37 threads found!
Singular3D | 1 | 1967 | ||
Singular3D | 8 | 3142 | ||
Singular3D | 9 | 277 | ||
Singular3D | 4 | 948 | ||
Singular3D | 19 | 359 | ||
Singular3D | 2 | 176 | ||
Singular3D | 2 | 155 | ||
Singular3D | 5 | 177 | ||
Singular3D | 3 | 10 | ||
Singular3D | 23 | 85 | ||
Singular3D | 2 | 9 | ||
Singular3D | 7 | 27 | ||
Singular3D | 6 | 20 | ||
Singular3D | 18 | 184 | ||
Singular3D | 14 | 19 |
398 comments found!
Solved it. I had put a fake poser.exe to the directory for some old DAZ installer, that check for this file. This confused the updater. I removed it and voila, it worked.
Thread: Why are you still using V4? | Forum: Poser - OFFICIAL
I mostly render in Cinema 4D and sometimes Carrara in the past. So Genesis is no use for me. Transfering the characters is just annoying. I also have a lot of V4 content. Simple as that.
Thread: OT - I'm probably over-qualified......... | Forum: Bryce
Well. Just go to the american ambassy on Mars and ask for a green card. That will be a great start.
Thread: Why no Marketplace-items like that (Vue) for Carrara, too? | Forum: Carrara
In my opinion, a major issue is, how Daz takes care of Carrara. There's no clear roadmap and no one knows, where Carrara goes. Vue has been used and will be used in prime movie productions and thus is slowly becoming a major application for landscapes. Carrara mainly improved in being Daz content friendly. Atmosphere and cloud improvements are progressing slowly.
I honestly like Carrara and Howie showed us Carrara's potential. Nevertheless the community is quite small and I would have prefered, if Daz integrated Studio slowly into Carrara. This would have been a big push!
Thread: Even with a new computer: the same nightmare | Forum: Vue
Unfortunately Vue was never good at handling memory limits. Other programs deny an operation, Vue simply crashes. Now that Vue went 64bit, I highly recommend using a 64bit operating system. That should help to keep the number of crashes low. Nevertheless save often.
Thread: Ozone.... | Forum: Vue
By the way: You can't use Ozone with the actual Cinema 4D version 12. I think the last version it worked with was C4D Version 10.5.
Also the atmophere capabilities are outdated. Ozone 4 uses the features of Vue7. Seems e-on is not keeping it up to date any longer.
Thread: Infos about Vue9 Esprit needed! | Forum: Vue
Thanks bruno for the reply. Cinema 4D can take spherical HDRIs and convert cross HDRIs. The free HDR Shop also supports conversion of all types of HDRIs. So I wonder, what the benefit of the quite expensive exporter module will bring in this use case.
Unfortunately there is no trial version of Vue9 available up to now, so I wanted to ask some owners of Vue9 here.
Thanks a lot, I thought this might be the case, although they state at e-ons site that Vue9 Esprit can render 360° images without limitations.
RenderUp adds both standard and spherical panoramic rendering with adjustable angle up to 360 degrees. This is especially useful for creating and exporting environment HDR images and backgrounds.
Obviously this doesn't mean, that they can be saved. Don't want to rant here, but a spherical projection should be possible and saveable without exporter module.
I did, but it is not very clear, what is completely or only partly included and where additional modules are needed. Some links on e-ons site are broken.
Also looking for experience.
Thread: AMD 6 Core | Forum: Vue
I have an AMD 6 core and plan to use Vue9 Esprit quite soon. Let you know about the results.
Thread: Still necessary to install V4 in the Poser Runtime? Why? | Forum: Poser - OFFICIAL
Thanks for the fast reply. Made a fresh install on my new PC with Win7 64bit and wanted to set up everything the right way. No data on my main drive.
Thread: Antonia - Opinions? | Forum: Poser - OFFICIAL
Thread: New Antonia thread | Forum: Poser - OFFICIAL
I plan to do a free texture set, when Antonias mapping is final and maybe some morphs. She looks very useful. Thanks to all for contributing.
Thread: Problems installing support files | Forum: Poser - OFFICIAL
