48 threads found!
sittingblue | 4 | 233 | ||
sittingblue | 4 | 171 | ||
sittingblue | 5 | 235 | ||
sittingblue | 0 | 12 |
(none)
sittingblue | 16 | 84 | ||
sittingblue | 6 | 32 | ||
sittingblue | 4 | 99 | ||
sittingblue | 4 | 105 | ||
sittingblue | 19 | 909 | ||
sittingblue | 22 | 461 | ||
sittingblue | 4 | 301 | ||
sittingblue | 0 | 25 |
(none)
sittingblue | 5 | 140 | ||
sittingblue | 6 | 143 | ||
sittingblue | 11 | 261 |
813 comments found!
IMHO, turn the cam a few degrees so that the angle of the pole group is approximately 30° to 45°. This will give a greater perception of depth as the lines of the pole will draw the viewer into the scene, and the background terrain will expand into the horizon.
Charles
Thread: New PC | Forum: Vue
With the computer in hand, do an over-night memory check right away with MemTest before installing apps.
Charles
Thread: Vuueport issues, SERIOUSLY aggrivated | Forum: Vue
You could try increasing the smoothing angle on the V4 model to smooth-over the triangle-polygons in the render. Select object. Press ctrl-e. There are other options in the object editor that might work as well.
Charles
Thread: I can't open Vue 7 Esprit | Forum: Vue
AMD is the place to look for a Radeon driver:
http://support.amd.com/us/gpudownload/Pages/index.aspx
Charles
Charles
Something like this happened to me when I first got V7i. Sometimes I couldn't start the program, other times, it would crash without cause or event. After, I installed the latest video card driver, the problem cleared up. A new video driver may help you as well.
Charles
Thread: Small tip for those of us with Antec 900 gamer cases :) | Forum: Vue
I don't know if this helps, but I keep an air cleaner appliance running 24/7. Then I dust once a month with a Swiffer cloth. My computer's internal parts have collected minimal dust in a one year period.
Charles
Thread: shadow problem? | Forum: Vue
Thread: Why for does Vue do this to volumetrics? :) | Forum: Vue
I don't why Vue does that with volume materials, but I've seen it many times.Â
I believe the final volumetric material scale is dependent on the scale of the volumetric container. How so? I don't know. Maybe somebody knows about this relationship between volume material and volume material container.
Charles
Thread: 1-way mirror "trick" | Forum: Vue
Thread: Happy Holidays.... | Forum: Vue
Thread: Freebie Model from C3d (update) | Forum: Vue
Thread: Grainy motion blur in 6i | Forum: Vue
I think most would do this kind of blur in postwork. My experience with motion blur is that to get rid of the grain, I had to bump the user-setting's object anti-alias amounts to over 255+.
Charles
Thread: Where does the light come from when inside a box? | Forum: Vue
This has something to do with the normals of the cube. The normals are facing outward. The best work-around is to create a hollow box with a boolean subtraction.
Charles
Thread: WIP: German Free Energy Device | Forum: Vue
Thread: Segestions for enproving this? thanks!! | Forum: Vue
