Sat, Jan 11, 9:33 AM CST
Subject: Problem with Anime Hair from DAZ
Neyjour ( ) posted Fri, 22 February 2008 at 6:35 AM · edited Sun, 05 January 2025 at 1:52 PM
Hi guys.  I'm having a problem with the Anime Hair from DAZ.  I've asked for help in the DAZ forums but no one has been able to find a solution yet, so I'm hoping maybe someone here will know how to fix this.
To begin with, the Tran and Scale dials were all hidden.  I had to download and install Dimension3D's UnHide Dials 1.02 script.  It worked great and I now have Tran and Scale dials for the hair.  Now, the Tran dials work perfectly but the Scale dials won't work at all.  No matter what value I plug into any of them, nothing happens.  The hair will not resize.
Someone asked if the hair was locked.  I checked and it's not.
Does anyone know how to fix this problem?  This hair is really nice, but if I can't do something as simple as resizing it, then it's pretty much worthless to me and I'm going to have to ask for a refund.
Please someone, help!  :(
"You don't know what we can see
Why don't you tell your dreams to me
Fantasy will set you free." - Steppenwolf
Paloth ( ) posted Fri, 22 February 2008 at 8:21 AM
Make sure the hair is un-parented from the head of your figure. (It will parent automatically if the head is selected.) You can place and size the hair and then parent the prop maunally. This should work.
Neyjour ( ) posted Fri, 22 February 2008 at 8:24 AM
Thanks Paloth, I'll try that, but...how do I unparent it?  I know how to change the parent, but how do I select 'nothing'?
PhilC ( ) posted Fri, 22 February 2008 at 8:33 AM
In the parent list select the universe.
Neyjour ( ) posted Fri, 22 February 2008 at 8:49 AM
Thanks Phil.  Well, I tried unparenting and it looked like it was going to work...the Scale dials were actually working, but when I parented it back to the figure's head, it 'shrank' back to the original unfitted mess.  :(
Someone over at DAZ (who also has this hair) just posted that they're experiencing the exact same problem, and said that it is indeed 'broken'.  A ticket is being sent to customer support to get it fixed.
Thanks for trying to help.  I appreciate it.  :)
Paloth ( ) posted Fri, 22 February 2008 at 9:07 AM
A temporary workaround would be to parent the hair to a primitive sphere. Scale the sphere (and the hair) to the proper size. It should be a small sphere so you can see the hair. Translate the sphere so that the hair fits onto your figure. Parent the sphere to the figure's head and make the sphere invisible.
Paloth ( ) posted Fri, 22 February 2008 at 3:05 PM
I'm sorry. The temporary solution is actually a bit more complex. You need to take any simple prop into the Setup Room. Give it a bone, making sure the bone's internal name matches the prop's internal name. When you leave the Setup Room, the prop is now a figure. You can now load the hair and parent it to the former prop and when you size the parent, the hair will size along with it. When you parent the former prop to the head of a character, the hair behaves like it did before people tried to "make things simple."
Neyjour ( ) posted Sat, 23 February 2008 at 8:18 PM
Paloth, thanks very much!  If for some reason DAZ doesn't fix it, I'll give this a try.  :)
Connatic ( ) posted Sun, 24 February 2008 at 10:22 AM
Did you try selecting a Bodypart of the hair instead of the Body?  Often the dials will not work on the Body, but the neck or head dials will change the hair.  I have this hair and was able to get it to work fine.
Neyjour ( ) posted Mon, 25 February 2008 at 4:55 PM
Quote - Did you try selecting a Bodypart of the hair instead of the Body?  Often the dials will not work on the Body, but the neck or head dials will change the hair.  I have this hair and was able to get it to work fine.
I think you must be talking about a different hair?  The one I'm talking about is this:
Anime Hair by Bobbie25 & SWAM
This hair is a .hr2 not a .cr2, so there's no 'neck' or 'head' parts to select.  It's a prop of the figure you've added it to.
Connatic ( ) posted Mon, 25 February 2008 at 5:44 PM
Sorry, had it confused with a figure hair.
Anniebel ( ) posted Mon, 25 February 2008 at 5:53 PM
Have you tried contacting Bobbie25 or SWAM about it?
The best & most beautiful things in the world cannot be seen nor touched... but felt in the heart.
Helen Keller
My Gallery                       My Freebies                        My Store
Neyjour ( ) posted Mon, 25 February 2008 at 6:07 PM
No, customer support at DAZ has been contacted, but they haven't responded yet.  :(
Anniebel ( ) posted Mon, 25 February 2008 at 7:10 PM
Ok I had a play & this is my fit for Aiko 4 - default head.
Unhide the dials, as you will need yTrans & xTrans
xTrans = 2.85.72
yTrans = 16.136
Fit_Aiko = 2
Adj_forehead = 0.2
Adj_Neck = -0.434 (note neg)
Adj_FaceSide = 0.4
Incidentally, playing with this I noticed, if you scale A4 to 90% she is virtually the same proportions & body shape as A3.
Helen Keller
Neyjour ( ) posted Mon, 25 February 2008 at 7:14 PM
Thanks very much Anniebel!  😄
Purrdey ( ) posted Sun, 30 March 2008 at 3:44 AM
Mystery solved as to why this was done this way - now they are selling an A4 version of this hair as a separate product. ><
Paloth ( ) posted Sun, 30 March 2008 at 11:28 AM
It takes some tricky coding to make a hair prop that can't be scaled so you can sell it over and over again at different sizes. I'm not sure it's worth the risk for the merchants or Daz, since people might become leery about buying crippled products from them.
Download my free stuff here: http://www.renderosity.com/homepage.php?page=2&amp;userid=323368
Purrdey ( ) posted Sun, 30 March 2008 at 12:30 PM
Exactly. I'm lucky in that I can kind of buy what I want most of the time which is probably not a good thing as I tend not to think too much. I like it so I buy it.
That will change now for sure.
Mitzibear ( ) posted Sun, 30 March 2008 at 2:23 PM
Anniebell i am lost on your instructions for the a4 fit. I cannot put in no such numbers for the x and y trans. Not with dots in them. I can only put in say like 16.000
Rance01 ( ) posted Sun, 30 March 2008 at 4:39 PM
Not sure about the product here but what about exporting the thing as an .obj and re-importing the thing.  I'm sure you'd have to adjust the fit a bit and the texture would have to be re-applied in the Material Room -- transmaps don't import back into Poser so well.
Just a thought.
Haven't been to DAZ in a while (I find their Web site annoying) but I'm reading other threads about hidden scale dials.  Now why would you want to hide dials?  I guess I am unclear about this whole issue.  There's a software script just to show hidden dials?
Best Wishes,
Rªnce
Neyjour ( ) posted Sun, 30 March 2008 at 5:38 PM
Quote - Mystery solved as to why this was done this way - now they are selling an A4 version of this hair as a separate product. ><
Quote - It takes some tricky coding to make a hair prop that can't be scaled so you can sell it over and over again at different sizes.
Well, I had thought that it was just a sloppy mistake that DAZ couldn't be bothered to fix, but now I know I won't be buying hair from SWAM and Bobbie25 in the future.  And if DAZ is going to allow that kind of thing, I'm going to steer clear of buying any hair products from them, period.
Anniebel ( ) posted Sun, 30 March 2008 at 6:04 PM
Quote - Anniebell i am lost on your instructions for the a4 fit. I cannot put in no such numbers for the x and y trans. Not with dots in them. I can only put in say like 16.000
It's a typo, I am not at home at the moment, so I cannot look at the file I saved, but try instead...
xTrans = 2.8572
yTrans = 16.136
Fit_Aiko = 2
Adj_forehead = 0.2
Adj_FaceSide = 0.4
Helen Keller
Anniebel ( ) posted Sun, 30 March 2008 at 6:09 PM · edited Sun, 30 March 2008 at 6:12 PM
Quote - > Quote - Mystery solved as to why this was done this way - now they are selling an A4 version of this hair as a separate product. ><
I seriously doubt that selling fits seperate was the motive, it has been mentioned that this is done if using those dials produces questionable results, again though this is just supposition.
I have other hair by SWAM (old & new) & the dials aren't hidden, I don't have any more by Bobbie25 to compare.
Helen Keller
Mitzibear ( ) posted Sun, 30 March 2008 at 6:19 PM
xTrans = 2.8572
yTrans = 16.136
Fit_Aiko = 2
Adj_forehead = 0.2
Adj_FaceSide = 0.4
This is not working at all for me when I put those in the y trans and the other it makes the hair go way off of a4s head? maybe I am doing something wrong I don't know but its not working for me.
Mitzi
Anniebel ( ) posted Sun, 30 March 2008 at 6:43 PM
Quote - > Quote -
xTrans = 2.8572
yTrans = 16.136
Fit_Aiko = 2
Adj_forehead = 0.2
Adj_FaceSide = 0.4
Mitzi
Ok well I will check the settings when I get home this afternoon.
Helen Keller
Mitzibear ( ) posted Sun, 30 March 2008 at 6:46 PM
Thank you its really appreciated :)
Rance01 ( ) posted Sun, 30 March 2008 at 9:06 PM
Neyjour,
The product link you sent, it says there are fits for David, Hiro, Aiko and Victoria.  Just curious, your trying to put it on another figure?
I only ask because I do have hair packages from SWAM and enjoy them.  And I do like the Anime Hair you're talking about.  This issue with hidden dials confuses me though ...
Good Luck,
Rªnce
Neyjour ( ) posted Sun, 30 March 2008 at 10:33 PM
Rance01, I'm not sure what you're confused about exactly...
The Tran and Scale dials are hidden.  You have to use a script to un-hide them.  Once you've done that, you'll be able to use the Tran dials, but the Scale dials still cannot be used.  They're broken.
At first it seemed this was a "mistake" that had slipped through the testing process, and even after someone sent in a ticket about it, DAZ couldn't be bothered to fix it.  But now it looks like it was done intentionally.
There's more info about this in the thread over at the DAZ forums:
Anime Hair doesn't have Tran or Scale dials??
Anniebel ( ) posted Mon, 31 March 2008 at 12:35 AM
Sorry guys I did a major typo :blushing: when I gave you those settings, it should read....
xTrans = 0
yTrans =
285.72**
zTrans =** 16.136**
Fit_Aiko = 2
Adj_forehead = 0.2
Adj_FaceSide = 0.4**
Helen Keller
Rance01 ( ) posted Mon, 31 March 2008 at 4:42 AM
Thanks Neyjour.  That clears everything up.  I do see now you're working with V4.  My suggestion (above) was the same as 'michy's' over at DAZ ...
I like the look of the hair product but the whole unhide dial thing seems really stupid to me and I don't think I want to be bothered.  I grabbed the script sometime ago when it came up here but haven't been so sorely tempted to purchase V4 yet.  So far I don't have any of these new DAZ models.
Best Wishes,
Rªnce
SeanMartin ( ) posted Mon, 31 March 2008 at 5:17 AM
Did anyone else see this little gem? Arguably one of the most idiotic statements possible:
>> QA would still have to bow to the decision of the artist, since technically, it's not a problem if the scale dials are hidden, because they are not meant to be used
Uh, right.........
Mitzibear ( ) posted Mon, 31 March 2008 at 6:41 AM
Quote - Sorry guys I did a major typo :blushing: when I gave you those settings, it should read....
xTrans = 0
yTrans =
285.72**
zTrans =** 16.136**
Fit_Aiko = 2
Adj_forehead = 0.2
Thanks Anniebel. I will check those out this morning :)
Mitzibear ( ) posted Mon, 31 March 2008 at 6:53 AM
Quote - > Quote - Sorry guys I did a major typo :blushing: when I gave you those settings, it should read....
xTrans = 0
yTrans =
285.72**
zTrans =** 16.136**
Fit_Aiko = 2
Adj_forehead = 0.2
hmm still not getting these to work for me. Everytime I do them again the hair is way off of the head :(
