Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 12 9:36 pm)
Yes and I tried my username and password for CP then for e-frontier and they didn't work.
France, Proud Owner of
KCTC Freebies
No its a textfile posted up a few postings here by Curious Labs. I tried editing my knownfaceroomheads.xml with it and curiously the information was already in there. So I can say it did not work for me. Hmm maybe we should have Deecey send out her .xml file for everyone else! See what the difference is.
The installer correctly modifies the XML file (though if you run it again it re-adds the same lines, which I suspect is a no-no). The problem is the model itself and the logic Poser 6 is using to determine which face room character to use. I suspect the model they are shipping is different than the one the face room add-on was setup for. This isn't an install problem.
-Matt
From Content Paradise support :
"We're looking at the problem, and it appears that the problem is an oversight in the design of the face room installer.
A new one which is a wee bit more robust will be coming out very shortly. For now, contact the Support Engineers at Curious Labs/E-Frontier and get in the
Technical Support queue. They can get you working..." * sits down and waits for the update *
Message edited on: 08/18/2005 20:48
Hello all.
It's good news for you that you can buy Miki.
But currentry I'm disapointed for e-frontier, because the Miki1020 package is very different from japanese version including. (Diffrent clothings, No pose file, No Expression file, No Bike.)
And there is a no information about face room moduke fo japanese version yet. (From japanese forum, the Module for Miki1020 doesn't work for japanese version.)
Anyway, I can give you some information about them from my experiment. But I'm not sure whether CP version is same as japanese version or not.
For Miki.
If you want gloss for lips, there are two ways, I think.
(1) Use specular map including package.
I don't know it's included in Miki1020 or not, but there is a "Miki_Fase_Spec_09_01.jpg" in japanese package. this is specular mask for lips and eyes.
(2) Making new lips material group.
You can make new material group for lips using GroupEditor in Poser 6. And assign image maps for lips same as head texture map. (Of course, you can make new texture template using UVMapper, for new texture map.) Then, you can change lips material changing specular color, diffuse color, and so on.
Caution!! The Miki's EULA allow to make new shader in material, but not for material group. So if you make new mterial group, you must do it at your own lisk.
For Koji.
As noticed above, following is for japanese version and it may be diffrent from CP version.
Koji is seemed to be made from James' body with new head and neck. The UVs are not completely same, but very similar.
And you can use FBM of James for Koji, using MorphManager and modifying body channel of cr2 by text editor. The FBM works for body but not for head and neck. So when you apply FBM to Koji, there's a gap between chest and neck. To fix this, you may make FBM for neck using magnet. (It's not so difficult, even I could do it.)
Caution!! I'm not sure this is legal or not with EULA, so if you try this do it at your own lisk.
Hi ytetsu, First, どうもありがとうございました for your hard work in creating these Japanese figures! :) For now, be glad that you don't have the FaceRoom module. The poses are mainly for the motorcycle, so not too much lost. Looking forward to Koji! ではまた。
C makes it easy to shoot yourself in the
foot. C++ makes it harder, but when you do, you blow your whole leg
off.
-- Bjarne
Stroustrup
Yes, those are the lines that the installer keeps putting into the "knownFaceRoomHeads.xml". And, yes, I have a properly installed and registered version of Poser 6 (two even)! :) I'm really hoping that this doesn't require an uninstall and reinstall of Poser 6...
off.
-- Bjarne
Stroustrup
beryld, that does seem to be the only file missing, doesn't it? No way to fake that one as it's a data file.
off.
-- Bjarne
Stroustrup
Nope, I don't have that file in my Miki folder either. This is weird. I checked the lines mentioned in the TXT file above, and they are exactly as posted above, though not pasted completely at the end. Now, I've just noticed something. The Miki CR2 library files are located in the Downloads: Runtime: Libraries: Character folder. But the Heads data is located in the ROOT Runtime: heads folder. Maybe that's a clue?
I'm pretty sure the missing file is what controls the importing of face pictures, which they have said isn't working/doesn't work. So I think it's ok (but crappy). Clearly eFrontier hasn't reproduced this problem that almost everyone is having. I even went so far as to force the face room to use the Miki settings(removed all the faces and changed the XML to say Miki is the default), which sort of works but has issues (like her neck kept gapping open when the morph was applied) and it wouldn't bring in her head texture I had to do it by hand. There is something wrong with the files. Why Deecey's works I have no idea, but the files I have aren't going to work without changes. In case it makes any difference I'm running Windows XP. I'm running Poser 6 SR1. I have the compression option off. I have use external morphs off. I've tried changing these options but didn't see any result. I bought the product from CP, but not through the P6 tab (which I have removed). I unzipped it to a directory and then copied it into my main runtime(cause their zip files are defectively laid out). I then ran the face-room installer against my P6 runtime (which isn't my main). I also tried doing it the other way(installing Miki into my P6 runtime and runnning the face room installer) The XML file has the lines they claim it needs in the right places and appears to me to be valid (but obviously not working). -Matt
-Matt
This is what I just got when I asked tech support about the face room...haven't tried their suggestions yet. Hi Marque, So i've installed this myself, and it's working like a champ, the problem here seems to be that my test machines are super plain vanilla, and after speaking with the developers, there are some ways to thwart the standard install of the face module... Here is an exerpt from the conversation I had with the engineering guys, and you want to take a look at where it may apply to your physical environment. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ The Miki head data installer does the following: 1. Install the Miki head data folder in ./Runtime/heads/ 2. Modify the "knownFaceRoomHeads.xml" to add the following: as the last "FigureList" item, and as the last "HeadList" item Now when the installer is first launched it will do some "behind the scenes" stuff to help out the user. It will check the registry entry for the .pz3 file extension to determine Poser's original install location. This will be used as the initial default location. The user can overwrite this and choose to install to a different Poser installation. If the installer was configured in such a way, as to have the user point to a directory which does NOT contain Poser. Will certainly cause the installation of the head data to fail. Further, if Poser was moved from the original install location the installer will go ahead and put the files in that original location (creating any missing directories in the path). A more robust installer will be built and distributed immediately.
Oh definitely. Wish they would've put facial variation morphs in the Face folder rather than in the FaceRoom. Waiting on P&K to update WW to work with Miki, then I'll be in H (no, the other H!). :)
off.
-- Bjarne
Stroustrup
Before modify the script, I do recommend to backup "RealSkinShader.py".
Using Text Editor, Search the line containning
if material.Name() in ["SkinBody","SkinTorso", ... ,"ForeSkin"];
in RealSkinShader.py. (In my case it's line584.) And add followings after "ForeSkin".
,"Body","Head"
That's all.
if this dosn't work, replace the line as:
if material.Name() in ["Body","Head","EyeSocket"];
This case the script is for Miki only.
To be honest, I like the figure but the missing faceroom morphs are disappointing. I have used the installer on my original registered version, everything is in place and the xml is changed correctly but unknown figure. I contacted CP yesterday but until now, no response!! Thats customer care :((
Ulli
TamiL likes her. That's encouraging. That's what I'm looking for. Anyone else? If I have to pay full price I don't want to end up wishing I hadn't. Can anyone validate P5 or other poser compatability?(nonfaceroom of course) More info the better. :)
My brain is just a toy box filled with weird things
I contacted Technical Support yesterday through the link left by "Curious_Labs" above and received a response within hours. Nothing that changes the situation, but at least they responded. :)
off.
-- Bjarne
Stroustrup
mylemonblue, Miki will work with P5, but the morphs are stored externally as PMD so you'll see the dials, but they won't do anything and the FaceRoom data does not look to be compatible with Poser 5 at all. Unless you can find a way to load Miki into P6 and resave to the library with External Morph Targets disabled, you will not be able to use them.
off.
-- Bjarne
Stroustrup
D|S only exports Wavefront OBJ and saves in its own format. If you can spawn morph targets in D|S in a way that can be loaded back into Poser, then, albeit tedious, this would give a way to get the morphs back onto the figure in Poser 5.
off.
-- Bjarne
Stroustrup
So any word on the fix? Or are they still sticking to the its you not us theory. Reminds me of anytime I call my net service provider to ask whats wrong with thier system. They always say it my computer. I sure that saying is tatooed to the back of thier eyelids so thats the first and usually the only answer they can think of. LOL
Ok I have Poser 6 and my version number is 6.0.1.75 Is that the latest update? I tried editing the xml file and its still a no go for me too :( Thanks
Poser 9 SR3 and 8 sr3
Processor Type: AMD Phenom II 830 Quad-Core
Hard Drive Size: 1TB
Processor - Clock Speed: 2.8 GHz
Operating System: Windows 7 Home Premium 64-bit
Graphics Type: ATI Radeon HD 4200
System Ram: 8GB
yeah pokeydots...that's the version I have. Doesn't work for me either ;o). At least you're in good company - everyone...LOL. Thanks TamiL, but I think the skin shader is what really makes it (tho the bumps are still to high no matter how much I tone them down...hehehe). Just as an aside to texture-makers, the maps don't really stretch that much at all. You can pretty much plop a picture down over the template (of course I'm exagerating...) and just stretch a little here a little there, and everything lines up. There are areas that overlap, so you gotta watch for them, but they are thankfully very few :o). Laurie
I'll be working my map for awhile...LOL. Since I usually do clothing textures and not skin, it's a slow process ;o). Just wish I could do some work in the face room...sigh Tick, tick, tick... BTW, could someone give that link for the PoserClub? I wanna check out that item of Miki clothing ;o). Maybe do a tex or two for it. Laurie
???? what? The article wants a user name and password.
