9 threads found!
Lenora2 | 2 | 99 | ||
Lenora2 | 5 | 146 | ||
Lenora2 | 7 | 286 | ||
Lenora2 | 12 | 492 | ||
Lenora2 | 6 | 259 | ||
Lenora2 | 8 | 196 | ||
Lenora2 | 23 | 538 | ||
Lenora2 | 4 | 198 | ||
Lenora2 | 22 | 408 |
35 comments found!
No I did not, but I already solved the problem by reinstalling the service pack 3 for Poser7, my boyfriend said that such bugs sometimes happen for no good reason...
but at least the topic is here, and people that eventually have the same problem can consult e ask questions too.
Thanks for the help!
Thread: Librarie Error When Running Poser 7 | Forum: Poser - OFFICIAL
Oh, so I have to increase the 'reading' time, right? Where I change this thing?? and HOW? I'm a noob in programming and stuff, I'm just a simple pc user ^^'
Thanks for the advice!
Thread: Occlusion Master and Unimesh realism Kit Problem in Smith Micro Poser7 | Forum: Poser - OFFICIAL
well, gona try it out after my actuall render ends... alredy changed the col= to column= with txt viewer, hope it works ^_^'
Mine is alredy like this
copy of the grid line:
self.ButtonFrame.grid(row=3,column=0,columnspan=3,sticky="ew")
Thread: I see the girl next door 4 has been released... not bad at all! | Forum: Poser - OFFICIAL
GND4 is amazing, saw some pictures and loved her
now a tricky question... Maybe you could ask, I don't know, someone who's good with adapting magnets to build up a fitting magnet to GND4 (to use V4 clothes on her and stuff like that). Using Netherworks clothkit with the magnets is also a very good thing, since it converts the magnets into morphs, so I've been thinking it would be a great idea, don't you guys agree?? grinlove
Thread: Apollo 2008!!!!!!!!!! | Forum: Poser - OFFICIAL
Quote - Stormchaser. That is one hell of a scary vid you have running in your sig line there!! :blink:
What character is that if I may ask?? Reminds me of The Ring movie, which, in my humble opinion, was hella cool!! :scared:
It's from a movie called Silent Hill, based in the homonymous game
and yeah, Apollo is the only male in my runtime (altough I used Hiro for a while, indeed)
great job Mr Anton!
Thread: Softer Shadows in AO | Forum: Poser - OFFICIAL
After a lot of testing I found out what to do...
I apllyied the settings of the Light AO into the node, and it worked fantastic ^_^
Thanks for all your tipping!
Thanks BagginBlill, i will certainly try out what you just explained...
Problably that's what was done in 4blueyes packege of Bright Lights...
That's the opposite of what I'm doing.
I use occlusion master to avoid using AO in a light, my computer is not fancy eonough for that, and I just want thing to shadow over the main character, but in a soft way.
as an example: the hair of my actual render (where I'm using Occlusion master in a A3 character) projected a shadow of itself over Aiko's face. That's good, that's correct. But the shadow wich was projected was too sharp... I can't describe that without illustrating what I want...
Like when you put your hand between a lightspot and a wall; closer your hand get's to the wall, shaper the shadow appears; the closer your hand gets to the spotlight, the shadow projected gets smoother.
I didn't mean that, I mean Ambient occlusion shadows, not overall shadows... Like the different levels of smoothness in 4blueyes IBL Bright package (sharp, soft, softer)
Thread: GND4 Outfits Wishlist | Forum: Poser - OFFICIAL
What a fantastical job, modelling Aeon's suit... fantastical job... hope you put it on the store after finished... I would certainly buy it, as most of the posters of this topic...
Thread: IBL Brights from 4Blueyes | Forum: Poser - OFFICIAL
Thanks guys for the opinions! I usually lower my bucket size too (I do believe that it takes long to render, it's a very detailed light) but unchecking the AO will, eventually, take away one of the most fantastic effects that the light gives... gonna give it a try anyway!
Thread: Poser7 shuts down when I try to open a saved pz3 file | Forum: Poser - OFFICIAL
thanks nruddock
I did what was suggested in the link you posted here, and the file opened (without morphs as stated in the link too)
But I guess that's better than nothing, after all is just applying the morphs all again...
Thanks you all**
Thread: Help! what Happened to my Props Library?! | Forum: Poser - OFFICIAL
