Carrara F.A.Q (Last Updated: 2024 Sep 07 1:44 am)
Attached Link: http://www.subdivisionmodeling.com/page1.htm
Take a look at this: http://www.subdivisionmodeling.com/page1.htm It is a very well laid out intro on sub-d modeling. Hypernurbs is C4D's flavor of sub-d. Carrara has Sub-Division Surfaces in both the standard and pro versions.(I do not have the standard version) You can make loop selections in standard but I do not think you can cut in new loops with it. There are other ways to do the same thing - it will just not be a single click operation. wayne k guam usaTruth has no value without backing by unfounded belief.
Renderosity
Gallery
I've been to subdivision modelling, but it never uses Carrara terminology, so, none of it really made any sense to me... :)
Renderosity
Gallery
You can also use deformers in the Vertex Room which might be useful for roughing out the shape you have in B. Select the vertices you want to deform then go to Model>Deform and select the modifier you want to use. For the benefit of others, you can cut an edge loop in C5 Pro by selecting a loop of edges and then using Model>Extract Along.
Ok, but you are cutting yourself short. If you do not have a good grounding in the basics every time you run into an unknown situation or an error you will end up being frustrated, not knowing why something is not working the way you think it should I know that... which is why it is further frustrating. The 'basics' of that tutorial at subdivision modeling, which I read through in full about a month ago, is nearly 80-100% concepts that do not exist in Carrara. All it did was start me on the path I've been on these past few days, wondering just how these things could be done when I couldn't find any of the things they covered over there at subdivision. Finding the tutorial at Daz was merely the 'last note' in a longer process... when I saw a tutorial that in essense employed the concepts I read at subdivision... and that brought me back to wanting to again know where they were in Carrara. I'm not sure I'm selling myself short by finding subdivision an ill fit for a Carrara user. It seems more like all it can do for a new user is confuse and misdirect them - getting me to think in the wrong paradigm. Half the replies to my present frustration have been 'you're doing this wrong thing for this app, correct your thinking' - which of course, is what I want to do... and if I follow subdivision's method that just won't be possible. But no other path was presented... (noting that I haven't yet read the rest of your message).
Renderosity
Gallery
arcady, You can probably do this in carrara, but not very efficiently. Carrara really isn't a modeller nor is it promoted as such. Pro is much better, but still going to frustrate someone new.It has modelling tools which is more than most of these renderers can say, especially at this price. Particularly for sub-d. I wouldn't drive myself nutty over it. Go try hex or silo. These will work well w/ carrara. See which one you like more. Hex is more powerful, but silo has displacement which hex won't have till later. Hex should have a carrara bridge coming too which will make it even better for carrara. It already exports car files and works well in other ways.If you want to model don't drive yourself batty spend a few bucks extra and get a good modeller you like.You might want to even try truespace 5 which can be had pretty cheaply.I don't like the old interface (newest one seems much better), but for modelling it might not be bad. Lotta people like it's modelling tools.
No need to think outside the box....
Just make it
invisible.
Arcady, It is hard for me to tell what you want. You asked how - I said get some background basics. You said - been there, done that - didn't get it. I said - too bad, here is the "how to" info. you asked for. You have replied to the "too bad" part. I figured that you would have replied to the "how to" part if that is what you really wanted to know. "The 'basics' of that tutorial at subdivision modeling, which I read through in full about a month ago, is nearly 80-100% concepts that do not exist in Carrara." If we are talking about the same primer over on subdivisionmodeling, just about all the concepts presented do apply to Carrara. The Standard version of Carrara is missing some of the specific edge tools listed, but that does not mean you can't do what you want to do. Is Carrara Standard the best tool for your modeling needs? Maybe not, but it is not useless. You can learn the basics of polygonal modeling with it. I do not use the vm for modeling but there are users in the Carrara community that have made models that will stand up to anything made in other dedicated modeling applications, using earlier versions of Carrara (c4-c3) that had far fewer tools than Carrara 5 standard has today. I am not going to suggest doing it in something else or upgrading to C5Pro that does not look like what you want to hear. good luck with your 3d quest wayne k guam usa
With every passing day, and with every tute, my admiration for the brilliance of Carrara (5Pro especially), and Hexagon, grows and grows. Everyone should look at those two Carrara made film shorts by Astro Films to know that the only problem with Carrara is with the thinking power of the user not the App!
bwtr
Trav,
Is that c5pro or standard.Part of the issue is I think alot of people have pro. Arcady is using standard.So people reply w/ what they know.I don't think carrara isn't capable tho of modeling. It is. I have seen some great stuff done w/ the old tools, but I found it frustrating. The new vm is actually intuitive. The thing is you have to decide you want to go the distance or look at other options.As happy as I was w/ the new VM I decided to try hex and said wow this is much easier.You do have to try not to get too emotional tho(it's easy when your frustrated) and wait abit for some help before jumping to conclusions.Look at Maya(tons of power)...lots of people can hardly do a thing w/ it.I think carrara is such an easy app including the new VM, but I don't choose to really model from scratch in it.That's me, if it's w/in my means to do something a better/more efficient way (my def)then I am gonna do that. BTW Dynamic geometry is awesome!
Message edited on: 02/22/2006 20:35
Just make it
invisible.
NO problem shere ren mem, I wasn;t intending to single you out. I've seen the same thing said across the boards, not even so much here. I have Hex too and am just the opposite of you, feeling much more compfortable with Carrara's tools. Hex is a bit.. quirky for me. Haven't really looked a the differences between standard an Pro. I know that I could have done the same model (and have done similar) in C4 just a matter of a single slider in the Sud-d menu and a bit different wokr wiht the scale tool. SO I THINK the process should still work. I'll pop over the Eovia and see what tools she might not have. mike
It's ok trav, I didn't feel that way, just wanted to clarify I didn't think it was an all or nothing situation. Having the modeling tools in c5 IS an advantage. That is a down side. Another interface and another program w/ import/export.Getting a hex bridge will help alot. I hardly touched carrara before this version so I wasn't really accustomed to things. Had I been using it I might very well find carrara more comfortable.I just felt like sometimes I had to do more steps in carrara than hex. If I really wanted to model in carrara I would recommend pro over standard that's all. I do love the dynamic geometry tho. Did I say that enough;)
Just make it
invisible.
Nice bwtr. I am finding I would like more of these kinda tuts in hex. The skirt was easy to modify to fit the form, but I am finding the top much trickier for women. Lot of angles and curves. Tips on different ways to approach different types of clothing would be nice. However, it is alot of fun to just play. I particularly find the holes for sleeves tricky.
Message edited on: 02/25/2006 15:42
Just make it
invisible.
Attached Link: http://forum.daz3d.com/viewtopic.php?t=22916
In the link I've posted here, the author keeps referring to making cuts and loops, and especially, the 'loop cut' done to the cube.Also, the reference to 'dropped the mesh into a hypernurbs' in post 3.
In Carrara (5 regular?) terminology, what is going on here?
Do we have all the tools needed to duplicate this process (or some way of our own)?
Message edited on: 02/20/2006 21:44
Renderosity Gallery
