Community Center F.A.Q (Last Updated: 2025 Feb 10 11:31 pm)
Quote - Well I use to could not see the reply box in FF but now I can. Everything about this is weird if you as me lol. I just want my products I paid for. I have one thanks to the generous vendor but sadly I still can't get the other.
Just a thought.
Have you tried downloading them using a different computer, one that has a different firewall and virus scanner?
if you are able to download from another computer but not your own, then it would seem that the problem is something on your computer, likely settings to your firewall or virus scanner.
say." - Ghandi
the site somehow disabled or deleted the download manager function in an older copy of
netscape that I sometimes used on a machine with no firewall, meaning said browser can no
longer complete any downloads from any site, including this one. I know said browser is not
supported, but haven't the foggiest how it managed to rewrite the browser code, somewhat like
a worm. IMVHO a firewall is mandatory if the new site software is trying to rewrite the client's
browser modules, or other client-side software.
otherwise, on a more secure machine with hardware and software firewalls, the site software
hasn't been able to do any damage to my other browsers (explorer, safari, firefox), although
of course the html editor (reply box) doesn't work properly in any of them.
I find it difficult to believe that (a) it's even possible for site software to rewrite or modify anything on ones browser. (b) even if it were possible, that it would have any legitimate purpose to so such a thing. I may have some issues with how Renderosity applies its policies, but I seriously doubt that they would go out of their way to do nefarious things to my web browser, including trackers. In all my years as a member of Renderosity, I have never found any evidence of malicious code on the site.
AFAIK, NOTHING was done to modify the software that caused this problem. This has to do with a routing issue. The site was moved to a new server on Monday. Since then, some members are experiencing packet loss during downloading. This is causing all sorts of oddities for a few of us.
I really don't think there is anything we can do on our end, except be patient, and let the tech folks sort it out.
just to reassure y'all, it occurred to me that the download manager for the particular
user (me) of the aforementioned browser may have been disabled by some other site or action,
hence no need for concern. it was likely just a coincidence that the download manager for
that user of that browser was disabled around the same time as the site problems (if any)
developed.
I just tried the same browser on the same machine with a different user (standard mac
troubleshooting technique) and said browser's download manager is o.k. after visiting this
site. if any folks are experiencing download problems from here, I daresay they'll set it right
ASAP. I just tried to download the floribunda freebie and it downloaded/expanded o.k.
Ok, this is getting kind of annoying. I have yet to have one completed uncorrupt download from the store since its opened. I don't have problems like this on any other site I go to. Garbled pages, garbled images, and garbled zip files. The latter is constant, the other two irregular but showing up too often for my liking. And another symptom is that downloads seem to be moving at a fairly sluggish pace for My connection.
Here is what we need to know from everyone having the problem:
Can you please clarify your statement of "since its opened"?
The RMP has been open for several years. If you've been having troubles for that long, there is probably something else going on in your case, either separate issue, or in addition to the current troubles. The situation under discussion in this thread has to do with a routing issue for some customers, involving packet loss, caused by something that happened on Monday June 23, 2008, during a server transition.
OK, I admit it ... I was bored. [grin]
I did another 6 downloads of the test ZIP file in addition to the one I did a few days ago. I used Netscape 7.2 for 3 of the downloads and Internet Exploiter 7 for the second 3 downloads.
I couldn't find any of those 7 downloads would uncompress and allow the PDF to be viewed ... I couldn't even find any 2 of the 7 that even had the same error ... that is, I couldn't find any 2 files that would compare as equal using the file compare command (FC from a command window).
This is a very simple test that your programmers and/or network admins could run both from your LAN or also from some other location. I don't know if your servers are located in your office space or not ... but if you can download and expand the file when you are on the same physical LAN as the servers but not otherwise ... this problem is something your ISP is doing ... OTOH, if it's always bad, then it's something to do with your servers.
If what I wrote here isn't clear, please have your programmers and/or network admins contact me directly.
Martin
p.s. In an earlier message in this thread, you already have the details about my setup, ISP, ...
I had no problems downloading or unzipping the file
My Freebies
Buy stuff on RedBubble
I see that Khai raised an important observation,
except, you've missed the post where I let them know it downloaded fine here
... which if it was the servers, would not happen...
True
... OTOH perhaps I'm channeling Inspector Clouseau who sometimes began an investigation saying, I suspect everyone and I suspect no one. [grin]
Martin
No he is not the only one seeing the site like that. I'm seeing it spread like that with garbled code as well. A refresh usually brings it back, sometimes it takes 2x's.
I'm also getting partially loaded and corrupt looking images generally in the marketplace and the gallery.
3-D Arena | Instagram | Facebook
I do not feel obliged to believe that the same
God who has endowed us with sense, reason, and intellect has
intended us to forgo their use.
-Galileo
That's not what I meant.
He keeps referring to the image he uploaded as looking different than what he uploaded.
My point is that I don't think that the graphics anomalies appear the same for everyone at the same time, because the image he uploaded, while it was a screencap of a garbled screen, had no color anomalies that I could see. I have also had these anomalies, and then returned to the same image later on and it would be fine. Another view..after leaving and returning, might yield yet a different anomaly.
I see that Momcat wrote,
The color thing will come and go at random.
... and also,
You are the only one seeing it like that.
Ahhhhhhh ... you have contradicted yourself ... if you know, "The color thing will come and go at random" ... then you must have seen it yourself (or been told about it by someone else) ... therefore, how could you also say, "You are the only one seeing it like that"?
OTOH, (In any case) how could you possibly assert that I am, "the only one seeing it like that"?
IOW, what kind of statistical sample would 'prove' your second statement to be true?
Here's the bottom line ... I've worked with all aspects of LANs for a total of close to 20 years. In addition, I have about 12 years of Data Communications Systems Design in my background. That 32 years of experience was at all levels: system. protocol, specify, design, implement, and debug right down to the bit level.
One of the worst things anyone can do when facing an elusive issue like this one is to dismiss some of the observations without proof ... and misslead the people who are supposed to fix it.
Martin
You are correct. I have no way of knowing if you are the only person seeing it like that. I was not successful in communication what I wanted to get across, and likely misunderstanding what you were trying to say.
I was under the impression that you were referring to what appear to be color changes in the images you uploaded.
If that was not the case, then I have no idea what specifically you were referring to.
If it was:
Did it look anything like this? (image too big..didn't post the first time)
Posted this before, but did not seem to "take". Sorry for any duplication.
Larry F
Quote - ::sigh:: I hope they can get this fixed soon. I wonder how many of us there actually are. I'm very interested in knowing what the common denominator is here.
Me too, Momcat! I've tried downloading older purchases- both here and at RDNA- still the same mess. I've downloaded purchases from other non- Bondware sites (zip format) and they work fine. I, too, see the funky images like the one you posted. Wonder if the Bondware people are off for the weekend...? Guess we just sit and wait.... :o/
Well, I hadn't seen that forum bar thingy at RDNA but I did re-D/L some old purchases from there and THEY WOULD NOT UNZIP! Of course, I think this must mean that I will not be buying anything from a Bondware site for a bit. Spent the greater part of today trying to install a purchase I made today with no luck. Debbie M was very gracious in trying to help me, though, and I appreciate that.
This will likely be sorted out in a bit, though we may not know what the "common denominator" was.
@Momcat
I am seeing both scrambled images (color messed up ... like your example) and also distorted web pages (per my examples)
@3-DArena
Today is the first time the forum text box was missing for me --- had to clear cache and reload 3-4 times to get this opportunity to post this message. Anyone who knows my posting history will realize how distressing that would be for me ... that is, not being able to post a message [grin]. Also saw repeated warnings in IE about error in page ... many retries to get it to load without error.
@scanmead
both kinds of problems (scrambled images and funky web page formats) are happening in both browsers.
Martin
I see that Momcat wondered about,
IMO, it seems to attack larger files more than smaller files ... i.e., the longer the file, the more likely it will be inaccurate. Other than that it seems to be somewhat random.
Another point ... based on my 6 tests today (downloads), even though the downloaded file content is corrupt, the file size is unchanged in each test ... this suggests that the correct amount of data is being sent (file size, image size, ZIP file size) ... but incorrect values were being substituted at some point.
This could be quite nasty to track down ... one strong possibility is a bad memory sitck in a router somewhere ... or a bad port, bad fiber splice, bad cross-connect cable ... so many interesting possibilities ... and not all of those possiblle hardware impairments are under the control of renderosity (bondware).
Martin
p.s. As you might guess, I love to troubleshoot/debug ... hardware/software issues ... then again, my idea of fun ... might not be yours. [grin]
Well thanks ever so much, Momcat, but I know those folks at RDNA are tops. I just think I don't need any more aggravation around this type of issue right now - kind of a low priority actually, given other more pressing matters around my house right now. I did buy something from them that got hung up through PayPal and they did practically jump through hoops to rectify. Thanks again.
Larry F
Who is your ISP? comcast
What type of Service do you have (dial-up, dsl, cable, etc)?Cable broadband
3) What OS do you run and what version and service packs? XP home, sp3
4) What software is used to Unzip the file? (version & service packs) WinRAR 3.70
5) Do you use any type of download manager? No
7) What is the file size stated on Bondware before downloading and what is the file size your computer has after downloading (but before trying to unzip)? 11.6 MB listed in Firefox
download list, 12.1 MB in file folder.
Note: WinRAR was able to repair the ZIP, and the repaired version extracted properly.
My python page
My ShareCG freebies
I see that ockham seemed to have a success,
That may be ... or may not be.
I wouldn't trust those extracted files at all.
If the ZIP was corrupted during the download and the winZIPintegrity checks determined that the ZIP file was corrupted, how could any other software possibly correct the extraction by 'guessing' the correct values? HINT: corrupt ZIP file means the downloaded data included values which were invalid ... that would mean that the extracted file would also be invalid.
IOW, it is not possible to get back the information that isn't there.
Martin
MGD...I have had files to open with winrar that winzip wouldn't open..that's why I don't use winzip anymore...
And...if you tell me I don't know what I'm talking about...I'm gonna smak ya! :blink:
“For those who believe, no proof is necessary. For those who don't believe, no proof is possible.”
[Stuart Chase]
Has anyone considered the possibility that it may be an ISP issue in only one area? If the people having problems might tell us their basic location that might help...different ISPs perhaps but same backbone?
zai
Rendo Store | Freebies | RDNA Store
Thanks for the Info on RDNA. I have sent A email the rendo requestinga refund of what I purchased. All except one item when the vendor here was nice enough to give me a another link to download it at :) But other then that I purchased my items thursday and contacted both vendors. Only one offered another way to download. So now I want a refund for that other item. I am unable to unzip it or use it at all cause of the site messing up. I just want my money back on my credit card. I will not be shopping here anymore till the site is fixed and even then who knows.
Downloaded & extracted the test file with NO issues:
3) What OS do you run and what version and service packs? XP Pro x64 w/latest SP's
4) What software is used to Unzip the file? (version & service packs) WInZIP 9.0 SR1
5) Do you use any type of download manager? None
7) What is the file size stated on Bondware before downloading and what is the file size your computer has after downloading (but before trying to unzip)? N/A
