Fri, Jan 17, 3:22 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 17 1:54 pm)
Subject: Lighting in Superly (Poser 11)
rokket ( ) posted Mon, 11 July 2022 at 8:29 AM ยท edited Fri, 17 January 2025 at 3:18 PM
Content Advisory! This message contains nudity, violence
I have been struggling with the settings to get decent renders with Poser 11 Superfly with lower lighting in scenes. I let this render go for nearly 8 hours, and I still have issues with artifacts left in her crotch area.
Any suggestions and tips from veteran users would be great. Post screen shots of your render settings and lights, please.
This was the Sci fi hanger prop and light set that came with it. I didn't use ezdome or the construct in this scene. Maybe I should have? But the IBL sets that I have for ezdome don't really match the hanger lighting and make it too bright.
I may try this render again with the ezdome, but I will have to search for an IBL set that has lower light settings. I know I can change the settings in the lights, but I'd rather not have to spend a lot of time tweaking and doing test renders.
Liquid_Ice ( ) posted Mon, 11 July 2022 at 9:58 AM
What source are you using for the ibl? Are you using an hdr? If so polyhaven might have hdri's you are looking for.
hborre ( ) posted Mon, 11 July 2022 at 10:11 AM
Online Now!
IBL is not supported by Superfly, you need to find another source of lighting either generic or photorealistic for your scene.  I'll need to look at the model before I make some suggestions.  I imagine that you are rendering with stray fireflies in the scene.
hborre ( ) posted Mon, 11 July 2022 at 10:22 AM
Online Now!
bTW, what is the name of this set?
rokket ( ) posted Mon, 11 July 2022 at 11:57 AM
The set is the SCI FI Hanger. It was a freebie I got somewhere. It renders well in Firefly, as it's a bit older. I haven't adjusted any of the materials and I haven't changed the lights.
Using the EZDome isn't an option, because the lighting from the dome doesn't penetrate the model. It's a solid hanger model, so I am looking at other ways to get it done. I changed the color of all the lighting from the purples and blue hues to all white, but I haven't done a complete render. I stopped the render after about 12 samples because I had a visitor come over.
I am using HDR Haven for EZDome.
rokket ( ) posted Mon, 11 July 2022 at 11:59 AM
Liquid_Ice posted at 9:58 AM Mon, 11 July 2022 - #4441041
I am using Polyhaven's stuff. I downloaded a lot of the HDR's from them when they were HDR haven. I went on there this morning and downloaded some of the HDR's, but I am not sure how to load them in EZDome...
Rhia474 ( ) posted Mon, 11 July 2022 at 12:36 PM
Online Now!
Not at my computer atm, but if I recall correctly, EZDome does not accept hdrs (error messages).
The user guide you get for the Poser 11 version suggests you use the sIBL archive (url provided) to load.
If it is a completely closed hangar, i also would suggest to see if you can delete or make invisible a wall you don't have in your camera view so light can enter .
hborre ( ) posted Mon, 11 July 2022 at 1:06 PM
Online Now!
Rhia474 posted at 12:36 PM Mon, 11 July 2022 - #4441055
That is not entirely true.  You can load HDRIs into EZDome but considering that the hangar is completely enclosed, it is a mute point to set up such lighting.  An sIBL file can be created but you need alternate software for compose the different components.
Rhia474 ( ) posted Mon, 11 July 2022 at 1:39 PM ยท edited Mon, 11 July 2022 at 1:42 PM
Online Now!
Okay that's good to know. Every time I try to load a hdri file to ezdome it gives me an error message. I may need to redownload it.
I am not a fan of completely enclosed rooms hence my suggestion about a wall or ceiling made invisible/removed. I would be interested to see what solution is suggested that works.
Area lights perhaps?
Eta: I am fond of loading a hdri onto the background node using the material setup from ghostship2's tutorial, but OP uses Poser 11 and I use P12.
Y-Phil ( ) posted Mon, 11 July 2022 at 2:03 PM ยท edited Mon, 11 July 2022 at 2:03 PM
When it comes to EZDome: I'm using an HDRi on the external sphere and its JPG counterpart on the inner sphere: it's easier to position. I create the JPG  using Photoshop but I suppose that there are other optons as well.
Here's an example. The preview picture is most of the time a small one
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟ Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
๐Ÿ‘ฟ Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
๐Ÿ‘ฟ Nas 10TB
๐Ÿ‘ฟ Poser 13 and soon 14 โค๏ธ
hborre ( ) posted Mon, 11 July 2022 at 2:15 PM
Online Now!
I managed to find the Sci-Fi Hangar at ShareCG.com and discovered that there is an open-end for environmental lighting to enter.  Apparently, the amount of environmental light needed to illuminate the hangar will be relatively high.  Instead of using the EZDome, I'm placing an HDRI into the Poser background and ramping its intensity.  But, by doing this, there will be an increase in background noise in the scene.  I'm experimenting now with lighting.
hborre ( ) posted Mon, 11 July 2022 at 2:21 PM ยท edited Mon, 11 July 2022 at 2:25 PM
Online Now!
Y-Phil posted at 2:03 PM Mon, 11 July 2022 - #4441061
There is a small app that can convert HDR to JPG if you are looking to use the same image for the EZDome: Easy2Convert HDR to JPG.  IIRC, will produce a high-res image.
I noticed that your screencap is showing a low-resolution HDRI, be very careful with low dynamic range images, they are notorious for causing fireflies when rendered with SSS in Superfly.
hborre ( ) posted Mon, 11 July 2022 at 2:28 PM
Online Now!
This is what I have so far with Blackbody overhead lighting and a high-intensity HDRI background.
Rhia474 ( ) posted Mon, 11 July 2022 at 2:41 PM
Online Now!
If you use the sIBL Archive, the zips come with jpg, HDR and ibl included.
Thanks for the tip on usage, Y-Phil!
hborre ( ) posted Mon, 11 July 2022 at 3:12 PM
Online Now!
Yep, and sometimes you come across a magnificent HDR image that you would love to have as an sIBL for EZDome but don't have the companion files.  I use sIBLedit to create such files with strict control over the intensity and composition of the images.
rokket ( ) posted Mon, 11 July 2022 at 3:30 PM
I am experimenting with those overhead lights right now.
Update when I get one.
I am happy to see that a thread I started is getting responses. I haven't seen this much attention since the old days when my threads would reach 300-400 pages...
hborre ( ) posted Mon, 11 July 2022 at 3:48 PM
Online Now!
Overhead mesh lights using actual photorealistic light settings in degrees Kelvin.  The actual temperature will determine the light color that is not artificially tinted.  This setup has Inverse Square activated.
rokket ( ) posted Mon, 11 July 2022 at 4:22 PM
hborre posted at 3:48 PM Mon, 11 July 2022 - #4441074
Perfect. Let me try that out and I will post an update!
rokket ( ) posted Mon, 11 July 2022 at 4:27 PM
All the materials are in German(?) I think...
I don't know what the lights are...
rokket ( ) posted Mon, 11 July 2022 at 4:58 PM
I found it...
hborre ( ) posted Mon, 11 July 2022 at 5:13 PM
Online Now!
Fortunately, most of the materials have the same shader arrangement, just different texture maps associated with them.  I just revamped the lights to Inverse Square and changed one to high-intensity area light.  I'm trying to keep it close to physically realistic without making it photorealistic if you know what I mean.  I am noticing that the overhead mesh lights are causing a bit of firefly background because I ramped the intensity a little higher than illustrated above.  I also made some material changes but those are easy to manipulate.
hborre ( ) posted Mon, 11 July 2022 at 5:20 PM
Online Now!
How is this?
If I was in P12, I would denoise this to get rid of the fireflies.  Overall, adding the PhysicalSurface PBR improved the texture response to the lighting.  With the exception of the Area light, all the lighting was converted to inverse square and the intensities increased to match the scene.
rokket ( ) posted Mon, 11 July 2022 at 6:16 PM
So you used the lighting that came with the prop?
Can you post a render with a figure in it?
And can you post a screen shot with your material set up?
Rhia474 ( ) posted Mon, 11 July 2022 at 6:45 PM
Online Now!
That's a lovely light set up, hborre, thanks for showing it.
hborre ( ) posted Mon, 11 July 2022 at 7:05 PM ยท edited Mon, 11 July 2022 at 7:05 PM
Online Now!
Sure.  I just finished a quick background render with a figure in it.  Forgive the nudity, I needed something available for Superfly rendering.  Anyway, the V4 model has a PBR procedural SSS skin with a base texture, a total rework of a Syyd Raven set he published at RDNA.  You might find it at the DAZ store.  I am beginning to apply the same procedural shader to other models.  This is what I came up with:
It's a little grainy due to some of the mesh lights but it gives it a film quality.  Screencaps of the materials and lights to come.
ghostship2 ( ) posted Mon, 11 July 2022 at 7:22 PM
This is what I do. Add some primitive boxes to your scene and scale them into the size/shape of florescent lights. I just use a Poser root node with only ambient used. Set the strength to the desired amount. remember to use several of them to simulate light fixtures.
rokket ( ) posted Mon, 11 July 2022 at 7:24 PM
That is looking like what I am trying to achieve. I am rendering now...
hborre ( ) posted Mon, 11 July 2022 at 7:31 PM ยท edited Mon, 11 July 2022 at 7:31 PM
Online Now!
These are the modifications I made to the lights that come with the set.  Lights 1 and 8 were turned off, they did not contribute anything to the section of hangar I was using.  This is the same area that you used in your render, Rokket.  I wanted to treat this render as close to physically accurate as possible, all lights converted to inverse square with the exception of the area light that lacks this feature.  If you want a longer depth of light then use inverse linear as a choice.  The screencap below is an image of D3D's XLC (eXtended Light Control script) that works very well in P11.  You can find it under Scripts.  It is totally absent in P12.  This will give you an idea of how much I changed the intensity of each light.
The area light was scaled 900,000 %!  Keep in mind, that this is a huge model.  V4 was scaled to 250% to fit the scene a little better.  The area light is a substitute for the HDRI, although I did provide one in the Poser background, I would have needed to increase its intensity to properly illuminate the hangar.
rokket ( ) posted Mon, 11 July 2022 at 7:35 PM
Thank you!
I will look for that script. I never paid much attention to the scripts already in Poser. I guess I should...
hborre ( ) posted Mon, 11 July 2022 at 7:36 PM
Online Now!
Yep, self-illuminating primitives work very, I have used those on occasions, even made them invisible yet glowing.  I have moved away from the Poser root for ambient lighting, Blackbody illumination is my preferred method unless there is color involved.
Rhia474 ( ) posted Mon, 11 July 2022 at 7:46 PM
Online Now!
Neat script in P11, I had no idea it existed. I wish they kept it for P12.
I'm learning a lot today, guys, keep it coming and thank you.
hborre ( ) posted Mon, 11 July 2022 at 8:25 PM ยท edited Mon, 11 July 2022 at 8:25 PM
Online Now!
Blackbody nodes for the lights for physically accurate rendering.  Sure I could fake it and visually guesstimate it but why when the renderer can do it and the feature is available.
hborre ( ) posted Mon, 11 July 2022 at 8:40 PM ยท edited Mon, 11 July 2022 at 8:40 PM
Online Now!
From what I've seen, most of the shaders are basically set up the same way, very simplistic, and very easy to convert to PBR.  P11 doesn't have a PrincipledBsdf node, so the next best solution is to use the PhysicalSurface node without going completely into Cycles (my preference).  This is the rudimentary change I made to some of the material in the render field of view.  I just noticed that the Roughness channel should be slightly higher and the Metallic channel increased to around 0.8 to give the material some reflective properties.
Keep in mind, that if you use Superfly rendering, just about every surface in your scene should reflect some degree of light to help brighten up the surroundings.  Next time you watch a movie with a nighttime outdoors scene, observe the ground, it is always wet with water, a highly reflective medium.
rokket ( ) posted Mon, 11 July 2022 at 8:46 PM
Very cool. The render I am working on may take until tomorrow to finish, but I'll post the results...
rokket ( ) posted Mon, 11 July 2022 at 9:54 PM ยท edited Mon, 11 July 2022 at 9:56 PM
More than one way to skin a cat...
This time the trick was to make the overhead lighting work for me. I changed the Poser surface to a Physical surface and amped up the emitter quantity.
There are no other lights in the scene.
Thanks for the tip, Traci!
rokket ( ) posted Mon, 11 July 2022 at 9:55 PM
I see that she is not quite touching the ground... I will have to fix the pose now... sheesh
hborre ( ) posted Mon, 11 July 2022 at 10:30 PM
Online Now!
Big difference from your original render and it works very well.  BRAVO!  I rendered my creation with a higher render setting subsequently making a brooding image of a creature in the shadows.  I'll get to posting it tomorrow.
ghostship2 ( ) posted Mon, 11 July 2022 at 10:32 PM
That looks great! Reflections on the helmet  help sell it.
Y-Phil ( ) posted Tue, 12 July 2022 at 1:38 AM
hborre posted at 2:21 PM Mon, 11 July 2022 - #4441065
Oh? ok thank you for the info  ๐Ÿ˜„
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟ Nas 10TB
rokket ( ) posted Tue, 12 July 2022 at 6:53 AM
hborre posted at 10:30 PM Mon, 11 July 2022 - #4441122
Yeah, I want to see it. Besides fixing her feet, I am going to do something about the rifle she has strapped on her back. Can't even see it unless you know it's there. That can be a good thing if it was real life combat, but in this case, I want it seen...
rokket ( ) posted Tue, 12 July 2022 at 8:52 AM
ghostship2 posted at 10:32 PM Mon, 11 July 2022 - #4441123
I made that helmet for Miki, then I used your materials (car paint) on it. So it looks great because of your work. Thank you for the awesome materials.
Rhia474 ( ) posted Tue, 12 July 2022 at 9:03 AM
Online Now!
Looks really cool! I faffed a bit with that set yesterday, couldn't figure out what the overhead lights' material was as my German is pitiful.
hborre ( ) posted Tue, 12 July 2022 at 9:05 AM
Online Now!
I used Google to translate.
hborre ( ) posted Tue, 12 July 2022 at 9:10 AM
Online Now!
Here is the last render I made before retiring for the night.  I'm going to revisit some sections of this scene to see if I can improve it.  I'm going to look closely at her eyes, I've been swapping out some nodes and including the GlassBsdf node.
rokket ( ) posted Tue, 12 July 2022 at 9:46 AM
Gives me an idea for a follow on scene. Since the original idea is that she is an operative with a secret life she is forced to reveal to her husband, and he gets taken by a clandestine group to force her to confront them. She ends up in this hanger, where she encounters the aliens. Why not have her encounter a V4 creature like that? Could have her crouched down and hiding from the light. A failed experiment or something...
rokket ( ) posted Tue, 12 July 2022 at 9:48 AM
Rhia474 posted at 9:03 AM Tue, 12 July 2022 - #4441149
It's the material glas-lampe
Rhia474 ( ) posted Tue, 12 July 2022 at 10:32 AM
Online Now!
Thank you... had a W40K style thing pop in my brain last night. Your heroine sounds cool.
hborre ( ) posted Tue, 12 July 2022 at 11:35 AM
Online Now!
WOO-HOO!  I finally figured out how to do inverse square and blackbody illumination with the PoserSurface.
Shader:
Render, overhead mesh alone:
rokket ( ) posted Tue, 12 July 2022 at 1:16 PM
I know it probably takes quite awhile to render, but I'd love to see it.
I made a huge mistake in the render I submitted. I had added the developer work lights to the scene so I could arrange the aliens. I forgot to delete them before I rendered. SO, what I posted is not an accurate representation of the lighted scene. I didn't discover it until I had already deleted the aliens. So I am going to redo the render without the lights. And without the aliens...
hborre ( ) posted Tue, 12 July 2022 at 1:50 PM
Online Now!
ATM, I'm running a high-quality render that I may consider a 'final' copy.  I previewed the existing lights through D3D's XLC script and made changes to their light intensities.  I want those lights to compliment the mesh illumination without overwhelming the mood of the scene.  So far, I like what I am seeing.
Y-Phil ( ) posted Tue, 12 July 2022 at 3:50 PM ยท edited Tue, 12 July 2022 at 3:50 PM
Rhia474 posted at 7:46 PM Mon, 11 July 2022 - #4441105
It's the reason why I partially rewrote my own version, to which I've added the functions I needed (on/off by group of lights, double-click to activate the corresp. cam)
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟ Nas 10TB
