40 threads found!
EagleWing1000 | 10 | 2810 | ||
EagleWing1000 | 9 | 2032 | ||
EagleWing1000 | 10 | 1471 | ||
EagleWing1000 | 5 | 1718 | ||
EagleWing1000 | 8 | 146 | ||
EagleWing1000 | 11 | 763 | ||
EagleWing1000 | 3 | 682 | ||
EagleWing1000 | 6 | 866 | ||
EagleWing1000 | 20 | 528 | ||
EagleWing1000 | 4 | 145 | ||
EagleWing1000 | 2 | 145 | ||
EagleWing1000 | 6 | 976 | ||
EagleWing1000 | 2 | 2042 | ||
EagleWing1000 | 2 | 346 | ||
EagleWing1000 | 2 | 1290 |
71 comments found!
Cool, thanks for the info. much appreciated.
Dell XPS M1730
Intel Core 2 Duo T9500 2.6Ghz
500GB (2x 250GB) RAID 1 Sata HDD
4GB RAM
Nvidia GeForce 9800M GTX SLI
Thread: 3D Eagle | Forum: 3D Modeling
Ok, I was affraid that might be the answer. Thanks guys, much appreciated for your time, it definately looks that way. Cheers,
EW.
Dell XPS M1730
4GB RAM
Already tried that guys, I would just post on here without trying that first haha.
None of what it's returning are reference images you can use for 3d modeliing though, and by that i mean orthographic views of an eagle.
EW
Dell XPS M1730
4GB RAM
Thread: Adding A Smile | Forum: Photoshop
Quote - Becoming friends with the liquify tool couldn't hurt either, even if you aren't stuck using an old version that doesn't have warp. (It takes a bit of practice, but it's possible to change an entire facial expression with that one.) It looks like you got it close enough already though, so this advice is a bit late.
Thanks for the advice anyways and yeah I agree, though I've found if you push things too far with liquify in proportion, to where there is obvious stretching, then the clone stamp tool is then needed., thanks.
Dell XPS M1730
4GB RAM
Dell XPS M1730
4GB RAM
Dell XPS M1730
4GB RAM
gotcha, I understand. will give it a go and post back. thanka again Twisted_Symmetry.
Dell XPS M1730
4GB RAM
Quote - It can be done. More to the point, it can be done better with good source and destination material. The straight-on smile just doesn't jive with the angle-on destination - plus you have to do more than paste the smile and wrinkles, you have to fix the nostrils to sell the smile - given the destination file is also highly compressed, it makes marrying the source a little more time consuming. Color-correction not withstanding.
thanks for the reply, much appreciated.
What you did there looks very good. did you copy the pixles of the cheek wrinkles aswell as the mouth to get that result? Also what do you mean by "color-correction not withstanding"?
Regards,
EW
Dell XPS M1730
4GB RAM
Thread: After Effects Question | Forum: Photoshop
@thundering1
Yay! that's the beuty i'm looking for. Cheers mate.
Dell XPS M1730
4GB RAM
Thanks graphicnovel.
Dell XPS M1730
4GB RAM
THanks guys, I will check out Creative Cow forums.
For some reason you can't in AE have a Ramp (gradient) applied to the text AND utilise the Stroke effect, the moment you apply the stroke effect it removes the ramp.
@Graphicnovel:
What/where do I find that Dynamic Link thingy?
Cheers guys.
EW
Dell XPS M1730
4GB RAM
Thread: Software required | Forum: 3D Modeling
Many thanks for the link. I'll look into it, some nice looking models there.
Dell XPS M1730
4GB RAM
Wow, many thanks guys, knew this was the right place to ask.
both are what I'm looking for it looks like, especially the link by Shawn.
Thanks again,
EW.
Dell XPS M1730
4GB RAM
Thread: Copyright Owner | Forum: Photography
Cheers pushinfaders. thanks for not taking it the wrong way
Dell XPS M1730
4GB RAM
Sorry if I upset anyone, I was just following advice given to me by member: bobbystahr.
Dell XPS M1730
4GB RAM
