Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
I see the same problem with a highres clothplane and V4s head. It looks like the original position of the head is not updated during calculation. It does change somewhat if you lower the offsets and friction, but it will never settle the right way.
Looks like a bug here. Are you going to report this to Smith Micro?
Tried that. Seems like there is a -piece- of the head that it collides with, not the whole thing. I made another experiment and made the whole hairpiece constrained. Even then, the portion where the dynamic group would collide with whatever it is in empty space did the same thing to the constrained group, like a stretched out block about the height of her ears...
Quote - I think that there can be any JMC magnet. Try craeate phantom head - head shape prop but less resolution. It really helps. V4 head has number of polygons on ears, lashes etc. Their normals have different directions and it can cause simulation errors.
You may be right. It looks like the ears have something to do with it. But P7 ran the simulation ok, so something must have changed in the behaviour of posers clothroom
Quote - I probably should report it. In the mean time though, I wish there was some sort of work around so I can continue with the project. Got some really cool ideas for good cloth hairs, but this kinda puts a damper into it. :)
For a workaround, can you just do the sim in Poser 7, spawn a morph, save the scene, and then load in PP 2012 to finish the work?
If I want to continue working with the hair, I'll have to stick to Poser 7. Saving a morph won't really do much since it's a cloth hair. Reopening the project again in PP2012 to work on materials and so on would work though.
The idea has been to make something that can eventually be distributed, but it'll be hard to make anything that can be distributed if people are forced to use a certain older version of Poser.
I made a test with this, using the skullcap parented to the head for the simulation. Turns out that the hair's constrained group will not follow the skullcap unless the head is included in the simulation too.
It turns out that JoeBushido's cloth hair doesn't have this issue. It's a conforming item with the hair included as a prop which is then simulated. Why this works is beyond me though.
Ok something really weird happened. I was messing around with turning on and off different collision objects, and suddenly it started working. When I reloaded the project again and did the same type of things, it was back to it's normal weirdness though. Can't for my life figure out what made it suddenly work.
Constrained groups do not works against props. You can make it choreographed.
Maybe it is a bug, but if there is any magnet different Poser version can select different way child props. Default setting should not include magnets o colliding group, but maybe P9 does not recognize it as a magnet.
Nevertheless I think that transparent prop resolve problem faster and easier then SM fix Poser. Moreover you can join hair strands and head phantom as a 1 prop (choreographed group)
Choreographed didn't do it either. The constraints still won't follow the parented skullcap. :/ It also raises another problem, which is the rest of the body. It's a very long hair, so it needs to drape over arms, chest, back etc. If any V4 bodypart is selected, not just the head, the same weird thing happens.
SM is on the case at the moment trying to help figure out what's going on and finding a workaround, too.
Quote - Constrained groups do not works against props. You can make it choreographed.
Ok, revisiting this thread with some updates, and a challenge!
Earlier in June, I spent over a week with SmithMicro, who did all they could to help me test and resolve the issue, but we weren't able to do it. It seems to be an issue specifically with the Generation 4 figures (happens to M4 too), which is what I want to make the hair for.
I've got really nice ideas for this hair, got photo sources made and everything is set, but this issue still persists. One option is to make each "piece" thinner, that way they would probably just slide around the bump, but it wouldn't be a great solution, especially for animation.
If I can finish the hair, it will be available completely free for the community. I'm making it because I'd like nice, flowing -long- hair that doesn't take 3 hours to pose with handles, or with the really long calculation times in the cloth room. I am sure there are others who would enjoy it too, if it turns out well.. So is anyone out there interested/willing to help out testing or troubleshooting, figuring out a workaround? If you are, just lemme know and I will send some test props! It'd be cool to see if we could make some really good dynamic cloth hairs for the Poser community.
There have been some improvements in this area done in SR3
The simulations I did with a cloth and a v4 head were better afterwards. Without having the actual item I could not see if it improved this particular problem
Have you tested it with SR3? And has it improved? I am happy to volunteer and help you with this
Ok I've emailed it to one person, just drop me a sitemail with your email and I'll send it.
Here is a description of how it's set up:
Two obj files, one with just the base hair, and one with a soft decorated group. It's quicker to just test with the base hair first. It has the following groups:
"constraint" for the hair roots to keep them from falling
SC1_auv for the skullcap, probably works best constrained too
"Hairbase" for the main hair, and "Hairsoft1" for the full hair, a test with soft decorated groups to add thickness to the hair.
The skullcap is made in Wings, and the strips were made in MD2 and then attached in wings. I found that the hex triangles that I get from MD are -way- faster than quads. The full hair with soft decorated groups is 20k polys, and gives no problems as far as simulation speed. Could probably double it and it would still do fine (just might, if it ends up working, with more thickness)
The main problem that arises is if you run a simulation where V4 tilts her head or moves to the side, with some sort of invisible bump there. It shows clearly in the image in the first post.
Also, please feel free to use the skullcap and hair strips to make your own hairs! All I ask is that the resulting hair is made freely available for the community. If you want more hair strips I can make them easily.
At first glance it looks like the inner and outerlayer of the hair strips are mixing with eachother at some areas. This also happens to be the area where the problem occurs. It then looks like that as soon as you tilt the head the simulator gets confused at this point and only calculates the outerlayer at that area, with the result that the inner layer pushes the outer layer out.
You said that you used MD2 to create the strips. MD2 simulates differently as the clothroom in Poser and probably has no problem with the overlapping layers. I wonder if you can get the outer layer not to touch the inner layer would make it work. I tried to create a new group for the outer layer, but that is pretty difficult if not impossible in poser because of the overlap. If I had that group I could have moved it away from the inner layer and test it that way
I am going to do some more experiments tomorrow after I get back
Quote - It's really strange. It tends to work better in a bit older versions of Poser. I just tested it in Poser 7, and it works fine, so like you are saying, it's probably fairly new. I recall it being problematic in P8/2010 as well.
It's ironic you say this, because I just refrained from commenting in the thread asking for release dates to say how relevant they are. This is a prime example. I know of some dynamic cloaks for V4. Their promo renders wouldn't have been possible with this problem. If we knew when they came out, we might be able to hazard a guess about P8/2010 without testing it there.
Edited to add: The sim using the imported obj didn't go very well, but it seemed to not go well in a correct fashion. If that makes sense. Trying something else...
I think I found the solution for the problem
What you need to do is to make the eyebrows visible then run the simulation but with the eyebrows excluded from the collision targets. After the sim you can turn off the eyebrow again.
It looks like the sim collides with the eyebrows in its original position even when invisible and not a collision target. Making it visible and excluding it makes the sim work.
This is a weird bug
Can someone confirm it is working this way?
I had my project up just now, so tested right away. Making the eyebrow visible and running the simulation did the trick, very funny bug to be sure!
Well, now it's at least possible to make this hair, even though it needs some special treatment in the clothroom! Maybe it's possible to get this issue fixed in the next version of poser, since we know what it is.
I still have the ticket open with SM, so I can send this information to it, so they have it.
Quote - I had my project up just now, so tested right away. Making the eyebrow visible and running the simulation did the trick, very funny bug to be sure!
Yes, send it in. Please do as soon as possible.
Do you have a texture or template for the hair?
One issue is when the dynamic hair intersects with itself, creating render artifacts. The one to the right has no soft decorated group, only a bunch of cloth segments. The one to the left has a soft decorated group over it, a first layer of thickness which does look a bit better!
If I have too many layers, they may cut into each other, if I have too few, they may create too many gaps. There's also the issue of when the character tilts her head. More than one layer is kinda necessary, like up at the top, some that begins down at the ear and so on, otherwise she will look very bald underneath when she moves her head in any unusual position. The textures is a first rough, just to get a general feel how it works, with a really rough trans map too.
I know it has a ton of potential, just need a smart method to do it.
Quote - Yes, send it in. Please do as soon as possible.
Responding to the ticket now!
I just corrected the UV maps in the latest version, the one I sent didn't have much work there, and has some UVs all over the place. Just starting this, it's our first hair. Got some photosources to work with. Done a ton of dynamic clothes, so I understand the basics of hair, too.
Im soo glad i found this thread, im currently also making a dynamic cloth hair,but ive paused to perfect my hair shader that currently works with most transmapped hair. my aim is to make dynamic cloth hair that is 100% node based with no images,including no transparency maps,(this shader does currently exist but is being tweeked).im also putting in a few little tricks which im keeping under my hat for the moment.....i will post info on my dynamic cloth hair if people want when im back in the cloth room.....oh and dont try windforce with the hair in sr3 it is also broken, you have to use a pre sr3 poser 2012/9 or an earlier version of poser
Getting old and still making "art" without soiling myself, now that's success.
Quote - Im soo glad i found this thread, im currently also making a dynamic cloth hair,but ive paused to perfect my hair shader that currently works with most transmapped hair. my aim is to make dynamic cloth hair that is 100% node based with no images,including no transparency maps,(this shader does currently exist but is being tweeked).im also putting in a few little tricks which im keeping under my hat for the moment.....i will post info on my dynamic cloth hair if people want when im back in the cloth room.....oh and dont try windforce with the hair in sr3 it is also broken, you have to use a pre sr3 poser 2012/9 or an earlier version of poser
Looking forward to see what you come up with!
My biggest challenge right now is to figure out how to give hair thickness without getting weird render artifacts that come when the dynamic segments intersect each other. I am pondering if I should make a lot of small strands, or maybe a single big like hood for the main style with just soft decorated segments over it. A lot of thick layered hair segments doesn't work so well at the moment.
It may be possible to use more than one hair prop though? Self collision usually doesn't work nearly as well as layers of clothing.
Ah! That makes sense as a problem. It was bothering me that it was a problem with the figure and not the prop, even when the figure was completely different. I'm so glad you guys figured it out!
I think your hair solution depends a lot on your end goal. For me, hair is a basis more than a finished step. I have a hair shader I'm pretty happy with at the moment, and I've always used hair that I can pose well. But the only purely realistic hair I've seen has been custom made for a still, taken from a photo, or painted. Including pro level dynamic hair. So for me, as long as it's not in the entirely wrong place or doing something so wrong I need to do a lot of fixing, I really don't care. For me, a simple hair mesh that worked sort of like a softbody would be preferable to something that was strandy but full of errors.
Also, I'm pretty sure I've seen someone at CG Society show off dynamic hair styles as theirs that were hair that followed some top Poser hair meshes, including some Kozaburo ones. If you could use your cloth hair to do for strand hair what skull caps do for regular mesh hair, as well as serving as some sort of guide, that would be really powerful. I think a lot of what makes dynamic hair so scary is styling. If it was possible to do a basic style with mesh, get strands to follow each piece, and then just run the dynamics, that might make dynamic hair more usable.
Okay, this is what i've got....(nudity in animation)
http://jrdonohue.com/clothhair3.mp4
I don't seem to have the (eybrow?) bug.
So, what shader/maps to I put on this, and I wonder if it will look like hair in animation if I do.
It would be great, because the simulation churns at about 2-3 seconds per frame, even with collision.
Any suggestions for making it look like hair?
::::: Opera :::::
[edited to add: I am not colliding against "head" because it was not giving good results because of ears. So, i have a very low res proxy (you can't see it) parented to the head, and the prop parented to the proxy. you may see a little "whoops' with the nose, that's because I carelessly did not ease the nose inside the proxy!]
::::: Opera :::::
Looks like you have a similar approach like the one I have. A skullcap and then strands attached to the top.
I'm also working on having layers underneath too, so all the hair doesn't come from the top of the head. The difficulty seems to lay in getting the thickness right. I thino that soft decorated layers is the key, but I haven't quite figured it out yet. Hair props have a long turn around time, it takes a while to make something before testing. :)
As far as making it look like hair, hair textures with trans maps is probably the way to go, (Unless you are really good with the material room) that's what I'm doing. There is a ton of hair resources around.
Quote - Ah! That makes sense as a problem. It was bothering me that it was a problem with the figure and not the prop, even when the figure was completely different. I'm so glad you guys figured it out!
My end goal has for some time to have nice, long wavy hair that doesn't need so much adjusting for a custom figure. My female characters are often more bigger and full bodied, with a ton of morphs, which makes working with conforming hairs challenging. It takes so many rounds with the morph tool and magnets to get them to fit, and then if I move the character in leaning pose, the hair still hangs at the wrong angles. It -is- doable with a lot of work for stills, but if I want animations or a more "in movement" pose, it's frustrating.
I'd like to get a nice, rich long hair that also gives the illusion of thickness. That's why I am playing around a lot with soft decorated groups.
I am pondering if having fewer layers of dynamic hairs, more like one or two big elements (easier to style too), and then a ton of soft decorated strands over it may do the trick.
The problem with multiple dynamic layers is when they go into each other, some intersects just look really bad in render.
Another type of hair I want to make is a version of the same long hair tied up in a pony tail. I gather this is much easier. All I need is a dynamic tail, with a ton of soft decorated hairs layered over it, should do the trick.
With hex triangles, poly count and simulation speed doesn't seem to be much of an issue any more, so the main challenge is to get the styling and layers work right.
I'm making two hair props. One has the lower layer, that starts at ear level and goes down. The thick strands are "sown" together, creating more like a loose cap than strands, giving the hair completeness. Then I am making another prop on top of it that starts from the parting on top of the head. This will collide with V4 and the underlaying prop. I haven't added any soft decorated strands yet, but I think it could work!
The clothroom likes separate props layered on each other much better than self collision, probably for obvious reasons, since the self collision will have a harder time deciding what goes on top. 2, or even 3 separate props and the top one having soft decorated groups for styling and thickness really could be something. They are layering as they should. Now it's just a matter of refining everything and getting it right.
MD really is nice for making those strips! They are automatically made as hex triangles, and the strip comes unwrapped straight, easy to texture. They just need to be organized a bit. The screenshot shows with and without test texture, and no transmaps.
It's a a simulation and it actually has volume which is really neat!
I'm working on a dynamic cloth hair, and have gotten quite far, until I ran into a really pesky problem while trying it in different poses.. If V4's head is turned or tilted during the simulation, the cloth will continue to collide with something, as if there is an invisible object somewhere.
I've tried a ton of things to solve this, including trying a new, clean project, colliding just with the head, different cloth room settings, longer simulation (The hair will NOT settle, unless it slides past that invisible.. whatever it is), I've tried different parenting options, with no success.
The image included shows what it looks like using a simplified one side only piece of the hair without textures. It's dynamic except by the top of the head which is constrained. I even tried taking a simple piece of cloth, draping it over her head, and it gave the same result.
Anyone have any clue what can be causing this, and how I can fix or work around it?
The cloth uses hex triangles for optimum speed and quality of simulation.
