Fri, Jan 17, 11:33 PM CST
Forum Moderators: Staff
Subject: Using 3D nodes (Cellular) with 2D UV maps ?
3dcheapskate ( ) posted Sun, 14 July 2024 at 9:15 AM · edited Fri, 17 January 2025 at 10:42 PM
Online Now!
I know there was something about this somewhere... But I can find hide nor hair of it.
I'm using the 2D tile node at present but I need more flexibility than the two colour chessboard tiling that provides - the Cellular node would be perfect if I could remember how to use it.
I vaguely recall that you make one of the 3D axes use a fixed value by plugging a Math_function into one of the inputs (Scalez for a Cellular node?) and plug u_Texture_Coordinate and v_Texture_Cordinate nodes into the other two.
But that doesn't work, so I'm obviously misremembering something.
Any ideas ?
The 3Dcheapskate* occasionally posts sensible stuff. Usually by accident.
And it usually uses Poser 11, with units set to inches. Except when it's using Poser 6 or PP2014, or when its units are set to PNU.
*also available in ShareCG, DAZ, and HiveWire3D flavours (the DeviantArt and CGBytes flavour have been discontinued).
3dcheapskate ( ) posted Sun, 14 July 2024 at 10:11 AM · edited Sun, 14 July 2024 at 10:12 AM
Online Now!
I've found one of the bits I was thinking of - from bagginsbill's post on my 'PP2014 Image Map Node: V_Offset = (V mod 0.03125) - V ...unexpected result' topic onwards
(I need to get a good night's sleep, my brain's leaking again ;o) )
3dcheapskate ( ) posted Mon, 15 July 2024 at 10:37 AM · edited Mon, 15 July 2024 at 10:37 AM
Online Now!
Hmmmm... the fBm node is the only node that seems to work for me.
Here's a screenshot of a simple shader (based on the screenshot in this post from that 'PP2014 Image Map Node...' topic mentioned above, but modified to create an 8x8 grid) with a  FireFly render. The second (unconnected) fBm node is a duplicate of the connected one and has all the same values:
If I leave the material room, change the renderer to SuperFly, and go back to the material room (exit/re-enter required to update the mat room preview) the preview of the connected fBm node looks unpromising, but when I render it seems to work okay:LnuL0PCvtnaUibvBi7TMxh68mXlefLDKTiEcrTuU.JPG
(I'll do the same with the other nodes tomorrow)
3dcheapskate ( ) posted Mon, 15 July 2024 at 10:43 AM · edited Mon, 15 July 2024 at 10:43 AM
Online Now!
Plugging the fBm into a ColorRamp to convert the greys to colours, and then plugging theat into a 2D Tile node to get the grout/mortar between the pool tiles (that seemed the simplest way)...
FireFly:
SuperFly:
Yes, I'm trying to do that random blue swimming pool tiling.
3dcheapskate ( ) posted Tue, 16 July 2024 at 4:20 AM
Online Now!
Okay, after a good night's sleep I'm now wide awake... comparatively.
Just confirmed that using the Noise or Fractal Sum nodes instead of the fBm node also works, in both FireFly and SuperFly renders. It's just the node preview in SupeFly that looks wonky. Here's some screenshots showing the node preview and render together. The cropped nodes to the right are the same as before, just to create that 8x8 grid.
Noise node with default settings, FireFly render:
Noise node with default settings, SuperFly render:
3dcheapskate ( ) posted Tue, 16 July 2024 at 4:22 AM · edited Tue, 16 July 2024 at 4:22 AM
Online Now!
Fractal Sum node with default settings, FireFly render:
Fractal Sum node with default settings, SuperFly render:
3dcheapskate ( ) posted Tue, 16 July 2024 at 4:40 AM · edited Tue, 16 July 2024 at 4:40 AM
Online Now!
But the Turbulence and Cellular nodes don't seem to work here.
So in summary:
I've given the Noise node a double tick because it's easier to get a good dynamic range (near black to near white) than with fBm and Fractal Sum which always seem to give me justa small dynamic range of greys.
(the other 3D nodes don't have x/y/z scale inputs and thus aren't relevant here)
3dcheapskate ( ) posted Tue, 16 July 2024 at 5:15 AM · edited Tue, 16 July 2024 at 5:16 AM
Online Now!
Adding the ColorRamp and Tile nodes as before, but also increasing the grid to 20x20...
FireFly:
SuperFly:
Looking good !
Almost there...
3dcheapskate ( ) posted Tue, 16 July 2024 at 5:20 AM · edited Tue, 16 July 2024 at 5:22 AM
Online Now!
...and the final step, apply that to the toon pool I'm working on..
FireFly looks great, but uh-oh, what's up in SuperFly ? The sides of the pool show very little variation.
FireFly:
SuperFly:
3dcheapskate ( ) posted Tue, 16 July 2024 at 7:05 AM · edited Tue, 16 July 2024 at 7:06 AM
Online Now!
"Oh my giddy aunt" and other expletives !
Yes, I clearly had a sneaking suspicion back in Aug 2019...
Just created four perpendicular planes aligned with x, y, and z axes, each mapped to the full UV square and applied my random pool tiles material.
FireFly has no problem:
SuperFly on the other hand - if the constant is plugged into the y_index input of the Noise node (with the u/v derived values plugged into the x and z), as in my shader, the XZ plane is okay but the other two aren't.
Plug the constant into the x_index, with u/v to y/z:
And constant to z_index:
Exasperated. That's a good word for how I feel.
3dcheapskate ( ) posted Tue, 16 July 2024 at 7:49 AM · edited Tue, 16 July 2024 at 7:49 AM
Online Now!
Hmmm...
the simple expedient of plugging the u-derived value into the y_index of the Noise node (instead of using a constant) makes all three planes render as hoped - but with a diagonal symmetry. And both FireFly and SuperFly render the same pattern.
But even better is using the v-derived value instead for the y_index input - no symmetry:
PwrnCWxZQnIdFtO4ryAz0Jkdo9DKi3szDKJjYKSE.jpg QcV6Uza9ALv3rEbKi90jdqO1Cj5yMb4ZgvkHYC4i.jpg
3dcheapskate ( ) posted Tue, 16 July 2024 at 7:58 AM · edited Tue, 16 July 2024 at 7:59 AM
Online Now!
Okay, that seems to work on the toon pool too, albeit there's a minor artefact on the FF render now (just to the right of the diving board, a sort of vertical line) - I think I can live with that
odf ( ) posted Tue, 16 July 2024 at 7:21 PM
Interesting stuff! So, what does your final shader look like?
3dcheapskate ( ) posted Wed, 17 July 2024 at 2:15 AM · edited Wed, 17 July 2024 at 2:19 AM
Online Now!
It's the same as the most recent screenshot except that what's plugged into the y_index input of the Noise node has changed, and now unused node that was plugged in has been deleted. I also changed the number of tiles and the mortar thickness.
Set Value_1 of Math_Functions on the right to the number of tiles you want, but don't change anything else in the three columns of nodes at the right. You can change the colour/value of any parameters in the Noise, ColorRamp and Tile nodes that don't have an anything plugged into them. The x_index, y_index, and z_index values in the Noise node and the Mortar_Thickness in the Tile node are fair game too.
FireFly and SuperFly renders again. You can see those artefacts I mentioned in the FireFly render again - definitely similar to what I spotted back in Aug 2019
5cZMsCGwRvFdI5OSzeMIFAgwC9mXCH6wWJzAwgzY.JPG LINAiwZcwMC7JCgESpXuUVIbUjwrgIMEDDinfy72.JPG
I can't attach mt5 or txt files to this post, but I plan to upload the shader here in Renderosity's FreeStuff
3dcheapskate ( ) posted Wed, 17 July 2024 at 6:57 AM · edited Wed, 17 July 2024 at 6:59 AM
Online Now!
Found some values that give a good dynamic range from an fBm node, so tried replacing the Noise node with an fBm and plugged that into the Red input of a User_Defined node. Added a second and third fBm node to drive the Green and Blue, tweaked the x/y/z_index values in them to get a different pattern from the first. Now I have the complete range of colours available for the tiles:
Works in both FireFly and SuperFly, without those FireFly/Noise artefacts:
(note: the u-derived value is plugged into x_index, and the v-derived value into y-index and z-index. Using a constant produces the same problem as before)
3dcheapskate ( ) posted Wed, 17 July 2024 at 7:06 AM · edited Wed, 17 July 2024 at 7:08 AM
Online Now!
Adding a Math_Functions:Max and Math_Functions:Min node, setting the Red of my User_Ddefined to zero, and making sure Blue is greater than Green I now have just blue and blue-green tiles.
...and no artefacts in FireFly:
I think I have my solution :o)
3dcheapskate ( ) posted Wed, 17 July 2024 at 7:34 AM
Online Now!
I'm uploading the mt5s to the HiveWire3D forum here Random colour tiles (Poser 11 FireFly/SuperFly) | HiveWire 3D Community
odf ( ) posted Wed, 17 July 2024 at 6:41 PM
Very cool, thanks! I'll have a play with it.
3dcheapskate ( ) posted Sat, 20 July 2024 at 6:44 AM
Online Now!
an0malaus ( ) posted Tue, 23 July 2024 at 6:45 PM · edited Tue, 23 July 2024 at 6:47 PM
Just a quick speculation on the artifact you mentioned above (one tile or column of tiles with a colour change at its right edge).
That could be because the mod function is running into a whole number at its maximum range value, and just ticking over to the next number. A solution might be to use a float value just below a whole number as the range, like 31.99999 instead of 32 exactly, so the modulus will not have an isolated transition at 32.
My ShareCG Stuff
Verbosity: Profusely promulgating Graham's number epics of complete and utter verbiage by the metric monkey barrel.
3dcheapskate ( ) posted Wed, 24 July 2024 at 3:42 AM · edited Wed, 24 July 2024 at 3:42 AM
Online Now!
The artefacts in the noise node are actually more complex than that - here's a render plus the shader used.
(I've given up with the Noise node after finding settings for the fBm node that give me more or less full dynamic range from o.o to 1.0, and I've almost completed a fairly flexible compound node using fBm nodes - post #9 on the 'Random Colour Tiles' HiveWire3D topic )
an0malaus ( ) posted Fri, 26 July 2024 at 11:19 PM
"Yikes", "Concur", "We don't need any more of these!"
Pretty * Useless, where "*" is some vaguely defined boolean (or quantum) operator.
My ShareCG Stuff
3dcheapskate ( ) posted Sun, 28 July 2024 at 4:42 AM
Online Now!
You've totally lost me there ! :oD
Never mind, the fBm node saves the day, and I've now inserted an all-singing all-dancing fBm-node-based  "Poser 11 compond node for creating random colour tiles" freebie into the Renderosity FreeStuff.
(Yes I know there's a typo, but I can't be bothered with asking them to add the missing u to the freebie title so a compond node it is then)
3dcheapskate ( ) posted Thu, 01 August 2024 at 9:33 AM · edited Thu, 01 August 2024 at 9:35 AM
Online Now!
Just worked out a version in world space using P node x and z coordinates instead of U and V
MT5 posted over on the associated HiveWire3D topic, post 13. (you may have to scroll a bit to find post #13)
Render of two objects, a plane and a cone, using the shader
