498 threads found!
lululee | 8 | 392 | ||
lululee | 2 | 201 | ||
lululee | 5 | 251 | ||
lululee | 2 | 588 | ||
lululee | 4 | 253 | ||
lululee | 3 | 648 | ||
lululee | 4 | 931 | ||
lululee | 2 | 391 | ||
lululee | 0 | 106 |
(none)
lululee | 2 | 198 | ||
lululee | 5 | 439 | ||
lululee | 1 | 69 | ||
lululee | 3 | 489 | ||
lululee | 6 | 255 | ||
lululee | 3 | 1380 |
2,243 comments found!
HI skinklizzard, Thanks sooooo much for all of your valuable help. I cannot tell you how much I appreciate it. Your PDF was just what I was looking for. I looked at your store. You have some beautiful products. Nice to meet you. Cheerio lululee
Thread: How to fix pokethrough on a morph? | Forum: DAZ|Studio
Hi skinklizzard , I am using the GoZ Plugin to load the morphs which works fine. Basically my problem is I am using SickleYield's supermorpher set to add the morphs. It adds some morphs of characters i don't own. It seems there is some pokethrough on 2 of those morphs and some pokethrough on the bodybuilder morph. Since I don't have the character I can't see where the morphs are poking through. I tried on the bodybuilder morph to correct it in ZBrush but it did not autofollow on the morph I created in ZBrush so I am stalled. I added other fitting morphs but they don't autofollow. Grrrhhh! Any advice is appreciated. Cheerio lululee
Hi skinklizzard, Thanks so much for your valuable info. I do have ZBrush, but I realize I need to find a tutorial on how to put in the morphs so they autofollow properly. If you run across one please let me know. Cheerio lululee
Hi Richard, Thanks so much for your valuable info. Hope you have a great day.
Cheerio lululee
Thread: Are Prime products released on Mondays only? | Forum: MarketPlace Customers
Thread: Poser user really frustrated with store contents... | Forum: MarketPlace Customers
I supported Poser for a very long time and would like to support Poser again if it is profitable.
I think part of the problem is what character is profitable to support in Poser? There are now so many Poser characters and of course most of us are supporting G3 and G8.
I could not find a way to support G8 in Poser. She did not bend properly when I tried working with her. G3 is fine but profitability was not so great although it may have changed.
It seems to me Poser users are still using V4?
I think the best solution that would bring ALL of us profitability, (vendors and Renderosity) would be if Blacksmith could convert FROM G3 TO V4.
PBR: Since a lot of vendors are using PBR materials ByteFactory3D PBR-Emulator FIREFLY will quickly convert PBR materials to Firefly and can be used in Poser 9 +.
I have used it and it works very well. It's easy to use and quick to learn. The merchant version is a bit pricey. Maybe ByteFactory3D would run a sale for us. That would give us the PBR quality in Poser.
Basically a combination of a Blacksmith G3-to V4 and the PBR emulator would give vendors a fairly quick easy way to convert our G3-G8 products to V4 with the quality of our PBR materials that would be accessible to Poser user from Poser 9+. We could still do our base development for DS and have a quick conversion path to Poser. I think we could increase both Renderosity and vendor profit per product with that path.
Cheerio lululee
Thread: Advice needed to get a new computer that works well with Daz Studio | Forum: DAZ|Studio
Thread: PBR leather materials what node is specular | Forum: DAZ|Studio
Thanks so much Razor42. I'll definitely look into those resources as I am totally enthralled with PBR materials and the quality Daz Studio renders them. Quite impressive. Cheerio lululee
Thread: How to get Ds 4.9 to update when a texture map has been altered. | Forum: DAZ|Studio
Bejaymac posted at 9:45AM Fri, 30 June 2017 - #4308808
In the Surfaces tab's Options menu (top corner of the tab or right click the tab label itself) there is a function to refresh images, default keyboard short cut is Ctrl+I (PC).
Thanks so much for that really valuable info. I really appreciate it.
Cheerio lululee
Thread: Coming soon Maisie NEW Figure for Poser developed by nerd3d and Deecey, | Forum: Poser - OFFICIAL
admins, Maybe you could change the title to "figure" rather than character as she is a totally new figure. However you want to word the title to give the best description is fine with me. Cheerio lululee
Thread: Second Skin Not Showing Up | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Hi, I've been away from the computer and just returned. The lingerie set requires semidieu's FREE Advanced shader plugin. semidieu made it available for FREE at Daz. Go to Daz and type in his name and go to his store. You will see it there for FREE so you can add it to your cart and download it. Install it in the base Poser SOFTWARE you are working in. For instance if you are running Poser 11 install in Poser 11. Please contact me if you have any problem. Cheerio lululee
Thread: Where to find the log file | Forum: DAZ|Studio
Razor42 posted at 8:03PM Thu, 15 December 2016 - #4292758
Log File is located from the top menu drop down under Help/Troubleshooting/Logfile.
Duplicate ID's error is a complex one and relates to the data assets of the product. Richard Haseltine has a script that helps with most occasions of this error. There is a long thread regarding the subject at the Official Daz Forum, a google search should bring it up for you.
I know that a Properties presets supports animation from the timeline in the preset, I didn't think a character preset did so something is odd, it may be possible that you saved a preset that has multiple key frames in it by mistake? The error indicates that the preset uses Animation Key frames that are outside of the set length of the current scene in the timeline. If it is only for textures maybe a re-save as a Material Preset would be suitable?
Thanks so much for the valuable info. I took your advice and re-saved the preset and it is now working.
Cheerio lululee
Hi, Now I am getting another error message. I am making a character preset with just the textures. It tells me I have duplicate id's and that the preset has more frames than the scene. It is supposed to be just a texture preset. Any help is appreciated.
Cheerio lululee
