Forum Moderators: RedPhantom
Quote - I poked around and changed the following:
Under the RENDER tab and then under IMAGING, there is a section called TONE MAPPING.
I changed the Kernel: drop down option from LINEAR to REINHARD / NON-LINEAR and you should see something.
I'd suggest everyone invest 10 minutes reading through the short and concise online manual of Lux, so you know what all those things actually do...
Quote - That's why I was asking about memory, if the crashes depend on the number of objects loaded and not on which object is loaded, then you might be running out of memory.
The problem isn't tied to the number of objects in the scene, just to specific objects. I could load any of these scenes into Carrara or render in P7 with no trouble. Turning objects on one at a time was just the method to find which ones were the problem. Even exporting out just the one object caused a crash in Lux.
Quote - I know this was prolly answered in the post. Have not had a chance to read it all. What light types work from poser to Lux? Not sure where to insert the sun parameter into the lxs file.
LightGroup "sun"
LightSource "sunsky"
"float gain" [0.050000]
"vector sundir" [0.965955 -0.026948 0.257303] "float relsize" [1.000000]
"float turbidity" [2.000000]Great work on the exporter and thank you.
After "WorldBegin
WorldBegin AttributeBegin
LightSource "sunsky" "integer nsamples" [1]
"vector sundir" [0.70000 0.400000 0.700000]
"color L" [1.000000 1.000000 1.000000]
"float aconst" [0.500000] "float bconst" [0.500000] "float cconst" [1.000000] "float dconst" [1.000000] "float econst" [1.000000]
"float relsize" [2.000000]
AttributeEnd
"That government is
best which governs the least, because its people discipline
themselves."
Thomas Jefferson
To the powers that be - What about making a special Luxrender (sub)forum, to keep the development discussions, the tips and tricks and the metaphysical debates (like "Lux stinks anyway") separate, inside different threads?
I don't know if you can do this, but at the speed this thread here is growing and the progression of the growth (more and more people come), by the time the exporter hits beta, it will have reached several hundred pages (and probably bog down your database).
Just a suggestion.
Quote - If you want really blue skies, try this:
AttributeBegin
AttributeEndThis is from rty's post several pages back
Linked pic is using this.
Just read this and now looking at your settings
The physical sky creates a lighting setup that simulates the light of the sun and atmosphere, based on the direction of a sun lamp in the scene and a parameter named turbidity which defines the clearness of the sky. Both the sun angle and the sky clearness influence the colour of the light.
Additional parameters called aconst, bconst, cconst, dconst, econst allow you to fine tune the color of the sky to simulate various atmospheric conditions.
Where did you set the Sun Angle?
or is that this part?
Thanks,
"That government is
themselves."
Thomas Jefferson
Quote - To the powers that be - What about making a special Luxrender (sub)forum, to keep the development discussions, the tips and tricks and the metaphysical debates (like "Lux stinks anyway") separate, inside different threads?
Just a suggestion.
Don't waste your time ;o).
We would have made one on our forum, but no one goes there...lmao.
It's hard to get RO to make a new forum. They refused a Matroom subforum, a Sketchup forum, etc. Not sure what the deal is, but seems you practically need to promise your firstborn ;o).
Quote - > Quote - I poked around and changed the following:
I changed the Kernel: drop down option from LINEAR to REINHARD / NON-LINEAR and you should see something.I'd suggest everyone invest 10 minutes reading through the short and concise online manual of Lux, so you know what all those things actually do...
I approached this as newbie who doesn't know anything about LUX and editing.
I just grabbed the exporter, read the the text file, and went to town with my copy of Poser.
So yeah, we could read the fine manual, but what FUN would that be. ::biggrin::
Intel Core i7 920, 24GB RAM, GeForce GTX 1050 4GB video, 6TB HDD
space
Quote - Where did you set the Sun Angle?
Yes, that's the problem with the partial quotes...
So I'll post this again (I guess it will see some heavy use till BagginsBill releases his light control GUI):
To insert a sunsky (sun+skydome) in Lux:**
Edit the .lxo file in notepad and delete the existing, exported light (on top of the file, pretty obvious, it's well commented), then open the .lxs file and insert after WorldBegin:
AttributeBegin<br></br>
LightSource "sunsky" "integer nsamples" [1]<br></br>
"vector sundir" [0.70000 0.400000 0.700000]<br></br>
"color L" [1.000000
1.000000 1.000000]<br></br>
"float turbidity"
[2.000000]<br></br>
"float aconst"
"float econst" [1.000000]<br></br>
"float relsize"
[2.000000]<br></br>
AttributeEnd
Insert empty lines if you want to separate the rest.
As you might have guessed, "vector sundir" determines where the sun is in the sky (caveat: Z is height!). The "float" parts control sky haze (sky color, ranging from clear mountain air to sand storm or heavy smog).
Quote - So yeah, we could read the fine manual, but what FUN would that be. ::biggrin::
The first problem is misinformation, since this thread is unreadable (if you miss more than a day), and second it makes it even harder to read since everyone will post the same basic questions again and again, page after page ("my car has 4 seats, do I need to sit behind the steering wheel to drive, or can I pick just any place?"- type ones).
Tone mapping is how Lux manages to make the extended luminosity range fit into our low-range displays.
Reinhard is a cheat, much like an audio compressor is for sound.
Linear works like a photography camera, if you have ever used a real one (not a point & click one), you'll feel at home, having settings for film sensitivity, Exposure (shutter time), FStop (aperture), and gamma.
Contrast tries to keep contrast, but unlike Reinhard it works on the whole picture instead of zones.
MaxWhite does what it says: It considers the brightest value to be white, period.
Linear is the only linear (duh) setting, so for quality, it's the one to use. Next in quality comes Reinhard, although, like with an audio compressor, you degrade your signal. Next comes Contrast, which really should be only used in very specific cases, and last MaxWhite, for which I don't really see a situation it might be the preferred choice.
Just set Ambient_Value to anything other than 0 and that makes it a light source.
You can plug image maps into the Ambient_Color. Or anything else that is currently supported by the material converter, such as Blender and Clouds.
Note: Light source objects render without any antialiasing. I have no idea why or what to do about it.
Note 2: Light source objects cannot also use alpha maps. Every polygon is a light source in its entirety.
Quote - > Quote - Where did you set the Sun Angle?
"vector sundir" [0.70000 0.400000 0.700000]Yes, that's the problem with the partial quotes...
So I'll post this again (I guess it will see some heavy use till BagginsBill releases his light control GUI):To insert a sunsky (sun+skydome) in Lux:**
Edit the .lxo file in notepad and delete the existing, exported light (on top of the file, pretty obvious, it's well commented), then open the .lxs file and insert after WorldBegin:AttributeBegin<br></br> LightSource "sunsky" "integer nsamples" [1]<br></br> "vector sundir" [0.70000 0.400000 0.700000]<br></br> "color L" [1.000000 1.000000 1.000000]<br></br> "float turbidity" [2.000000]<br></br> "float aconst" [0.500000] "float bconst" [0.500000] "float cconst" [1.000000] "float dconst" [1.000000] "float econst" [1.000000]<br></br> "float relsize" [2.000000]<br></br> AttributeEnd
I do have a question about all of this. When i look at log that is generated when loading the luxfile, I see it says that aconst - econst are not used. I find that curious as to why, if it is documented to use those.
Quote - any object you want can be a light.
Great!
Can I also select if it will be a blackbody/spectral or RGB light (so I can make fluorescent lamps, neons and hot lava?)
Quote - I do have a question about all of this. When i look at log that is generated when loading the luxfile, I see it says that aconst - econst are not used. I find that curious as to why, if it is documented to use those.
Well, I don't know, one would have to ask this over at the Lux forums.
As I said, I took the values from their test files, so it might be those values aren't used anymore. They are documented as being the settings for atmospherics (haze), that's all I can say...
Quote - > Quote - any object you want can be a light.
Great!
Make a wish list. I'm not going to remember all this.
Lux Light:
To use a "skyglob" with a HDR Image attached, use this for example:
LightSource "infinitesample"
"string mapping" ["latlong"]
"color L" [1 1 1]
"float gain" [500]
"string mapname" ["path/filename_to_your.hdr"]
AttributeEnd
AttributeBegin
LightSource "distant"
"color L" [0.75649095 0.87289506 1] # sun color
"float gain" [1637.0247]
"point from" [1.0153754 -3.1502762 3.7476354]
"point to" [0.81230026 -2.520221 2.9981084]
AttributeEnd
As you see here, "distant" light is used for this. For Posers "infinite-lights" we have to use "infinitive" in Lux also. Until Alpha_10d "distance" where used.
Quote - I got this error message frequently when exporting:
"Loading pydough.geometry_export*
2010RuntimePythonposerScriptsScriptsMenupydoughPoserunimesh.py", line 108, in collect_data** nr_tpolys = sum([len(actor.Geometry().TexPolygons())*TypeError: len() of unsized object"
I found out that Posemagic Pro was causing this error. Is there a way around this or should I just avoid using Posemagic when exporting to Lux?
If the TexPolygons() call returned a None object, that would explain that error message. I'll change my code to catch that. I don't know what Posemagic does and how it works, though, so I can't guarantee that it will fix your problem.
Quote - > Quote - Great!
Well, you have it. Only thing I really want, is to have the physically correct lights Lux provides:
Blackbody (physical emission spectrum - enter temperature)
Spectral (spectral ones, enter a spectrum, get a light, can be used to make realistic fluorescent light)
RGB (now this is the type of light Poser has, it has a color. Usable for colored lights)
(IES support would be nice, but that can wait v2).
Check here: http://www.luxrender.net/v/manual_lighting for more description.
Quote - > Quote - That's why I was asking about memory, if the crashes depend on the number of objects loaded and not on which object is loaded, then you might be running out of memory.
If you can identify which objects make Lux crash, let me know. Hopefully not something I'd have to buy (because as I'm not making any money from this, I can't be buying stuff to test it with Lux).
Anyway, Lux used to crash on me on a regular basis. I now close the program after each render and start it again for the next. No more crashes since then.
Quote - @odf - nevermind about the transform. I was being stupid. It was 3-line change. All done.
I'm glad you figured it out.
I might still add an option to apply an arbitrary transformation to an object when exporting the geometry, as it could be useful for including posed figures into scenes created with other applications.
Ah yes, quite right ;o). Better yet, they all need some pages with a big fat DONATE button on them. I certainly will ;o). You just can't get them the wrong thing if you give them money...lmao. The only trouble with that is, odf and and adp would both get screwed by anyone from the U.S. because of the dollar to euro conversion ;o).
What's a Euro? We use Australian Dollars here. :laugh:
Quote - > Quote -
Ah, but with the junk status of the U.S. dollar, I bet ya still get screwed...lol ;o).
Quote - Lux Light:
Forgot to copy some lines:
AttributeBegin
Transform [1 0 0 0 0 1 0 0 0 0 1 0 0 0 0 1]
"color L" [1 1 1]
"float gain" [500]
"string mapname" ["path/filename.hdr"]
AttributeEnd
Quote - Can't you guys just tell smithmicro ( makers of Poser) to make Poser render using Lux engine( or whatever it's called)?
Instead of trying to implement it yourselves
Question for you:
If you're not even sure what the programmers are doing or even what LuxRender is called, then why are you commenting? Just askin ;o)
One more thing (since you haven't been around as long as some of the rest of us):
Most major advances with Poser since version 4 have been discovered BY USERS, not by the owners of the program. Just a nice tidbit of info for ya ;o).
It's guys just like this little group here who have made Poser enjoyable for the rest of us. Don't diminish their work. It's actually pretty ground-breaking.
In another thread, josterD said:
Quote - Sports players don't deserve the amount of money they make. No matter what.
Also programmers don't deserve it. If they deserve it, laborers also should get the same.
Laborers do so much work and they get so little. If you think Programmers deserve so much, then give the same to laborers.
I work for money. I work for free. Either way, I can't please this guy.
And should be very low on your list of people to please ;o). Most of us feel this whole thing is pretty awesome...lol. Anyway, if you could be paid for asking silly things, well then... (hint given)
;o)
Can you include a option to use the sun, but not the sky in your GUI please? OR be able to change the color easy with a slider? Also, could you have a option for in poser, to make a light, name it sun so you can move it around easier in the scene?
Great job everyone and thank you for making this plugin.
For the Daz crowd, that program can be free and then pay for the plugin. Pay for Poser and get the plugin for free. I dont understand why people complain.
AttributeBegin
"color L" [1 1 1]
"float gain" [300]
"string mapname" ["tex/Factory_Catwalk_Bg.jpg"]
AttributeEnd
One additional spot is used to get some shadows.
The background image is a "latlong" map I found somewhere on the net. Don't remember where. But you can find a some in your Poser texture folder under HDRVFX. For spherical images in there replace "latlong" above with "spherical".
Rendertime 35 minutes.
Quote - Can you include a option to use the sun, but not the sky in your GUI please? OR be able to change the color easy with a slider? Also, could you have a option for in poser, to make a light, name it sun so you can move it around easier in the scene?
Yeah, I'll make separate options for sun and sky.
In any case, you control it with a Poser infinite light. The direction and intensity come from Poser, not from the Luxpose GUI. All you're doing in the GUI is telling the exporter that you want to use the Poser infinite light(s) as "suns". I tested it with two suns and that works as well.
Yeah that's probably the best solution. The script comes with Posemagic Pro but I haven't tried it yet :)
Vestmann's Gallery
