129 threads found!
igohigh | 1 | 198 | ||
igohigh | 8 | 331 | ||
igohigh | 17 | 743 | ||
igohigh | 14 | 655 | ||
igohigh | 8 | 320 | ||
igohigh | 2 | 205 | ||
igohigh | 16 | 556 | ||
igohigh | 77 | 3293 | |
igohigh | 3 | 746 | ||
igohigh | 15 | 614 | ||
igohigh | 10 | 279 | ||
igohigh | 4 | 167 | ||
igohigh | 4 | 116 | ||
igohigh | 4 | 148 | ||
igohigh | 13 | 325 |
2,593 comments found!
RedPhantom posted at 10:03 PM Sun, 12 May 2024 - #4484704
igohigh posted at 9:05 PM Sun, 12 May 2024 - #4484702Yes, I found my camera Was underground.....While I did have the Ground Prop invisible and no shadows I did not think to make ground Invisible to the Camera!This sounds like you had the camera underground. A workaround would be to make the ground invisible to the cameraAre you by chance trying to get a camera angle Looking UP at your subject?
This happened to me all of a sudden, it took me bit then I realized I had the camera BELOW ground.
Working in the work space all looked just fine, but renders came out a Blank Screen.
At first I could not believe this was the case but I moved the camera Up and re-rendered and *POOF* there was my scene....just not at the angle I was wanting so I had to play around until I got an angle Poser would accept and I would accept:
I will certainly give that one a try next time; THANKS!
But I guess this was not Faery_Light's issue???? Just thought I would toss it out...
Thread: Why is Poser rendering a blank screen | Forum: Poser 13
Thread: EZ Pose Dials LOCK UP with two or more Charaters in scene? | Forum: Poser 13
One other observation; When I first noticed the trouble was when I brought them both into a scene to test render.
1) Set up V4 & her tail
2) Brought in M4, posed the tail, then posed M4
3) Tried to adjust M4's tail: LOCKED ??
Then I turned away...when I looked back BOTH the tails were curled up like a pig's tail?!!?
Mike's was Locked, Vicky's I could pose but it was so curled I just hit Render because I was checking clothing and colors....
The Render came out with Vicky's tail in the original pose I set?? But back in the Pose Room it was still curled?!!?
It was late, I shut it all down and came back to it today...
Oh, and each tail if you are not familiar with them, have their own .obj file in their own separate folders (one in MilMan and one in MilWoman geometries folder)
And I did try re-naming some of the CR2 and even one of the tail .obj files, just trying to 'separate' them for Poser - no luck
Thread: Crossdresser? | Forum: Poser - OFFICIAL
No LF2 license yet. I have been watching the website.
Crossdresser does more during the processes then the tutorials out there; not sure what or how but it converts morphs over great for compound movements and things such as 'open-close' on coats, vests, and shirts.
I do hope EvilInnocence finds time to add LF2, it has been an invaluable tool for many years now!
Thread: Clothing V4-to-LF1-to-LF2 with clothing morphs carried over? | Forum: La Femme 2
Yes, that is what I am finding on other pieces as well. A "Victorian Bundle" I have for V4 converts the Chemise to LaFemme1 perfectly with CrossDresser, it has a morph to slightly open the top couple buttons. But when converted to LF2 it only stretches the Chemise.It seems to me that the morph projection is getting confused with those vertices touching each other there. The vest that worked well isn't closed at the front.
RobZhena posted at 7:33 PM Sat, 9 December 2023 - #4478873
I have restarted....dozens of times. They are not 'misbehaving', they are just not copying over correctly or the conversion using the LF2 Tools are altering the mesh...?This will sound stupid, but when morphs start misbehaving, I restart Poser.
Maybe this render explains better.
All Six 'Combat Jackets' are rendered together in the same scene to show that CrossDresser can copy the morphs over to the converted piece but the Poser converted/fitted piece is welding itself closed for some reason??:
RobZhena posted at 10:48 AM Tue, 5 December 2023 - #4478671
I have done that and it just won't work.Copy morphs from the original V4 garment. You can do that for any clothing conversion, and it usually works pretty well. It doesn’t have to be the sa,e garment. I copy morphs from the morphing fantasy dress to other gowns all the time. I find, though, that open and close morphs can just tear the mesh if the garment is completely closed at the start.
Oh Shoot!
I just realized the end of your comment.
YES, this blouse IS "completely Closed" in it's default position....
Is there a fix for this??
Again: Crossdresser can convert from V4 and copy the morphs over - so how can we do this for LF2??
there must be a set or method that Crossdresser knows that we dont?
Thread: Show your Poser 13 renders! | Forum: Poser 13
hborre posted at 11:02 PM Wed, 23 August 2023 - #4473303
Perhaps "Depth Cue" is the wrong terminology, just repeating what the little check box in SuperFly Render Settings calls is; Perhaps 'Depth Blur'?Superfly does not recognize Depth Cue so that is a waste in set up time. Keep in mind that the PhysicalSurface node emission defaults to Inverse Square falloff which means that you really need a very high emission value. The only way to change that behavior is to attach a Lightfalloff node, which offers additional Linear and Constant features not found on the PhysicalSurface node. When using mesh lighting from an object, you can hide the object in the scene by not making it visible to the camera or Raytracing but still display your light.
with Depth checked in SP settings (but NOT set up in the material room)
Okay, so I am beginning to some sense out of these cycle node connections, but not so much sense out of the math.
I have been watching and studying particularly Ghostship and Afrodite-Ohki work.
So now I have this: La Femme with BillyT's cutoffs (converted) and her two pups Sweet and Pea.
Lights are still my nightmare...so I went with No lights and just used three Balls:
1) Large ball with blackbody node on Physical Surface root.
This one just in front of La Femme and up out of camera
2) Smaller ball using Cycles root with one of Ghostship's nodes with blackbody
This one just in front of Harley's Henchman (aka Funnyman)
3) A large ball in the background: this one I have tried lighting with both methods. I am trying to light up the background with a Dark Purple (think Gotham City) but don't seem to be getting anywhere with it.
I don't want to blow away the front lighting, just get somewhat of a 'black light' effect (yes I know Poser can't do "Black Light" truly).
I rendered it with Depth Cue but Poser's DC is too shallow and it made her Henchman none recognizable but looked pretty good with the floating cards...I may do a double render and stack them in Photoshop once I can get the lighting worked out.
Thread: Template SIZE vs Render Quality question | Forum: Poser - OFFICIAL
Exactly what prompted me to ask and that answers my question spot on!!There's no issue with enlarging the template first. Yeah, you get some blurred lines, but that can easily be worked around. You use the outside of the lines on the edge of the template and the center of the ones in the middle
here is a skirt that was textured with the original temple of 500 and one enlarged in Paintshop Pro to 2048. The second is much clearer. It's more noticeable if you view the image at full size.
and here, you can see a closeup of the island edges to show that there isn't any of the template background peeking through at the edges.
I think the confusion here is in the terms 'UV' vs 'template' vs 'texture.
where:
UV is the coded map of the object as it presents itself to the render engine
Template is the 'template' of the UV mapping, used in graphic apps to paint on
Texture is the painted template of the uv mapped object.
Now, in UVMapper one is asked "What size to save out the TEMPLATE" and usually has a default of 520x520 (?) but can be changed to 'whatever' and not even need be square.
The question here is again:
IF I saved out the TEMPLATE at default 520x520 but then in Photoshop enlarged it to 4000x4000 and painted a Texture on it. Save the Texture at the 4000x4000
One can paint much more detail on a 4000x sheet of paper then on a 520x - but both being applied onto the SAME Obj with the same original UV mapping.
I think FVerbaas and ironsoul answered the question.
Also the T-shirt I was speaking about does render out much better with the larger Texture then had I painted onto the original smaller map.
No "stretching" involved....sorry, I did not understand that explanation at all but have seen ill effects if say the Original map was Not square (say 1024x762) and I RESIZE the TEMPLATE (or texture) into a 1024x1024 and paint on it....IF I then apply that texture to the object it 'stretches' the texture UNLESS I run the object file back through the mapper and save out a 'squared' UV map (ie Template) and replace the original model with the newly mapped one.....
Anyway: resizing the TEMPLATE did allow me the results I was looking for - thanks all
@ironsoul; I think maybe that answers my question.
I am not talking about enlarging a texture to edit and then reducing it to apply in Poser.
What I am wondering is: If I enlarge the Template, then paint my texture to to and Save it at the larger size...does the render engine render my larger template or does it (behind the scene) reduce it back down to the smaller size that the object file was originally mapped at?
@hborre; pretty much what I have started doing.
I was just wondering if:
1) could I save some work and just enlarge the existing template file, paint it, save it as my larger file and use it - or would the render engine just reduce it back down to render?
2) when I do re-map (not really "re-map" but just run it through UVMapper and save as a larger template) do I need to Save the OJB in place of the original for the render engine to use my newly sized map....or would the engine look at the obj and look at my larger texture and say "Hey, this map is too large, I will shrink it down and render it"?
Thread: La Femme Template? (for making 2nd skin) | Forum: Poser - OFFICIAL
Thank you EnglishBob!The seam guides are live in Rendo Freestuff:
https://www.renderosity.com/freestuff/items/95826/seam-guides-for-lafemme
