Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 6:43 am)
View Ajax's Gallery - View
Ajax's Freestuff - View
Ajax's Store -
Send Ajax a message
Ajax's Store -
Send Ajax a message
Ajax's Store -
Send Ajax a message
Ajax's Store -
Send Ajax a message
Ajax's Store -
Send Ajax a message
GWeb, actually if you take a look at the mathematical procedure behind AO, yes all corners are supposed to get it. That's how the AO algorithm works and it's also one of the reason AO is far from a perfect solution for true radiant lighting. Gareee, Not much difference in speed between the four shaders shown, no. It's just a matter of which noise pattern you like the best. Stonemason, Yep, you can make it smaller and more subtle. The size of the individual dirt grains is controlled with the scale parameters of whichever noise node you use. The density is controlled with the bias parameter on the same node. Controlling how far the dirt extends from the corners is a matter of filtering the AO output through some math nodes.
Ajax's Store -
Send Ajax a message
Ajax's Store -
Send Ajax a message
Attached Link: http://www-viz.tamu.edu/students/bmoyer/617/ambocc/
More info on Ambient Occlusion http://www-viz.tamu.edu/students/bmoyer/617/ambocc/
Ajax's Store -
Send Ajax a message
get that bump out of the gradient slot!!..lol :) it's a nice effect with the shader,it looks a bit grainy,& obviously made up of dots..is there any way to clean that up?
Attached Link: http://www.metafex.net/cinefex/tutorials/dn/
It's meant to be grainy and made up of dots. It pretty much matches the appearance I was trying for, rather like the grainy dirt you see in the bottom right couple of pictures on the linked page. Those were done with the old C4D DirtyNuts shader. What sort of look did you have in mind? If you've got a pic, I'll see if I can come up with something similar.
Ajax's Store -
Send Ajax a message
I'm not sure what I'm looking for,just less apparent dots I guess,can you control the amount of dots?..make it alot more dense but keep the opacity http://www.maxon.net/pages/products/c4d/r85/images/dirt_nodirt.jpg
Looks doable. Just a matter of spending lots of time tweaking I think. Let me see what I can do.
Ajax's Store -
Send Ajax a message
Ajax's Store -
Send Ajax a message
GWeb, I realise the title of this thread, containing the rather subtle words "dirt shaders", might not have given it away to you, but the whole point of what I'm doing here is to use AO as a means of filling corners with dirt. I had hoped that the very first sentence in this thread ("...it's possible to create shaders that automatically fill nooks and crannies with dirt") might have hinted that, but apparently I was being too obscure. "AO is not supposed to look dusty" Surprisingly enough, DIRT IS SUPPOSED TO LOOK DUSTY! Perhaps I'm still being too subtle, so I'll quote your own words from post 6 back at you: "Very Nasty Very Bad bad BAD!!" If you aren't interested in shaders that look dirty and/or dusty, please do us both a favour and go and find a thread that isn't about dirt shaders.
Ajax's Store -
Send Ajax a message
Ajax's Store -
Send Ajax a message
Hehe, now the entire of Poserdom can use the old Ambient occlusion for "dirty shaders" trick Renderman users have had for some time. Good to see we're spreading the love grin I personally like the top left, the top-right is nice for say a "tarnished" look, but the top-left really does the "dirt thing" for me,
Ajax, This is outstanding. I agree with Eternl Knight on the dirt effect preferences. I have a couple of questions:- a) Would this work for bump and displacement mapped detail? b) Although not strictly 'dirt', but coming under the heading of 'weathering' would it be possible to use the settings on the ball at top left with a rusty colour, and the settings on the ball at top right as is, at the same time, to create a rusting dirty ball? Cheers Ian
Yeah, it's something I've wanted to see in the material room for a long time :-) I like the top left too, but I think I like the bottom right just a little better. I actually only put the top right one in as a control. There's almost no dirt in it at all.
Ajax's Store -
Send Ajax a message
Ian, Yep, sure will work for bump and displacement :-) Basically it drives a blender, so you just blend your dirt bump against your clean surface bump. Layering dirt AND rust will make the shader more complex with a bunch more nodes so it will be more difficult to manipulate in the material room and will render slower, but it's certainly doable. In the longer term I'd like to put together some more complex shaders like that. I'm really just playing with my new toy at the moment.
Ajax's Store -
Send Ajax a message
Ajax's Store -
Send Ajax a message
Can this be used to make a brisk texture look dirty? (Each individual brick, as opposed to only the corners of the mesh) Also please post a screen cap of the settings you used for the balls. Excellent use of the node by the way. Creative use like this could eliminate the use of textures for much of the structures within a scene.
Something that would be really cool in poser, would be adding the ability to "bake" these on textures, and then save those textures. It's using in lightwave all the time to create actual texture maps. Since the P6 material room is really blossoming, that would be a way to "share" the new tech with the older poser version users. Not that I think it'll happen...
Garee: "Hmm I just had a thought... if you applied negative math nodes, couldn't this be converted to some kinda of highlight lighter spots type of shader setting?" Perhaps to simulate the shiny spots on larger bronze statues, where they've been rubbed by the hands of thousands of visiting tourists...?
Ajax's Store -
Send Ajax a message
