23 threads found!
cfpage | 1 | 309 | ||
cfpage | 3 | 376 | ||
cfpage | 4 | 128 | ||
cfpage | 6 | 221 | ||
cfpage | 4 | 259 | ||
cfpage | 4 | 139 | ||
cfpage | 10 | 905 | ||
cfpage | 4 | 188 | ||
cfpage | 3 | 112 | ||
cfpage | 2 | 102 | ||
cfpage | 5 | 199 | ||
cfpage | 3 | 124 | ||
cfpage | 1 | 130 | ||
cfpage | 1 | 100 | ||
cfpage | 7 | 87 |
104 comments found!
Thread: Copy morphs from figure | Forum: DAZ|Studio
RHaseltine posted at 5:50PM Tue, 21 April 2020 - #4386900
If this is a custom morph you need to make sure that you have AutoFollow turned on in the Parameter Settings dialogue - click the gear icon at the right-hand end of the slider. Also, unless it's been fixed in a recent update, custom morphs that are embedded in a scene file (rather than saved as a morph asset) sometimes fail to project properly on reloading the scene
thank you for your help learned something new
RHaseltine posted at 10:38AM Tue, 21 April 2020 - #4386882
Which figure? For the Genesis figures morphs are automatically projected into fitted items if their AutoFollow property is on. For legacy figures, select the figure and right-click>Transfer Active Morphs.
Ok I should have been more detailed, I morphed gen3 head and morphed a custom, to the shape of V3 head, Now I want to add A hair fig to g3 and adapt to the new shape I made, I know I can export the hair and adjust and make a morph for it, I was just wondering If I can do in daz auto Like in poser "copy morphs from fig " thanks for reply
Thread: Blender Cloth | Forum: Blender
cfpage posted at 10:16AM Sun, 20 October 2019 - #4367642
I use poser cloth room a lot but sometimes, the results are sloppy like intersection, it's good but trying to see if blender can do better it does not have the above mentioned "designate certain vertices as rigid, decorated, or even completely not drapeable" I think I have a solution, for blender, will post results if any one is interested.
here's my work around, start with a single mesh, say a long sleeved T-shirt for example, next detach the arms form main body. assign+ vertex group to corresponding detached parts (were they attach) run simulation to arms use setting req (silk) when done run body (leather) when finished join parts remove double verts (weld) finished. you can do collars, cuffs ect. theirs wide rang of possibility here. just having fun with blender and poser
Lobo3433 posted at 10:25AM Fri, 18 October 2019 - #4367516
This is a long tutorial but the creator goes into extensive detail and does also reply to questions if what your looking for is not answered in the tutorial How To Make 3D Clothes and Outfits In Blender 2.79 I hope this helps
Thanks for respond, link has some good modeling tips I can use later, what I am looking for is cloth room, in poser you have separate dynamic groups, wondering if this was possible in blender. I can do this by chopping off different parts and merging them back, but this reg. mutable animations, was hoping for doing it in one. thanks any way.
Thread: Copy Position only: X,Y,Z | Forum: New Poser Users Help
this is what I do, select body or hip, depending on which one is the xyz, copy it, open notepad or word, paste it, now copy just the xyz and paste it to the fig you want. simple and quick
Thread: poser to blend is very small | Forum: Blender
Iam a basic user. never learned what clamp size is or does. import your obj. hit "s" on keyboard inter 10.or your size, on numeric, do your work when finished go to object mode hit "alt and s" now your obj is back to its org size and export. some one here taught me that hope that helps
Thread: V4's leg length morph and fitting clothing? | Forum: Poser - OFFICIAL
in the free stuff **Dimension 3D ** has a utility copy scale and also un hide dials , might help you.
Thread: Is there anyway to... | Forum: Blender
Quote - Tab into edit mode select the teeth faces and hit H key this will hide them. Alt+H key to get them back. This will protect them from your sculpting
that was to easy thank you
while on the subject (vertes groups)Iam trying to creat a face morph for poser
I have no problems to so exept when doing a smile for instance if I use the sculpt or proportional edit, it effects the teeth how can I make them Isolated from those tools.
thanks.
Thread: Exploding morph ! | Forum: Poser - OFFICIAL
well its no mystery your vertex order got mix-up
if it is stretching up or down the head was moved in world space
sorry to tell you their is nothing you can do as far as I know
maybe some else can tell you a fix for it but I dont think so.
Thread: How can a 3D texture be rotated in the Materials Room? | Forum: Poser - OFFICIAL
Thread: Constrain groups in Cloth Room | Forum: Poser - OFFICIAL
Thread: split an edge like in 3ds max | Forum: Blender
Quote - shortcut is V or use ctrl+v to get menu then its called rip
note it tends to rip towards cursor so get that on the right side ;-)
hope thats what you want I've never used max
I searched before I posted used words like split, break detach. and its called rip LOL tried it works hard to get used to this blender
anyway Thanks.
Thread: GPU wont render | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
