14 threads found!
amacord | 5 | 712 | ||
amacord | 12 | 423 | ||
amacord | 3 | 261 | ||
amacord | 4 | 234 | ||
amacord | 23 | 668 | ||
Advisories: nudity
amacord | 10 | 399 | |
amacord | 24 | 515 | ||
amacord | 5 | 313 | ||
amacord | 5 | 270 | ||
amacord | 6 | 143 | ||
amacord | 17 | 238 | ||
amacord | 5 | 172 | ||
amacord | 5 | 180 | ||
amacord | 1 | 173 |
279 comments found!
Thread: Poser upgrade advice | Forum: Poser - OFFICIAL
Thread: Victorian Shoe Continued - WIP | Forum: Poser - OFFICIAL
hi connie, i would like to try my luck with the heels. would you kindly send me the sole as .obj? pls find my adress in your site-mail box... ;) A.
Thread: Commission work? | Forum: Poser - OFFICIAL
Thread: dear mr. kisiel... | Forum: Poser - OFFICIAL
Thread: Can someone show me how to do a transparency map...? | Forum: Poser - OFFICIAL
Quote - If you load an item , and redo the texture with a map , or redo the material zones , you can save it back to the library with a new name . Then its available in its new form without needing to redo it every time .
...which is definitely the easiest way. but isn't a new cr2 (and obj) a waste of harddrive-space? wouldn't it be better to morph the pants instead? and best to fix the geometry? especially when you want to give these pants to others (free or commercial).... ;) A.
Thread: Magnet question | Forum: Poser - OFFICIAL
would one of you guys pls open the cr2 with a text-editor and show me the actor head...only the first couple of lines (from the beginning to 'channels') and the last lines (from 'orientation' to the end)
basically import the .obj, parent it to actor head and save it to libraries/hair. of course there's no bones then, this prop will be as stiff as a gun barrel. but that's where mags show their power...;) personally i never use conforming hair. it's this "wrapped-around-the-neck" thing..... if you want to keep existing morphs it's a bit more complicated. but just a bit: - load the hair in a new scene. - make sure that all dials (morphs, trans and scale - whatever) are zeroed. - export the figure as "*.obj". include all actors. in export options check only "weld identical vertices" and "include existing groups". - then set the first morph to "1.0" - export it with the same options as before, and use the morphs name. - same for all the other morphs. - when you have all morphs, import the first obj. (the zeroed hair) - with object properties/add morph targets you can assign the exported morph.obj's as morphs. (sorry, my english isn't good enough for sentences like this...) - load your v4, parent the prop to actor head, safe it to libraries/props. - amen. what sounds sooo complicated is in fact boring but simple. less than an hour's work, i'd say. with the creators permission (i don't have this hair) i could make it for you, but it's quite unlikely that he will agree. try your luck and ask him..... A.
Thread: APPLYING MATERIALS TO ALL OF A FIGURE IN 1 CLICK??? | Forum: Poser - OFFICIAL
in addition to acadia's screenshot...after 'select all' r-click again and select 'apply to all...'. edit: crosspost....
there's an awful lot of things that can go wrong or weird with conforming hair. without knowing the cr2 and obj one would have to write a novel to exclude all possibilities. so i suggest you talk to the guy who made this hair (and if he cannot help you...start some voodoo-thing). the other suggestion...since you know how to use magnets, why don't you use this hair as a prop? i don't see a reason why it has to be conforming, it has all groups ready to move the braids seperately...
Thread: V4 too-high underarm cut -- Morph Fix -- Beta Testers Needed | Forum: Poser - OFFICIAL
i think you should continue with this work, opera... both methods have their advantages and disadvantages. and i'm sure that in this case the best results will be produced by using a combination of both. plus: how many people are ok with dialling morphs, and how many are ok with joint-editing? i'm sure you'd make a lot of people happy, especially if you'd take the trouble to do something for those legs....;) A.
Thread: Change magnets to outline with a MAT pose? | Forum: Poser - OFFICIAL
Thread: artifacts produced by narrow triangles | Forum: Poser - OFFICIAL
