeyvcy754Wpa.jpgOnly if the morphing tool is active....
I'll try something else tonight. I've been morphing with Poser for years but I've never had anything like this before.
Also when subdividing, poser crashes. It did that with Poser 12 though. So I'll be patient and wait...wait and have tea...uhhh milk. Thanks a lot for the support.
GiveitUp ( ) posted Sun, 23 April 2023 at 9:17 AM · edited Sun, 23 April 2023 at 9:17 AM
iEJYygwPb8kq7OrgG8MeE56SFnKWPy6yJeqsylS5.jpgIs 64 GB of memory enough? I'll start with my PC. Drivers, etc. Not that I'm nagging here and in the end I'm actually the idiot. Ha haa...
vopehov506 ( ) posted Sun, 23 April 2023 at 9:56 AM
A Little "artistic" test Render with V4 ....
jura11 ( ) posted Sun, 23 April 2023 at 5:57 PM
My new freebie Modern Kitchen is finally done and uploaded over here on Renderosity and please enjoy it
Thanks,Jura
vopehov506 ( ) posted Sun, 23 April 2023 at 7:02 PM · edited Sun, 23 April 2023 at 7:02 PM
I was finally able to fix my GPU issue with poser causing a shut down or a black window, so for the first time I could runn Optix for a Render. With some correction on the skin to remove that Plastic and finally got rid of this massive grain effect ..... Again a V4
shvrdavid ( ) posted Mon, 24 April 2023 at 12:07 AM · edited Mon, 24 April 2023 at 12:07 AM
More doodling, but this is not La Femme..... Who could she be?
Yeah, I know, I forget to subdivide the hair to death......
No post work, no Post FX, took 318 seconds to render in Optix
Y-Phil ( ) posted Mon, 24 April 2023 at 1:15 AM · edited Mon, 24 April 2023 at 1:15 AM
jura11 posted at 5:57 PM Sun, 23 April 2023 - #4463194
Thanks,Jura
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
vopehov506 ( ) posted Mon, 24 April 2023 at 9:50 AM · edited Mon, 24 April 2023 at 9:50 AM
Just for fun pulled out the "old V4 Treasure Hunter" another tryout with Optix, no Postwork like the one above " Same Skin Used "
lsauvage ( ) posted Mon, 24 April 2023 at 11:58 AM
vopehov506 posted at 9:56 AM Sun, 23 April 2023 - #4463144
Nice, it's a good idea to add some drawing on it. It makes it more personal.
vopehov506 ( ) posted Mon, 24 April 2023 at 12:30 PM
lsauvage posted at 11:58 AM Mon, 24 April 2023 - #4463240
Yes it is thank you :) .... actually it is a full repaint so in theory not a postwork, made with brushes and pens I generated throughout the years for my needs ( Not Photoshop ). I do not like that hyperreality style, ( That's me ) but Poser 13 seems to have quiet some strength to generate the needed Templates to work em out in a Paint app.
vopehov506 ( ) posted Mon, 24 April 2023 at 12:36 PM · edited Mon, 24 April 2023 at 12:36 PM
This here is the "Treasure Hunter Render " that I just used as Template for a full repaint. Mixed with the semi realistic style and a load of brushes to get this final result. A quick test to see if it is usable. I Have to say as templates these renders sure do a good job. If you are a comic artist then sure could get neat results.
Y-Phil ( ) posted Mon, 24 April 2023 at 1:35 PM · edited Mon, 24 April 2023 at 1:35 PM
vopehov506 posted at 12:36 PM Mon, 24 April 2023 - #4463247
I do love your pictures. They remind me of the time we had a wonderful product to be used with old Poser versions, at the time of RDNA: Art Materials.
Excerpts of the PDF given with the product:
I know that it looks like Poser's Sketch renderer but it doesn't, at least for me as I am unable to reproduce some effects.
That being said, I've played a little with the Sketch renderer and it's fun too,
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
vopehov506 ( ) posted Mon, 24 April 2023 at 2:47 PM
thank you Y-Phil sure nice to hear :)  Yes I sure do remember these from RDNA I also have this collection somewhere, as far as I remember they also were templates that could be used in the sketch designer of Poser. Sure been a while. They did great things with little for sure in these times
RedPhantom ( ) posted Mon, 24 April 2023 at 2:49 PM
In this one, I decided to illustrate a chapter of a story I'm working on. I was able to render 23 figures in this one since most didn't use any textures. It took a half hour to render but that's because I decided to jack up the settings rather than using the denoise. Given how high I had them, I'm happy with the time. The only post work was to use the post effects to make the ruby glow
Y-Phil ( ) posted Mon, 24 April 2023 at 3:05 PM
RedPhantom posted at 2:49 PM Mon, 24 April 2023 - #4463272
Really cool!
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Thalek ( ) posted Mon, 24 April 2023 at 3:33 PM
Put a better Firefly texture on the rocks around the fire, verified that she was actually sitting on the log, and after some experiments, turned the lights off, and took the full moon background down to .5 because 1.0 was still too bright. I don't know if she's casting any shadows, but I like the way the ground has pools of shadow.
hborre ( ) posted Mon, 24 April 2023 at 4:36 PM
Online Now!
That looks much better.  There is still the issue with occlusion under her feet, I wonder if there is an ambient channel active on the ground.  The catchlights on the figure look right.  Keep in mind, a scene like this is difficult to light because you are expecting two very different light sources to be prominent at the same time.  With a camera view this close to the subject, I would expect the campfire to completely overwhelm the ambient moonlight.  But you are looking for a specific effect in your scene.
GiveitUp ( ) posted Mon, 24 April 2023 at 5:03 PM · edited Mon, 24 April 2023 at 5:03 PM
