DAZ|Studio F.A.Q (Last Updated: 2024 Oct 01 1:56 pm)
If you do a google search, you will find some links that tell you how to do it using the transfer tool within DS, including a link found in the daz forums. You may need to do some tweaking using something like blender. I moved a G9 shape back to G8M using the transfer tool. If you wrote your thread using the same tone you used here, then that's probably why the thread was deleted.
Thing is I am not the only one not a fan of what they did though dude. Many people are still only using g3 and g8 and not even trying g9 at all. Just reusing g9 clothing, poses, etc on g8 models. Geografts have bene atrocious to use, like for one Breastacular can't even use well on g9. Meipe already said that with it being a UNIMESH, you can only use breastacular's morphs only. If you use other morphs, it screws it all up and makes it deformed. Oh well, guess I will just keep using g8 and wait till g10 and heres hoping they return to normal and separate the female and male meshes...
Meipe did post some instructions on how use your morphs with breastacular in the 'rotica forums if you need to combine. It is a little bit of work, but i don't think the process is any different than getting the male gens product for G8 to work with other male shapes that had a different scale than the default one. But the vendor has been very good with support with other shapes. But between DS and blender you can get what you need for your characters.. Geografts have bene atrocious to use, like for one Breastacular can't even use well on g9. Meipe already said that with it being a UNIMESH, you can only use breastacular's morphs only. If you use other morphs, it screws it all up and makes it deformed. Oh well, guess I will just keep using g8 and wait till g10 and heres hoping they return to normal and separate the female and male meshes...
Might you have some screenshots or rendered examples Male_M3dia ?
An 8 or 8.1 rig is entirely different from the 9 series when exported out via FBX; # of bones, weighting, etc., so always thought it a bit of like unbaking a cake.
But doing the conversion within DS prior to, makes it a different story.
Anytime someone complains about "woke", I stop listening. Not that I like G9, but if you used that political charged combat term "woke" in the DAZ forum, I'm not suprized they deleted it. For a good reason....they are literally doing damage control on this WOKE infested model.
DocPhoton posted at 9:56 PM Thu, 19 September 2024 - #4489531
I don't have renders of the gens issues, you'd have to go back the 'rotica forum for examples. But the issue was not with the rig, it was with scaling for the rig. I believe if you applied the gens to a creature/character (like one of RawArt's characters or characters that scaled over 103%) that was larger than the base G8M the gens would load in the wrong spot and be warped. Meipe did provide fixes for those characters that had the issues. The hot fixes provided may not be in the product but in the forum posts that address the issue. Meipe provided the breast solution for G9 (and i believe included it in the download... i'd have to redownload it and check) because it would be impossible to do every single breast morph because everyone tinkers with them and then some vendors do custom shapes as well.Might you have some screenshots or rendered examples Male_M3dia ?
I play around with the gens from time to time, but usually I use the base gens for G8/G9 and do my own custom morphs.
There are also some 3rd party products that convert the mesh and the textures as well, they cost more but does the job. I think Wrap4 (zwrap if you have zbrush) will convert the mesh and Ultimate Unwrap3D pro will convert skins. Those products require you to put the meshes in the same pose or shape to work and hide/move the eyes, eyelashes and teeth so it doesn't mess up the conversion.There has several converters that work really well and they are at the Daz Store. They convert some G8 to G9 characters. I too was against using G9, there are some strange things going on with it, but as new figures come out for G9 I try them and if I like them I use them.
Male_M3dia posted at 4:05 AM Fri, 20 September 2024 - #4489537
I've run into the Scale issue with other products, & is just one of the Gotcha's on my to-look-out-for checklist for when things are's "meshing" so to speak. ;) So nothing unique to G9 in any case.DocPhoton posted at 9:56 PM Thu, 19 September 2024 - #4489531
Bottom line for me at least, is it really worth the time? I've seen very, very few G9 items that weren't mostly a re-hash of something already done in a previous Gen version. Newer doesn't always mean better.
I transfer morphs between them all easily enough using clone shapes and fitting the base resolution meshes to each other and exporting obj files for morphloader
just adjust rigging to shape, run erc freeze, save the new morph and you are good to go
there is no conspiracy and multitudes of tutorials out there
you may need to repose the thigh in/out for G9 as a bit different before creating your morph shape
...they are literally doing damage control on this WOKE infested model. every single time someone mentions about if and when a g9 to g8 morph conversion tool is on the way or asking about it, they delete it. im sorry but TRUTH HURTS. g9 was pandering. i will not ever use that model, but I will use the characters when they make a g9 to g8 conversion like many others are patiently waiting for. sad part is, whoever makes one, they won't be able to sell it on daz cause they won't allow it. oh well, guess they better make sure gen 10 with Daz 5 better be separate meshes again wont they?
