9 threads found!
Rokol | 11 | 50 | ||
Rokol | 3 | 116 | ||
Rokol | 4 | 53 | ||
Rokol | 16 | 2797 | ||
Rokol | 3 | 107 | ||
Rokol | 29 | 917 | ||
Rokol | 24 | 685 | ||
Rokol | 10 | 311 | ||
Rokol | 5 | 150 |
104 comments found!
Thread: * * * Welcome to the new forums ! * * * | Forum: Vue
Can I suggest the threads are aboutย ten replies to a page max. The wishlist thread for VUE 6 has thirty replies on page one & I am finding it hard to trackback through.
The other issue would be that when being notified of a reply to a thread. When you click the e-mail link it takes you to the top of page one. Is there a way of it finding the particular reply directly? I have this feature on other forums.
Thanks.
ย
Thread: Geting realistic image | Forum: Vue
Well, you have to ask the right questions. What is bothering you with the file above? Do you not want the lens flare? Do the clouds look flat? Too much fog or haze? Just open the atmosphere tab & move the sliders, it will change the lighting setup! Give the plant some landscape to sit on, this will damp the lighting & throw some shadows up around the place. If you want a step by step tut, go to the backroom & follow something from step one to step twenty or whatever. It may take hours, even days. You will be learning all the same!
That's probably a record speed of request for help! Best bet is to load up some of the sample scenes off the disk & play around with the parameters. Just tweak something & see what happens. That way you will feel more in control of your scene. If you want to tweak the lighting settings for the above file then go into the atmosphere editor or swing the sun around a little. Good luck!
Thread: Setting Depth of Field in Vue 5 | Forum: Vue
Attached Link: http://www.dofpro.com/
There is a very good plug-in for Photoshop/Coreldraw etc. There was a link in the backroom but I think the URL has just changed. I get excellent results using a Vue generated depth map. Cuts down on extreme rendertimes!Thread: * * * Welcome to the new forums ! * * * | Forum: Vue
Attached Link: http://market.renderosity.com/mod/forumpro/showthread.php?thread_id=2640627
Totally agree with Lynne & Wabe's points! Could we have some font colour & size options please, I find it useful on other forums. Another request would be that a clickable link to another thread be put below the message rather than at the top! Can we not just have a copy/paste your link in the message itself, then I can make multiple links if required. It does show where we are headed & congrats on getting that much old data transfered over. I noticed jpeg's posted are now pretty much unreadable on threads, they display correctly if you save them to disk though. See the link above.Thread: Quickest render? | Forum: Vue
Attached Link: http://www.boxxtech.com/applications/rendering_systems.asp
svdl, have a look at these workstations! Sweet!Thread: Is there ever going to be an update released that doesn't screw some thing up?? | Forum: Vue
I've got a problem opening Poser since the original auto update. Can't open it, gives me a parse error warning. I have manually downloaded the new 509 & installed straight over the old one. Should I re-install 'Infinite' for the fifth time since owning it perhaps? Getting tiresome! Is parse error something else entirely?
Thread: making an army | Forum: Vue
OK, not warez. The owner does have the liecense agreement information with the package, it clearly states about redistribution of the software. A legal transfer via E-On admin must be obtained. Hope you get it sorted. Nice prezzie! Happy birthday!
It's pretty easy & very effective. Just animate your Poser figure as you want & save the PZ3 file. Take it over to vue & save as a VOB file. Then create an ecosystem & load the VOB file. Make sure that you click the regular alignment box to get them in formation. Also turn the rotation factor to nought so they don't swivel. Then populate. Set the animation bar to the corresponding time-frame of the original Poser animation & away you go. Hope that helps!
Thread: How Do I make a Path in an Ecosystem? | Forum: Vue
Attached Link: http://www.md-arts.com/
Go to tutorials here. Look at the top ones. Shows how to do what you are wanting I think?Thread: More on Volumetric Clouds | Forum: Vue
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=1108764&Start=19&Sectionid=6&filter_genre_id=0&Whats
Don't forget Carrara 5. One from Rids on the link.Those are damn good clouds with Mojoworld. Yeah, come on E-ON! A free upgrade would be a nice way of making the community happy again! They must have it in the pipeline. Give us a hint!
Message edited on: 12/17/2005 09:30
