301 threads found!
dlk30341 | 5 | 252 | ||
dlk30341 | 10 | 415 | ||
dlk30341 | 12 | 321 | ||
dlk30341 | 13 | 363 | ||
dlk30341 | 10 | 229 | ||
dlk30341 | 2 | 148 | ||
dlk30341 | 3 | 249 | ||
dlk30341 | 3 | 131 | ||
dlk30341 | 4 | 178 | ||
dlk30341 | 12 | 386 | ||
dlk30341 | 4 | 92 | ||
dlk30341 | 6 | 128 | ||
dlk30341 | 9 | 369 | ||
dlk30341 | 8 | 261 | ||
dlk30341 | 5 | 174 |
3,477 comments found!
Thread: Hello! | Forum: Vue
Thread: realistic moon | Forum: Vue
Attached Link: http://www.oera.net/How2/TextureMaps2.htm
You can get REAL moon mats at this link - then apply them to a sphere. Hope this helps :)Thread: Support emails from eon | Forum: Vue
Thread: Share your horror stories here | Forum: Vue
I had a render going the other night, only to wake to find materials decided to play switch-a-roo :cursing: My owl became a strawberry, with blueberry legs. A set of trees suddenly took on the mat of what, I still haven't figured out! So, I had to redo/re-import etc quite a few things. I will try re-rendering again tonight.
Thread: Backdrops in Vue 7 | Forum: Vue
For those having the issues I mentioned above a reply from EON has arrived:
Hi,
My OGL is basically non-existent, not sure what else to say here. The items show up fully burgundy shaded(I have tried checking & un-checking limit polys to no avail). In addition, when I go to use a backdrop it doesn't show until I render.
V6I has full OGL & the camera backdrop works as well, it shows as soon as I apply it.
I thought all this was fixed, this is very frustrating :(
Thanks,
Debby
Posted by: Lee Randall On: 2009/01/27 04:37:57
Hi Debby L,
Thanks for the report. This is a known problem and should be fixed by the next update.
Best regards.
Lee Randall
Thread: Eco-painting problem | Forum: Vue
I probably could have but I wanted lots of other items, therefore painting all over. In addition it was in the back on another terrain.
Hope you have fun once you get it :)
FYI new Nvidia drivers out 1/22/09
Chipp, I think the problem is that the backdrop does show up once it's rendered, it just doesn't show UNTIL you render now(after the render it gos back to blank screen). If I add a backdrop in V6I the backdrop shows w/out having it to be rendered out.
Your image shows a rendered image, not just a screen grab after applying the image.
Hope that makes sense.
Thanks will give those a whirl :) FYI - I tried using the painter both ways with the same result.
Edit - by selecting restrict to underlying object did indeed solve the problem :)
The backdrop doesn't show for me either once applied. V7I - XP x64. Nvidia 880 Ultra - drivers 181.20
Thread: Asking to keep the Miller family in your prayers. | Forum: Vue
Thread: Reselling Vue ? | Forum: Vue
I would suggest sending the offending model/models to EON. I have done this in the past with 3ds etc. They were able to nail down the problem & fix it up in a an update.
For example, when 7 & 6 came out various(not all) 3ds models were causing Vue to crash or hang up so I sent them a sampling of offending models...In the next update this was all fixed up. Typically if you get the model in when EON issues a fix you can see the irregularities in the geometry ie odd verticies/odd welding/bad uvmaps/bad normals etc etc.
IMO - send them the model/models you are having issues with.
Thread: Vue 7.5 revealed. Ouch. | Forum: Vue
