Tue, Feb 4, 10:05 AM CST
Subject: Poser 8 in Linux with proof ;)
Lucifer_The_Dark ( ) posted Fri, 28 May 2010 at 3:53 AM · edited Tue, 04 February 2025 at 10:05 AM
Poser 8 works in Linux through Wine almost perfectly AT LONG LAST!!!!!!
You have to run the library through the windows version of Firefox by opening the LSMGUI.html file after you start Poser up (Adobe AIR & the latest flash player also needed) but it works!!!!!!! :b_grin:
here's a screen grab from just now while it was rendering a quick IBL enabled test shot
www.freeimagehosting.net/image.php
ps I'm using Ubuntu 10.04 with Wine V1.1.42
Windows 7 64Bit
Poser Pro 2010 SR1
rjjack ( ) posted Fri, 28 May 2010 at 5:14 AM
Good news, i have an used Dell Precision M6300 waiting a new HD and OS, will give a try to Ubuntu before spending something from Micro$oft
RobynsVeil ( ) posted Fri, 28 May 2010 at 5:43 AM
I'm still running Ubuntu 9.04 (have the downloaded 10.04 on my desktop but am not quite ready to make the switch)... this is awesome news. Which graphics driver are you using? I've got an NVidia 9400m G on this laptop I'm typing on... in Ubuntu.
Metaphor of Chooks
Lucifer_The_Dark ( ) posted Fri, 28 May 2010 at 7:08 AM · edited Fri, 28 May 2010 at 7:09 AM
According to the site I'm using NVidia driver 195.36.24 64bit released on 28/4/2010 with my Geforce 8400 GS, I'm using 64bit Ubuntu & 32bit Wine, although I have just seen I can compile a 64bit version if I'm feeling brave.
Windows 7 64Bit
Poser Pro 2010 SR1
RobynsVeil ( ) posted Fri, 28 May 2010 at 7:19 AM
Well done, LtD. 😄
I might have a go this weekend... see how we go.
Metaphor of Chooks
12rounds ( ) posted Fri, 28 May 2010 at 8:05 AM · edited Fri, 28 May 2010 at 8:20 AM
Poser 8 has been working (and Poser 6 and Poser 7 for that matter) with Wine for quite some time now. Personally I've used Poser with Wine for a few years now. Since Ubuntu 7.04. or 6.10. (don't recall exactly). And now with 10.04.
 DAZ installers have been the cause of headaches, though. Some installers work with Wine, some don't. I've used a minimal WinXP installation with Virtualbox virtual machine to install DAZ content, but otherwise using Poser in Ubuntu is a breeze. Also the P8 service releases work fine with Wine now - with Poser 7 installing the service releases needed extra steps.
Oh and currently (Wine1.2, Ubunt10.04, Poser8 SR2) I've encountered only two problems: modal dialog windows can get "behind" the main Poser window, which effectively "locks" Poser and it must be killed. It can be countered easily though. The other prob I have encountered is that the built-in Wardrobe Wizard doesn't work - it consistently hangs at same percentage when doing converting (tested several clothing items for several different base models). Not a problem for me though since I've bought WW1 and WW2 long time ago and they both work just fine.
RobynsVeil ( ) posted Fri, 28 May 2010 at 8:31 AM
Quote - Oh and currently (Wine1.2, Ubunt10.04, Poser8 SR2) I've encountered only two problems: modal dialog windows can get "behind" the main Poser window, which effectively "locks" Poser and it must be killed. It can be countered easily though...
Bit of a show-stopper for me, though. It was doing it all the time and workflow ground to a halt. It wasn't worth fiddling around with and so I had to go back to HORRORS Windoze... to run those apps. Once they get the modal windows issues sorted, though, I'm in!
Metaphor of Chooks
12rounds ( ) posted Fri, 28 May 2010 at 10:15 AM
Once I figured it out it hasn't been a problem for me. I just routinely drag modal windows to such a location that the main Poser window never hides them completely. A bit clumsy, yes, but works for me since I got a 24" monitor and I don't need to run Poser main window containing it full screen. Besides the Firefox needs to be open anyway so quickly dragging the modal windows on top of Firefox to process whatever it is that needs attention, is a minor nuisance really.
Lucifer_The_Dark ( ) posted Fri, 28 May 2010 at 10:20 AM
I heard horror stories a few months ago & then everything went quiet with regards to running it in Linux, the last time I tried it with Wine it was a 0.9 release last year that refused to even look at Poser.
For the record I haven't had any of the windows vanish behind Poser so far. I have Poser 8 SR3 installed.
Windows 7 64Bit
Poser Pro 2010 SR1
12rounds ( ) posted Fri, 28 May 2010 at 11:07 AM · edited Fri, 28 May 2010 at 11:09 AM
Yeah the "vanishing modal windows" is most probably an issue related to some specific graphics display cards only.
I've posted a few times about running Poser in Linux in this very same forum. I first got it to work in Wine version 0.95-dev after some head-scratching, then it didn't work in versions between 0.95-dev and 0.98 and afterwards worked again. There was also an additional issue with Wine versions prior to 1 having a too small heap stack that resulted in Poser going unstable if the number of subfolders in the Runtime grew too big (something along the line of 4000 if I remember correctly). But that's history.
odf ( ) posted Sat, 29 May 2010 at 4:31 AM
I've had the "vanishing modal windows" problem with Poser 8 SR2, but I don't have it with PoserPro 2010. I haven't installed P8 SR3 yet, but based on what Lucifer wrote, I suspect that they may have back-ported some of the changes that made PP2010 run more smoothly.
I love being able to run Poser with Wine.
12rounds ( ) posted Sat, 29 May 2010 at 8:41 AM
Well I have the SR3 installed, but still the problem with modal windows stays. But as said earlier, it's only a minor nuisance once you know how to get past it and attach it to your workflow.
WandW ( ) posted Sat, 29 May 2010 at 11:49 AM
Online Now!
I've been running Poser 8 under Wine for almost a year now:
Wine Application Database - Poser 8
Poser 7 works almost perfectly if the Wine source code is patched and built:
bugs.winehq.org/show_bug.cgi
DAZ Studio 3 works almost perfectly if the MS Core Fonts are installed into Wine...
RobynsVeil ( ) posted Sat, 29 May 2010 at 9:32 PM
Quote - Poser 7 works almost perfectly if the Wine source code is patched and built:
Please define "almost perfectly". I find having to move modal windows unsatisfactory and a show-stopper. Do you have to deal with this as well?
Metaphor of Chooks
WandW ( ) posted Sun, 30 May 2010 at 7:38 AM
Online Now!
Almost Perfectly means that sometimes the parameters and library windows are hidden, but closing and reopening them from the menu fixes it-I've had it do that in Windows occasionally.
The source needs to be patched using my modified patch from post #13 in the bug report.  I haven't tried it with Wine later than 1.1.26, because Poser 8 came out. When I compile it I don't install it, running it from the source directory it via  ./wine 'c:/path to /Poser.exe'
It needs to be run using Allow Window Manager to decorate and control windows, and with Virtual desktop disabled in winecfg...
PS, Smile... ;)
RobynsVeil ( ) posted Sun, 30 May 2010 at 8:03 AM
Good point, W + W... (smile 😄 ) it's one of the Linux things. Blender has suddenly stopped working on my system for no reason, so I rebuilt the kernel with the new NVidia drivers. Some update had borked it. Rebuilding fixed it. Blender works again.
One of those Linux things.
Metaphor of Chooks
WandW ( ) posted Sun, 30 May 2010 at 8:07 AM · edited Sun, 30 May 2010 at 8:08 AM
Online Now!
Indeed-you need to have a sense of humour to use Linux.
Obviously the folks at AT&T who originally wrote UNIX did, as they of course put the most vital system files in the 'etc' directory.... 😄
RobynsVeil ( ) posted Sun, 30 May 2010 at 8:11 AM
That said: for the most part, it just keeps on working. This is probably the first time I've actually had software stop working for no apparent reason.
Getting ready to install 10.04... lot of prep work, backing everything up, first. Hope the upgrade is worth the pain: I haven't read much network improvement stuff in the What's News... and that's where it needs the most help. Also, GIMP is gone, as is Blender. Sheesh. Oh well, Synaptic'll fix that.
Metaphor of Chooks
12rounds ( ) posted Sun, 30 May 2010 at 10:55 AM
Ubuntu Studio would be the distribution branch to get and install if you want the graphical tools all installed and ready to use. I myself think it's a healthy move to NOT distribute everything and their grandmam under the basic Ubuntu installation.
WandW ( ) posted Sun, 30 May 2010 at 11:16 AM
Online Now!
Has anyone tried PP 2010 with WIne?  I wondered if the AIR library would run succerssfully.  I'd be willing to give it a go if someone sends me a copy 😉
BTW, I had opened a bug report on the P8 Library issue, but  it still hasn't been assigned...
Bug 19608
rjjack ( ) posted Sun, 30 May 2010 at 2:17 PM
installed PP2010 but currently i use flash, no time to try AIR for this week-end, all was very simple
install ubutu
install wine
install flash-non-free
install PP2010
change permissions of the desktop icons
launch PP2010
with a terminal navigate in the Poser folder up to the Flex folder
#firefox LSMGUI.html to open the library
some problems :
double-click on a exe open the archive manager, need to change the file properties to open with wine
refresh is slow, maybe with the accelerated driver this will be better
no icons in the library, but content load on Poser
for me it's time to  go to sleep so my experiments stop here for now
odf ( ) posted Sun, 30 May 2010 at 6:56 PM · edited Sun, 30 May 2010 at 6:58 PM
file_453706.txt
It seems that for the icons to work, one needs to use the Windows version of Firefox (installed under Wine, obviously). I couldn't get AIR to work on the first try and spontaneously decided I didn't need it. :laugh:
In order to be able to start Poser with one click, I wrote the attached little shell script. Maybe it's useful to someone. This is the PP2010 version. For the P8 version, the paths and the name of the executable will of course have to be changed. Also in the first line you have to change the path to point to your .wine directory.
WandW ( ) posted Sun, 30 May 2010 at 7:19 PM
Online Now!
Now why didn't I think of that!  :blink:
Be sure to set the permissions to executable...
rjjack ( ) posted Wed, 09 June 2010 at 8:59 PM
> Quote - It seems that for the icons to work, one needs to use the Windows version of Firefox (installed under Wine, obviously). > > In order to be able to start Poser with one click, I wrote the attached little shell script. Maybe it's useful to someone.
Thanks, icons are working now and the script is useful
FYI DS 3.1 is working fine too
DAZ recently updated the DAZ Studio advanced and the setup tools to version 3.1.0.148, the installation was fine, before running DS you need to copy the fonts cour.ttf and times.ttf, from /usr/share/fonts/truetype/msttcorefonts/ to /home//.wine/drive_c/windows/Fonts/
screencap is from my HP Mini 5102 netbook, Poser don't run well on this machine, but DS is usable, now i can experiment with the setup tools when i am travelling
odf ( ) posted Wed, 09 June 2010 at 9:15 PM
Is that a free upgrade for owners of DS 3.0? If so, I'll definitely give it a try. Having to fire up a VM each time I want to use D|S gets a bit annoying.
mylemonblue ( ) posted Wed, 09 June 2010 at 9:21 PM
Quote - > Quote - It seems that for the icons to work, one needs to use the Windows version of Firefox (installed under Wine, obviously).
Is that HP Mini 5102 netbook using a Intel Graphics Chip? If DS runs with Wine+Linux on a system using Intel Graphics that would be amazing.
My brain is just a toy box filled with weird things
ar3d ( ) posted Wed, 09 June 2010 at 10:59 PM · edited Wed, 09 June 2010 at 10:59 PM
Quote - before running DS you need to symlink the fonts cour.ttf and times.ttf, from /usr/share/fonts/truetype/msttcorefonts/ to /home//.wine/drive_c/windows/Fonts/
Fixed that for you :)
rjjack ( ) posted Wed, 09 June 2010 at 11:03 PM
Quote - Is that a free upgrade for owners of DS 3.0? If so, I'll definitely give it a try. Having to fire up a VM each time I want to use D|S gets a bit annoying.
Visit Support -> Software -> Daz Studio you get a 3.1.0.148 public release or a 3.1.1.11 beta
For the setup tools i have found them on my account, a usual DAZ don't send any update notice, you have to visit DAZ at least once a week to avoid missing something
rjjack ( ) posted Wed, 09 June 2010 at 11:15 PM
based on the HP site the graphic card is a  Intel® Graphics Media Accelerator 3150
overall DS is a bit slow but so far i have not found a problem, my goal is to use it to learn the setup tools, i travel often in train and have plenty of free time
forget the Mini for rendering, the pic in the screencap take half-hour to render, it's just Aiko3 with some clothes and props and two lights, at home my Quad do the same scene in just 1 minute ;-)
odf ( ) posted Sun, 27 June 2010 at 7:37 AM
And... it's broken again.
My Firefox decided it had to update itself, and now I can't get Flash to work anymore.
I have Ubuntu 9.10 and wine-1.1.31. The Flash Player I had installed crashed after the update, so I uninstalled it. But now the installer for the latest version, 10.1, refuses to run.
throws rotten apples at Smith Micro and Adobe
Lucifer_The_Dark ( ) posted Sun, 27 June 2010 at 12:39 PM · edited Sun, 27 June 2010 at 12:41 PM
Good news of a sort, with the latest Wine 1.2rc5 I have managed to run the LSMGUI.exe file in Poser Pro 2010 & apart from the folder icons not showing up properly the library is working.
Sorry did I say it was working? I just ran it again to make sure while typing & it crashed. BUM!!!
Windows 7 64Bit
Poser Pro 2010 SR1
odf ( ) posted Sun, 27 June 2010 at 6:45 PM · edited Sun, 27 June 2010 at 6:46 PM
Well, apparently I can still run Firefox natively under Linux to show the library. Except for the folder icons and thumbnails, everything seems to work. Still hoping that the Flash issue can be resolved in some way. No, wait, I'm hoping that this thing will crash and burn on all platforms, and Smith Micro will realize like Apple did that depending on Adobe is a really bad idea.
bagoas ( ) posted Mon, 28 June 2010 at 12:05 PM · edited Mon, 28 June 2010 at 12:08 PM
Hmm VERY interesting all this. Did anyone try the queue manager under Wine? One of the suggestions I made to Smith Micro when they collected ideas for PoserPro and later for Pro2010 was to include a command line version of the queue manager that would run with a unix core in a runtime system. No waste of CPU capacity or memory space on GUI's, virus controls or whatever. Just boot a remote PC networked from CD and then burn it's circuits on rendering, rendering and nothing else.
Didn't hear anything back from them, but this sounds quite close.
WandW ( ) posted Mon, 28 June 2010 at 11:28 PM
Online Now!
Olaf,
I seem to recall reading that re-running the Flash installer in Wine uninstalls it, rather than installing the new version, so try reinstalling Flash.
I have my Poser installed to a subdirectory of my Documents folder, and I symlink it into the Wine C drive, so if things get too screwy I can just blow away the .wine directory and start anew without having to reinstall Poser.  Likewise with the external runtimes...
odf ( ) posted Tue, 29 June 2010 at 12:22 AM
I've tried to run the installer many times in various ways, and it keeps crashing on me. The only thing left to try seems to be updating Wine and starting with a fresh .wine directory.
Quote - I have my Poser installed to a subdirectory of my Documents folder, and I symlink it into the Wine C drive, so if things get too screwy I can just blow away the .wine directory and start anew without having to reinstall Poser.  Likewise with the external runtimes...
Sounds good. I'll try that.
