26 threads found!
buddhanature28 | 16 | 471 | ||
buddhanature28 | 3 | 123 | ||
buddhanature28 | 5 | 227 | ||
buddhanature28 | 19 | 337 | ||
buddhanature28 | 9 | 381 | ||
buddhanature28 | 3 | 137 | ||
buddhanature28 | 1 | 94 | ||
buddhanature28 | 4 | 127 | ||
buddhanature28 | 6 | 178 | ||
buddhanature28 | 26 | 407 | ||
buddhanature28 | 3 | 114 | ||
buddhanature28 | 9 | 200 | ||
buddhanature28 | 6 | 170 | ||
buddhanature28 | 2 | 79 | ||
buddhanature28 | 47 | 1140 |
177 comments found!
Thread: trouble creating animated texture | Forum: Poser - OFFICIAL
Hmmm not sure I'm following you? Add just the dragon? It will still need the textures...Maybe you could clarify?
Thanks!
Thanks again for the continuing support! Yes I do see the texture when I render a single frame and yes I am rendering in firefly. I did change the settings as you suggested and rendered a series of png files. I have never recomposed them into an avi file before and seems like an extra step I wish I didn't have to take. I am also wondering how useful it will be to me as my end purpose is to animate the skin on a dragon and then cut the footage of the dragon into live action footage...might be totally doable once I see how you reassemble as a movie...but like I said wish it wasn't necessary! Your work sounds fascinating and beautiful!
thanks for the encouragement! OK I enable hardware shading as suggested. It still does not allow me to see the movie texture until I have rendered. I render in firefly and changed settings as you suggested. Again they show up as images not a movie. When I select make movie under animation it still just shows the white on the model, no texture at all not even as just an image. I assume it would only show me the animated texture when it is made into a movie anyway. But no luck yet!
Hi I think I determined that the file size of the video might have been the problem. I have tried a new video which is much smaller and at first I thought it still wasn't working as model is still white but then when I test rendered a patch it showed up as an image (not as a video though. When I created a movie out of it I was hoping the texture would be animated as am using an avi file. But the movie I created of the scene contained no image at all not even the little I got in the test render. I produced an uncompressed avi file from premiere pro but when I loaded that it left the square at the bottom white. So I created the regular avi and I can see what I have shown here in screen shot. However I am having the issues described above. So am now closer but still not the animated texture I need. Any more ideas would be appreciated.
Thread: different in still render to animation render? | Forum: Poser - OFFICIAL
Thread: Real Metals in Poser pro 2010 | Forum: Poser - OFFICIAL
Hi hborre, Thanks for the advice. I tried that but same problem. It doesnt load if I click on it directly in the library window, if I load it in materials room it loads the image but instead of one color like you can see it advertised in the product it is the color I want and then either half black and half white. I have tried to contact daz support but they no longer help over the phone without going through a ticketing system first so it will be days before I even get my first response from them as they would only take my email address yesterday and now its the weekend. :-( Might just get my money back. Thanks for the help though. H.
Thread: How to create a 2D prop for Poser Pro 2010 | Forum: Poser - OFFICIAL
Wow thanks for all that everybody. I'll give it all a go and see what I can come up with. How do you add color to different parts of the image if it has to be all black and white? Thanks!
thanks for replying. I created an image using the brush in gimp in black on a transparent background and saved as a jpg. (Is this what you meant by silhouette) then I set the transparency to 1 and fall off to 0 as you said. And plugged it in to transparency. As you can see I can see the square which is what I am trying to avoid. I am sure I misunderstood something!
Heather
