Sun, Oct 6, 5:47 PM CDT
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 06 11:30 am)
Subject: Conforming shoes - how???
  • 1
  • 2
ahudson ( ) posted Tue, 09 December 2008 at 10:55 AM · edited Sun, 06 October 2024 at 5:47 PM
Hello,
I want to model some conforming shoes for V4. I want to make them as conforming shoes rather as props since I want to be able to make them into boots or have ankle straps.
I am having real problems rigging them and I wondered if anyone knows what I am doing wrong.
Here is what I did:
  1. I made a "shoe" consting of a cube, scaled and rotated to fit V4's zeroed right foot. See: 1. "Shoe" modelled in Silo
  2. I named the object rFoot and saved it as .obj format
  3. I started Poser and imported the "shoe". See: 2. Loaded into Poser
  4. I entered the setup room with the "shoe" selected
  5. I loaded V4 to donate her skeleton (I know that usually you would delete unneeded bones but I didn't this time). See: 3. V4 Bones donated
  6. I opened the grouping tool and deleted all groups except for rFoot then added all polys to rFoot. See: 4 All polys added to rFoot group
  7. I opened the joint editor, clicked rFoot bone, selected "Bend" in the menu and made the spherical fallof zones both bigger to encompass the whole of the "shoe"
  8. I exited the Setup Room. The shape and angle of the "shoe" changed slightly. The angle was more like V4's default foot angle and the shape of the "shoe" was no longer cuboid, it is twisted and tapered very slightly. (No pic, sorry)
  9. I saved the "shoe" as a Character See: 5 saved as TestShoe
  10. I closed the scene and made a new one
  11. I loaded V4 and used Joint editor "Zero Figure" button to zero her
  12. I lLoaded the TestShoe from the library. See: V4 loaded and then "TestShoe" loaded (not conformed yet)
  13. Finally, I conformed the shoe to V4. See: 7. Conformed to V4
As you can see, the shoe is nowhere like correct. It does follow the foot as it is bent but it deforms slightly even though I made very sure to enclose it completely inside the inner spepical fall-off zone.
I am really stuck. How do I get this "shoe" to conform properly and stay in the same place as I modelled it?
I hope you can see the pictures. When I preview, before posting, I appear to be able to click the picture to view it full size, i hope this works when I post it.
Adrian
ahudson ( ) posted Wed, 10 December 2008 at 7:22 AM
Anyone? Please??
chriscox ( ) posted Wed, 10 December 2008 at 8:21 AM
Is the shoe Zeroed out?
It looks like it might be bend a bit like V4's foot is by default
Chris Cox
ahudson ( ) posted Wed, 10 December 2008 at 9:03 AM
Hmmm... you mean after I leave the material room I should zero it or perhaps after conforming... Thanks, I will try that Chris.
lululee ( ) posted Wed, 10 December 2008 at 9:40 AM
Bookmark
ahudson ( ) posted Wed, 10 December 2008 at 9:50 AM
Hello Lululee,
I don't understand "Bookmark"
Adrian
lululee ( ) posted Wed, 10 December 2008 at 10:29 AM
Hi ahudson,
Bookmark means I too am interested in this thread. When I bookmark it i get an automatic email telling me someone has added a new post to this thread.
   I am very interested in learning how to make and conform shoes for V4 so i am hoping you get some good info and will continue to post your results.
cheerio  lululee
ahudson ( ) posted Wed, 10 December 2008 at 10:35 AM
I will make sure to forward any info I find through other sources to you by Rendo mail :-)
TheOwl ( ) posted Wed, 10 December 2008 at 10:57 AM
try adding a "toe" group plus make sure you zero the joints in the joint editor
Passion is anger and love combined. So if it looks angry, give it some love!
lululee ( ) posted Wed, 10 December 2008 at 11:02 AM
Thanks ahudson. Much appreciated.
cheerio  lululee
Letterworks ( ) posted Wed, 10 December 2008 at 11:28 AM
ahudson,
Without looking at the CR2 generated when you save yoour test shoe I can't be sure but I think I have an idea as to what;s going on.
First when you bring the test object into poser you are adding the skeleton via the setup room. Peronally I don;t recommend this... you'd be a lot beter off bbuying one of the commercial programs like Dimension3D's tools or WardrobeWizard and learning how to transfer the skeleton with those. For one thing most of those programs will eleminate a lot of unneccesary information from your final CR2 files.
That aside what may be happening is that when you bring in V4's bones to use as donor they are in a POSED position while your object is in the zero position.  Check this by loading the figure you are using as a donor (without th shoe object in the pose room) and note if it loads with the feet flat vs the floor or in the toe down zero position. If the feet are in the flat position that may be your problem. Try zeroing out the V4 figure and resaving it then using the zeroed figure as your donor.
Give this a try and see what happens. If it doesn;t work I'll see what else I can come up with.
bopperthijs ( ) posted Wed, 10 December 2008 at 11:44 AM
*5. I loaded V4 to donate her skeleton (I know that usually you would delete unneeded bones but I didn't this time). See: 3. V4 Bones donated
*Two comments: instead of using the original V4, you better use V4 Dev Foundation. Which is supplied with the V4 developer kit, which is in the V4 morphs++ package.
Second: After leaving the setup room, you must first memorize the figure.
If that still doesn't work, tweaking with the joint editor can solve a lot of problems, just don't forget that when you have the right position, you must memorize the figure.
My two cents.
Bopper.
lululee ( ) posted Wed, 10 December 2008 at 12:49 PM
bopperthijs,
Why is it important to "memorize the figure."?
What is the purpose of memorizing it?
cheerio  lululee
bopperthijs ( ) posted Wed, 10 December 2008 at 1:21 PM · edited Wed, 10 December 2008 at 1:22 PM
*What is the purpose of memorizing it?
*It's important when you save a figure (model, clothing, shoes) that is not zeroed, For instance V4 isn't saved as a zeroed model, that's why you get those strange rotations in shoes and clothes when you use the original V4 model as Bone-source for your outfits. The V4-Dev-Foundation is completely zeroed and has no Ik-chains, so that's why it's so suitable as a bone-source for new figure.
You can make your own "blank" CR2 by first deleting the IK-chains in the Hierarchy editor  of a normal V4 and than zeroïng it, then memorise it and save it as a separate "blank" V4-cr2. This can also be used a good bone-source.
I can explain more about the use of the joint editor and memorising, but I first have to have dinner, otherwise I'm in trouble.
Best regards,
Bopper.
lululee ( ) posted Wed, 10 December 2008 at 1:35 PM
Thanks so much Bopper. You are a gem. The haze is starting to lift from some of the problems i experienced in the past. Really valuable info you are sharing.
cheerio  lululee
ahudson ( ) posted Wed, 10 December 2008 at 2:22 PM
Letterworks & **bopperthijs,
Thank you both for your replies!** **in effect you are pointing me in the same sort of direction, namely that the V4 rigging is not zeroed as it is saved by default.
Lululee, you asked exactly the question I would have but you beat me to it. Memorize is one function of Poser I have never used (never needed to really since I have not done anything like rigging etc before).
I think I am closer than I have ever been to getting this to work. V4's feet and rigging shoes have always been such a difficult thing and I think it has always been down to this thing of the default V4 not being zeroed.
I'm off to try the dev kit model. I always wondered what tha was all about!
lululee ( ) posted Wed, 10 December 2008 at 2:53 PM
Looking forward to seeing your results, ahudson.
cheerio  lululee
ahudson ( ) posted Wed, 10 December 2008 at 4:40 PM
Well, I am slowly getting somewhere.
Using the Devkit V4 is a bit tricky since she has no visible feet (I just had a thought as I typed this that maybe they were there but invisible but nver mind).
This is what i just did:
  • Loaded V4 (normal V4, not the dev kit - see above)
  • Zeroed her and memorized figure settings and saved into the library as "V4 zeroed"
  • Saved her shin and foot and toe as an Obj
  • Imported into silo
  • Made another box "shoe" to just cover the foot part
  • Saved just the box shoe as an obj
  • Started Poser and loaded the "V4 zeroed"
  • Loaded the box "shoe" to check it was in exactly the correct place (it was)
  • Deleted V4 leaving only the box "shoe"
  • Went into the Setup room
  • Loaded the V4 devlopment kit to donate bones  *** (see later)
  • Added the polys to rFoot
  • Made the inner sperical falloff zone cover all of the box shoe
  • Made the outer sperical fallof zone cover all of the inner zone
  • Exited the Setup room
  • Memorized the Figure settings
  • Saved the shoe to the library
  • Made a new scene
  • Loaded V4
  • Loaded the "shoe"
  • Conformed the shoe to V4
  • Yaaay! It worked!!!!!!!!!!!!!!!
But.
When I flex V4 right foot, the box "shoe" still slightly squishes or stretches (just like my last image #8 above).
I started again, loaded a purchased V4 shoe and moved bent her fooot quite a lot... no deformation of the shoe.
(*** I should mention that at the marked point I tried several times to donate the V4 zeroed that I made but this did not work. At the end, when conforming the finished shoe it would conform in the wrong place (slightly off her foot). I did some tests and I determined that if you load V4, zero her and load her back in and check all her joints they are not quite zero - 0.000123 and similar. This does not happen with the dev kit V4.)
Soooo... if anyone is still following along...
I am nearly there. Better than EVER before (and I have been trying this for months - off and on) but I just need to understand how to stop poser deforming something rigid like a fashion shoe.
Any ideas on this last hurdle please anyone???
I would be,
"Eternally Grateful of the UK"
if anyone could help me for this last bit
lululee ( ) posted Wed, 10 December 2008 at 5:10 PM
Attached Link: PhilC's tutorial on joint parameters for shoes
ahudson,   Have your looked at PhilC's tutorial on joint parameters for shoes? Also Phil has 2 product for making shoes. Shoe designer and shoe converter. You might look at the documentation for those products and find the missing piece. Heep us posted. You are doing great. cheerio  lululee http://www.philc.net/ShoeConverter_page1.htm
ahudson ( ) posted Wed, 10 December 2008 at 5:30 PM
Ahh, yes, seen those but not taken a lot of notice... Hmmm.. "Joint parameters"
Thanks lululee :-)
bopperthijs ( ) posted Wed, 10 December 2008 at 5:31 PM
I'll see if I can give tomorrow some screenshots of a pair of shoes for a project I'm working on, I had a lot of trouble with these adjusting the joint parameters, but I think I finally know how to make it work.
regards,
Bopper.
bagginsbill ( ) posted Wed, 10 December 2008 at 6:05 PM · edited Wed, 10 December 2008 at 6:05 PM
> Quote - Hello Lululee, > > I don't understand "Bookmark" > > Adrian
I don't understand it either, but for a completely different reason.
See that link called "Subscribe" ? Click it. We don't need to clutter threads with bookmark anymore. ;)
lululee ( ) posted Wed, 10 December 2008 at 6:22 PM
Duh! Thanks Baggensbill. I must be living in the dark ages. i don't even want to know how long that has been going on and I've missed it.
cheerio  lululee
lululee ( ) posted Wed, 10 December 2008 at 6:41 PM
Attached Link: Figure Setup Tools
Has anyone tried the "Figure Setup Tools" from Daz. I bought it but have not had time to try it. The thread says it is very good for creating the JCM's. Iwonder if that will work with shoes? cheerio  lululee
Letterworks ( ) posted Wed, 10 December 2008 at 7:32 PM
ahudson
if the "shoe" is deforming squishing or stretching) but still following the foot then you need to make the spherical fall off zone even larger. The fall off zones are a bit tricky since the often ned to be slightly larger than it would seeM. Remember also, the inner falloff zone is the area of total movement while out side of the outter zone is zero movement everything between the inner and outer zone moves but at a ratre that falls off progressively from innr to outer.  So if you make the inner zone larger it's often a good idea to make the outer zone larger too even if it;s only very slightly larger than the inner zone.
The DAZ development tool that work with DAZ studio show this in a more graphical way having ALL of the polygons that recieve 100% movement colored in one color while all that are 0% movement are another color and the fall off zone blends the colors in a way that graphically shows the influence. I really hope poser 8 steals this idea or someone comes up with a stand-alone app that uses it for Joint parameters adjustment, mainly because I don;t know DAZ Studio and really hate the idea of learning a complex program just for those functions.
ahudson ( ) posted Thu, 11 December 2008 at 8:22 AM
Letterworks,
Yes, thanks for that. I had actually made the fall off zones encompass the whole shoe and the outer one bigger than the inner. I thought that would be all I needed but it is not. I don't really fully understand the relationship between "falloff zones" and "joint angles" but I needed to also adjust the joint angles to exclude the shoe as well.
Lululee,
!!!! Thank you !!!!
Whilst I had seen PhilC's shoe converter and the tut you pointed out I had ignored the info, thinking that it was not relevent. You pointing me at that tut ticked the final box and it has all fallen into place.
So. a recap of what I have found
  1. Using the default V4 for bone donation is right out! She is not zeroed and it just messes things up terribly.
  2. Loading V4, zeroing her, turing off IK and saving her into the library to use as a bone donor is better but still not perfect. Loading her back in and checking bone angles in detail  reveals that she isn't actually zeroed. For example her foot angle comes back as 0.002955. Now, that is very small but it seems to all add up and slightly mess up the whole process.
  3. V4 development foundation doesn't have foot (or hand or head) polys so using that to export and use as a tailor's dummy to model shoes etc does not work. However, a zeroed model of V4 exported as OBJ is fine.
  4. After the new content is made, import it into Poser and use the V4 dev foundation as a bone donor
  5. Shoes (especially ones with straps or tall boots will need careful adjustment of both sperical fallof zones AND joint angles in order to exclude the shoe from being deformed.
Okay. That's it for now as far as I have got. This was fine for zeroed shoes. Next stop, high shoes or flat shoes and how to conform those.
ahudson ( ) posted Thu, 11 December 2008 at 8:26 AM
I meant also to post this image
lululee ( ) posted Thu, 11 December 2008 at 10:01 AM
Good going ahudson. I am really pleased with how far you have come. Quite inspiring.
cheerio  lululee
bevans84 ( ) posted Thu, 11 December 2008 at 10:17 AM
Here's a pair of Wellington boots I made for V4 a while back. They're a little rough, since they weren't for a close up or anything. I made them conforming with AutogroupEditor and Quick Conform because I thought about putting them in freestuff, but never got around to texturing or finish tweaking them. As is, they just use the standard Poser leather shader.
Looking at them again, I believe a real person would have a hard time getting their foot in or out of them. :)
There are a lot of helper applications out there to make the job easier.
ahudson ( ) posted Thu, 11 December 2008 at 10:24 AM
**Hello bevans84,
Nice wellies**.
Can you describe how you made the mannequin that you built these on top of please? Assuming you exported an obj of V4's leg/foot/toe did you zero them before you output them or did you pose her foot a little first? Can you describe how you rigged them please too? What is Quick Conform?
Thanks!
bevans84 ( ) posted Thu, 11 December 2008 at 10:49 AM
For the mannequin, I just zeroed V4 in Poser and exported the right and left shin, foot, and toes as obj. files.
I box modeled the boots around the legs using Hex.
Autogroupeditor and quick conform are both by MarkDC. Many people seem to have trouble with his stuff, but I've been using it a long time. I'm sure there are other applications that people can suggest that are maybe a bit more user friendly.
ahudson ( ) posted Thu, 11 December 2008 at 11:16 AM
Ahh, Zeroed. Yes. Thanks.
The difficult bit seems to be making flat or high shoes. Then, the mannequin needs to be non-zeroed and things get much more difficult very quickly!
nyguy ( ) posted Thu, 11 December 2008 at 11:18 AM
Quote - For the mannequin, I just zeroed V4 in Poser and exported the right and left shin, foot, and toes as obj. files.
I also use quick conform for most of my clothing that I don't use PhilC's Obj2Cr2. I also use Pegasus Modeler by MarkDC. These are great tools to have for modeling and creating clothing
Poserverse The New Home for NYGUY's Freebies
bopperthijs ( ) posted Thu, 11 December 2008 at 3:59 PM · edited Thu, 11 December 2008 at 4:00 PM
*For the mannequin, I just zeroed V4 in Poser and exported the right and left shin, foot, and toes as obj. files.
*Don't forget to switch of IK,  I noticed that a zeroed model with IK looks different than one without.
Like bevans84 I also use Hexagon, autogroup editor and quick conform to make my clothes  (and other stuff) Pegasus is also a good modeller, but it hasn't the displacement and paint brushes Hexagon has.
I promised to show some screenshots of the shoes I'm making, I almost completely used the same methods as bevans84, make a pose for V4 and saved the toes,the feet and the shins and saved it as an obj-file I used that as a mold in Hexagon.
Bopper.
bopperthijs ( ) posted Thu, 11 December 2008 at 4:02 PM
Here are the shoes I made; they are part of a vintage-lingerie set I'm working on for months now.
Bopper.
ahudson ( ) posted Thu, 11 December 2008 at 4:06 PM
Nice shoes! It looks like they were made with V4 foot zeroed. Yes? How ever would one go about making a flat shoe or one higher than this?
If you posed V4's foot flatter or higher before exporting the mold, how on earth would you then do the rigging? It only seems to work properly if the mold is completely zeroed?
Adrian
bopperthijs ( ) posted Thu, 11 December 2008 at 4:15 PM · edited Thu, 11 December 2008 at 4:17 PM
As said I usually use autogroup editor and quickconform for the figure setup, but for these screenshots I didn't use quickconform, but did it the old-fashioned way and used the setuproom. The advantage of quickconform is, that it automatic deletes the unused bones so you don't have to go through the tedious process of deleting all the unwanted bones, but you can also add bones that are not in the model.
This is what I did: I imported the obj-files of the shoes (with the groups already in it) and entered the setup room. Important is not to move the model and uncheck everything when you import it. In the setup I insert the V4-dev-foundation, and I quit the setuproom, You can rename your model in the body-properties (it's now called V4-dev-foundation)
I memorised the figure (at this moment not really important, but it's a routine for me) and saved it in a directory of the figure library. I started a new document and loaded V4, and gave her the original pose. Uncheck all IK's, it's great for posing, but it causes only troubles for this process
Then I loaded the shoes and conformed them to V4.
Bopper.
edited after reading the previous post: V4-feet are not zeroed, this is a method for using posed feet as a mold to make highheel shoes.
bopperthijs ( ) posted Thu, 11 December 2008 at 4:18 PM · edited Thu, 11 December 2008 at 4:18 PM
Here are shoes after conforming not very nice, huh?
B.
bopperthijs ( ) posted Thu, 11 December 2008 at 4:20 PM
The solution is in the joint editor:  The best way to do this to make a four window pane, so you can see the shoes from all directions.
bopperthijs ( ) posted Thu, 11 December 2008 at 4:22 PM
Then start-up the joint editor and select the right foot of the shoes.
bopperthijs ( ) posted Thu, 11 December 2008 at 4:29 PM
Then select the center point of the shoe foot  (the green cross) and move it just as long the heel of the shoe is in the right position, then do the same for the toe and move untill the shoe look right, I had to move the center of foot also a bit and sometimes you have to re-adjust the drop-off zones. But tweak with all the centers untill the shoe looks right.
B.
bopperthijs ( ) posted Thu, 11 December 2008 at 4:36 PM
When the shoe looks right, you don't have to do the left shoe but, you just can use symetrie, but don't forget to copy the joint zones as well, which you don't do with normal poses.
Voila: a matching pair!
bopperthijs ( ) posted Thu, 11 December 2008 at 4:43 PM · edited Thu, 11 December 2008 at 4:43 PM
Now comes the final and important step memorise the figure and save the shoes (as an individual figure, not a composed) If you don't memorise all your tweaking and moving centers will be for nothing. When you now load the shoes and conform them to V4 they will fit perfect (well almost, sometimes you have to do some more tweaking, it took me two week before I was satisfied, and I still see mistakes)
B.
ahudson ( ) posted Thu, 11 December 2008 at 4:44 PM
Bopper, you are a star. Thank you for your tutorial here.
Basically, what you are saying here is that there is no automatic or even semi-automatic way to set up conforming shoes if the mold or mannequin is not completely zeroed. In the earlier posts in this thread, I found that it is possible to do this semi-automatically IF the mold iscompletely zeroed. then it is just a matter of loading in the finished shoe, going into the setup room, loading the v4 dev kit rig, deleting the extra bones, setting fallof and joint angles and it is done.
If you model with a mold not zeroed then you have to fit the shoes manually in the way you have described above i.e. intricately and carefully, pretty much "by eye".
bopperthijs ( ) posted Thu, 11 December 2008 at 4:46 PM
Here is a secret preview of my set with the shoes, I hope I will finish it someday, the biggest problem is in the morphing, I still have peek-troughs everywhere and wrinkles where I don't like them. but I won't give up.
Best regards and happy modeling and posing.
Bopper.
ahudson ( ) posted Thu, 11 December 2008 at 4:55 PM
Goodness! Wonderful!!!
lululee ( ) posted Fri, 12 December 2008 at 10:53 AM
Outstanding info from everyone.
Splendid lingere.
cheerio  lululee
patorak ( ) posted Sat, 13 December 2008 at 8:04 PM
Hey Bopper!
Great job!  That is an awesome model!
LLSmoothJ ( ) posted Wed, 28 June 2023 at 1:00 AM
Bumping this (Yeah, I know it's been awhile)
Here's how I went to conforming the shoe.
-Imported the obj file as a prop then made sure that it fit the shoe after magnetizing to the designated leg.
-Eexported the obj file after zeroing the figure and bending the foot/toe so that it fits within the shoe (noting the respective bends)
-Changed the internal name of the object to lFoot.
-Imported the file again (this time not centering it), then going into the setup menu.
-Loaded the V4 Development Figure, unchecking auto group, then unchecking the part except from the Left toe to the hip.
-Bent the foot/toe bones:
-After leaving setup room, made sure to memorize the figure.
When conforming, here's the result:
Any idea where I'm going wrong?  It seems to be tilted to the side when it shouldn't be.
RedPhantom ( ) posted Wed, 28 June 2023 at 7:05 AM
Site Admin
My setup room experience is minimal so I can't be of much help. I'm more apt to use the fitting room. If I were to see that there, I'd double-check to see if the shoe fit the figure's foot in the zero-posed position before going into the setup room.
LLSmoothJ ( ) posted Wed, 28 June 2023 at 7:27 AM
When I zero the figure, it didn't fit the shoe until I put in the bend/twist values for the foot/toe.  I try to do the same in the setup room.  I usually magnetize the shoe object to the feet and the conforming turns out fine.  What I'm trying to do is to prepare conforming boots in which I will have to take in account of the shin positioning (Unless I start having the boots created based on the legs in the zero pose position).
  • 1
  • 2
